Kingston SSD sudden fail and partitions missing Topic is solved
sergioc
#1 Post by sergioc »
Hi, I have a Kingston SUV500/240GB SSD drive which failed recently (overnight) without any warning. It now shows up on the main screen of the BIOS but the destop now says please insert boot disk.
i tried to run testdisk but i am unable to find anything, after that i made a image using ddrescue and run testdisk again using the image, same thing
using the image that i had and using a new ssd where i restore the image to, gives this log:
Tue Aug  2 12:00:51 2022
TestDisk 7.2-WIP, Data Recovery Utility, May 2021
OS: Linux, kernel 5.18.2-pmagic (#1 SMP PREEMPT_DYNAMIC Tue Jun 7 10:25:12 CDT 2022) x86_64
Compiler: GCC 11.2
ext2fs lib: 1.46.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: 20140806, curses lib: ncurses 6.2
/dev/sda: LBA, HPA, LBA48 support
/dev/sda: size       468862128 sectors
/dev/sda: user_max   468862128 sectors
/dev/sda: native_max 468862128 sectors
Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - KINGSTON SA400S37240G, S/N:50026B73814FE17D, FW:SAJ20103
Disk /dev/sdb - 8011 MB / 7640 MiB - CHS 1021 247 62, sector size=512 - Kingston DT 101 II, FW:PMAP
Disk /dev/sda - 240 GB / 223 GiB - KINGSTON SA400S37240G
Analyse Disk /dev/sda - 240 GB / 223 GiB - CHS 29185 255 63
SMART of the original ssd
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.18.2-pmagic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Kingston SSDNow UV400/500
Device Model:     KINGSTON SUV500240G
Serial Number:    50026B7682D0B062
LU WWN Device Id: 5 0026b7 682d0b062
Firmware Version: 003056RR
User Capacity:    240,057,409,536 bytes [240 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-4, ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Aug  2 12:08:21 2022 CDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Disabled
ATA Security is:  Disabled, frozen [SEC2]
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(    5) seconds.
capabilities: 			 (0x71) SMART execute Offline immediate.
					No Auto Offline data collection support.
					command.
					No Offline surface scan supported.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 (   5) minutes.
Conveyance self-test routine
recommended polling time: 	 (   0) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 48
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   100   100   000    -    1442464
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  9 Power_On_Hours          -O--CK   100   100   000    -    17627
 12 Power_Cycle_Count       -O--CK   100   100   000    -    537
100 Unknown_Kingston_Attr   -O--CK   100   100   000    -    4935584
101 Unknown_Kingston_Attr   -O--CK   100   100   000    -    796848
170 Reserved_Block_Count    -O--CK   100   100   000    -    0
171 Program_Fail_Count      -O--CK   100   100   000    -    0
172 Erase_Fail_Count        -O--CK   100   100   000    -    0
174 Unexpect_Power_Loss_Ct  -O--CK   100   100   000    -    67
175 Program_Fail_Count_Chip -O--CK   100   100   000    -    0
176 Erase_Fail_Count_Chip   -O--CK   100   100   000    -    0
177 Wear_Leveling_Count     -O--CK   089   088   000    -    3427
178 Used_Rsvd_Blk_Cnt_Chip  -O----   100   100   000    -    0
180 Unused_Rsvd_Blk_Cnt_Tot -O----   100   100   000    -    664
183 Runtime_Bad_Block       -O--CK   097   092   000    -    35
187 Reported_Uncorrect      PO--CK   100   100   000    -    0
194 Temperature_Celsius     -O---K   033   100   000    -    33 (Min/Max 4/42)
195 Hardware_ECC_Recovered  -O--CK   100   100   000    -    1442464
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O--CK   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O--C-   100   100   000    -    0
201 Unc_Read_Error_Rate     -O--CK   100   100   000    -    0
204 Soft_ECC_Correction     -O--CK   100   100   000    -    1442464
231 SSD_Life_Left           -O--CK   089   088   000    -    11
233 Media_Wearout_Indicator -O--CK   100   100   000    -    17835
234 Unknown_Attribute       -O--CK   100   100   000    -    9312
241 Host_Writes_GiB         -O--CK   100   100   000    -    10811
242 Host_Reads_GiB          -O--CK   100   100   000    -    16826
250 Read_Retry_Count        -O--CK   100   100   000    -    1442469
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL,SL  R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x0a       GPL     R/W      5  Device Statistics Notification
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1           SL  VS       9  Device vendor specific log
0xab           SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 0 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 0 (1 sectors)
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
SCT Status Version:                  3
SCT Version (vendor specific):       1 (0x0001)
Device State:                        Active (0)
Current Temperature:                    33 Celsius
Power Cycle Min/Max Temperature:     31/33 Celsius
Lifetime    Min/Max Temperature:      4/42 Celsius
Under/Over Temperature Limit Count:   0/0
SMART Status:                        0xc24f (PASSED)
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/70 Celsius
Min/Max Temperature Limit:            0/85 Celsius
Temperature History Size (Index):    478 (38)
Index    Estimated Time   Temperature Celsius
  39    2022-08-02 04:11     ?  -
 ...    ..(437 skipped).    ..  -
 477    2022-08-02 11:29     ?  -
   0    2022-08-02 11:30    29  **********
   1    2022-08-02 11:31    30  ***********
   2    2022-08-02 11:32    31  ************
   3    2022-08-02 11:33    32  *************
   4    2022-08-02 11:34    32  *************
   5    2022-08-02 11:35    32  *************
   6    2022-08-02 11:36    33  **************
 ...    ..(  5 skipped).    ..  **************
  12    2022-08-02 11:42    33  **************
  13    2022-08-02 11:43    34  ***************
 ...    ..( 15 skipped).    ..  ***************
  29    2022-08-02 11:59    34  ***************
  30    2022-08-02 12:00    35  ****************
 ...    ..(  2 skipped).    ..  ****************
  33    2022-08-02 12:03    35  ****************
  34    2022-08-02 12:04     ?  -
  35    2022-08-02 12:05    31  ************
  36    2022-08-02 12:06    32  *************
  37    2022-08-02 12:07    33  **************
  38    2022-08-02 12:08    33  **************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4             537  ---  Lifetime Power-On Resets
0x01  0x010  4           17627  ---  Power-on Hours
0x01  0x018  6     22674213602  ---  Logical Sectors Written
0x01  0x020  6       433716909  ---  Number of Write Commands
0x01  0x028  6     35286741475  ---  Logical Sectors Read
0x01  0x030  6       663240904  ---  Number of Read Commands
0x01  0x038  6     63459662530  ---  Date and Time TimeStamp
0x02  =====  =               =  ===  == Free-Fall Statistics (empty) ==
0x03  =====  =               =  ===  == Rotating Media Statistics (empty) ==
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4            2682  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              23  -D-  Current Temperature
0x05  0x010  1               0  -D-  Average Short Term Temperature
0x05  0x018  1               0  -D-  Average Long Term Temperature
0x05  0x020  1              42  ---  Highest Temperature
0x05  0x028  1               4  ---  Lowest Temperature
0x05  0x030  1               0  -D-  Highest Average Short Term Temperature
0x05  0x038  1               0  -D-  Lowest Average Short Term Temperature
0x05  0x040  1               0  -D-  Highest Average Long Term Temperature
0x05  0x048  1               0  -D-  Lowest Average Long Term Temperature
0x05  0x050  4               0  -D-  Time in Over-Temperature
0x05  0x058  1              70  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  -D-  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4            2682  ---  Number of Hardware Resets
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
0x07  0x008  1              11  ---  Percentage Used Endurance Indicator
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  4            0  Command failed due to ICRC error
0x000a  4            6  Device-to-host register FISes sent due to a COMRESET
after this i tried photorec and others but did not find anything.
any more ideas?
thanks
Re: Kingston SSD sudden fail and partitions missing
You posted important logs, but after running ddrescue it would have been worth looking at the ddrescue logfile and the final appearence of the status window of ddrescue in the command line.
You could look into the ddrescue image if there is content other than zero.
Furthermore you might get yourself an uninterruptible power supply or set up a clean system that does not require cutting of mains power to shut it down.
That might extend the life of your SSDs with a remaining life estimation of 11 (% ?) which appears low after having only written 11 Terabytes.
Otherwise contact a professional recovery service.
sergioc
#3 Post by sergioc »
hello thanks for the replay,
i have the mapfile log not sure that help:
# Mapfile. Created by GNU ddrescue version 1.26
# Command line: ddrescue /dev/sdb /media/sda2/ssd.img /media/sda2/ssdlog.log
# Start time: 2022-07-29 12:57:00
# Current time: 2022-07-29 14:09:09
# Finished
# current_pos current_status current_pass
0x37E4890000 + 1
# pos size status
0x00000000 0x37E4896000 +
i had look at the terminal after creating the image, but did not show any erros, and the pct rescued was at 100%
i may be being stupid but even searching on google i didn't find the answer, how can i do that?
the PC was turn off during the night, that is the odd part of about this, when check the SMART using the kingston program at says that the ssd have 89% life left so i am assuming that the 11% in this context is inverted
anyway thanks for the help, if you can tell me how I can have it if the image has content I would appreciate it but yes I can already see that I will have to send it to a recovery company, that's why I'm working with the image, the last thing that I want to do is damage the data more
sergioc wrote: 03 Aug 2022, 10:48 hello thanks for the replay,
# Finished
0x37E4890000 + 1
# pos size status
Sounds good.
Use any hex editor of your choice and open up your image file. Are there only zeros inside? I prefer Hxd (software for Windows) because I can use the vertical slider to move pretty fast across the file.
Thanks for letting me know. With 11 TB written the SMART attribute has to be read differently, indicating another 90 TB that you should be able to write.
sergioc
#5 Post by sergioc »
hello using HXD i can see "data" in the image, but to be honest i got to the point where i don't know how to test it anymore,I don't know if you have any other ideas if not, I think the time has come for a recovery company to take a look
#6 Post by recuperation »
You did not mention anythign about the content. File types, length, encryption etc... but you should contact a professional recovery service anyway.
sergioc
#7 Post by sergioc »
hey, just so you know is a controller issue, so my image is useless, anyway, thanks for the help, have a nice day
