Recovery of a fast blanked CD-RW won't work
fpf71
#1 Post by fpf71 »
Following the hints (see: https://www.cgsecurity.org/wiki/CDRW#Re ... nked_CD-RW) still doesn't help.
Using latest versions of testdisk_static and photorec_static under Linux. Even with different DVD/CD-RW writers/readers I can't find a way to unformat the CD-RW.
CD-RW was unfortunately fast formated by using CD Burner XP (cdpxpp).
Any ideas or step-by-step instructions how to recover the datas?
Thanks in advance...
Re: Recovery of a fast blanked CD-RW won't work
No.
