I am trying to recover files from a flash drive at work. It is a SanDisk Cruzer Micro, 4gb. The drive has 1 partition, and it appears as raw in windows. Testdisk seems to recognize it as FAT16, but it fails to find the partition, or any files. I will attach the Log.
Mon Aug 1 11:50:16 2022
TestDisk 7.2-WIP, Data Recovery Utility, July 2022
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=256058064896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4016045568
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=254935286272
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4013948928
Disk \\.\PhysicalDrive0 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - Intel Raid 1 Volume, S/N:Volume1, FW:1.0.
Disk \\.\PhysicalDrive1 - 4016 MB / 3829 MiB - CHS 488 255 63, sector size=512 - SanDisk Cruzer, S/N:22430311AD816CAF, FW:8.01
Disk \\.\PhysicalDrive1 - 4016 MB / 3829 MiB - SanDisk Cruzer
Analyse Disk \\.\PhysicalDrive1 - 4016 MB / 3829 MiB - CHS 488 255 63
test_FAT()
1 P FAT16 >32M 0 2 3 488 2 26 7839744
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
Bad sector count.
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
fat1x_boot_sector
Bad
rebuild_FAT_BS p_fat12 0, p_fat16 0, p_fat32 1
fat_find_type(max_offset=61312, p_fat12=0, p_fat16=0, p_fat32=1, debug=1, dump_ind=0)
No FAT found, reserved=0, fat_length=0
find_sectors_per_cluster skip_sectors=358 (skip_offset=183296)
Can't find cluster size
fat1x_boot_sector
Bad
FAT16 Invalid Boot Sector?
Re: FAT16 Invalid Boot Sector?
What exactly is your question?
Im wondering if recovery is possible. Ive follwed the other threads with the same issue, and it worked for them, but not for me. This sofware probably isnt enough, but I was really hoping to avoid paying for a sofware/service.
Have you tried the deep search after the normal search?
Yes, it did not find anything.
What information was located on the stick?
Is the USB stick encrypted?
