I have this SSD from a Lenovo Yoga 2 pro which stopped working (the laptop and visibly the SSD too). I have tried to put that msata into a USD-Msata reader, I can't detect any drive.
Note; I tested the adapter with another msata SSD it can read well through it, I could access that other SSD data.
I attached my testdisk log:
Note: I also went the road of an adapter msata to sata, and used an icybox sata device, no luck either.
Log:
Note: Crucial_CT256MX100SSD is my laptop SSD.
Sat Aug 13 11:00:31 2022
TestDisk 7.2-WIP, Data Recovery Utility, July 2022
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255369292800
Disk \\.\PhysicalDrive0 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - Crucial_CT256MX100SSD1, S/N:14350D10472E, FW:MU01
Using locale 'C.UTF-8'.
Sat Aug 13 11:06:50 2022
Command line: TestDisk /debug /log /all
Drive C: - 255 GB / 237 GiB - CHS 31046 255 63, sector size=512 - Crucial_CT256MX100SSD1, S/N:14350D10472E, FW:MU01
Any help?
Unable to read the ssd Warning: can't get size for...
RecoverSSD
RecoverSSD
Re: Unable to read the ssd Warning: can't get size for...
- myreport3.txt
- (283 Bytes) Downloaded 834 times
- myreport2.txt
- (389 Bytes) Downloaded 1085 times
- myreport1.txt
- (9.97 KiB) Downloaded 1161 times
RecoverSSD
Alternatively you should connect your drive to a desktop computer internally.
If that fails, contact a professional recovery service.
This is uncomprehensible.
RecoverSSD
I meant the log file myreport1.txt refers to a crucial SSD 256gb. That has nothing to do with that Toshiba msata SSD. I was just specifying.recuperation wrote: 14 Aug 2022, 10:17 Alternatively you should connect your drive to a desktop computer internally.
I don't have that at hand right now but I might have a friend who can help me in a few weeks.
I wonder how useful is posting two empty log files and another one that does not refer to the failed candidate but to another disk without any further explanation.
You will have a high likelyhood of having disk problems in the future as you are operating your computer in unsuitable way.
First, you were running your SSD at -9° Celsius which is out of spec.
Second you have shut down your machine over a hundred times irregularly by cutting the power supply/ pressing the ON switch for an extended time.
Assuming the other machine was operated the same way like you did with the Crucial it is no wonder when suddenly payback day arrives.
RecoverSSD
Hi, first I should mentioned that I'm work in IT for about 20 years, being RHCE, RHCA and various other certifications and numerous experience. Not to brag but to put some context because you feel strangely over confident with your responses.recuperation wrote: 14 Aug 2022, 17:52 1) I wonder how useful is posting two empty log files and another one that does not refer to the failed candidate but to another disk without any further explanation.
2)You will have a high likelyhood of having disk problems in the future as you are operating your computer in unsuitable way.
3)Second you have shut down your machine over a hundred times irregularly by cutting the power supply/ pressing the ON switch for an extended time.
4)Assuming the other machine was operated the same way like you did with the Crucial it is no wonder when suddenly payback day arrives.
1)You are right it's not useful. That's all I got to prove I tried your commands but I could not get any logs from the failed SSD.
I tried to explain that the only log not empty was about another SSD, I did that in poor way, fair enough.
2) my Ssd has never run at -9° Celsius, certainly not. No idea where that comes from. It's inside an old Dell latitude E6430 which is not that young and would tend to be on the hotter side (but not higher than tolerable températures).
3) I never do that. I always turn off my windows using shutdown option. In fact it's docked and I don't even have access to the laptop on/off button when the lid is closed. The dock has a power button but I never use it to shut down the laptop.
I probably had 2-3 powercuts in a few years and even so, the laptop had a battery.
Just saying that I don't understand where what you said come from. I'm also The sole user of that computer.
4) That's actually my wife yoga 2 pro. That machine had issues, also reported by other users, and payback day finally arrived. She reported that it had corrupted screen, with some green, etc... Then never booted again. Sure payback day was likely to happen, worse, from a professional, I did not do any backup of her system. I don't expect sympathy, I fully understand my inaction amplified the problem. Let's say I had other worries, also working top much and being mobbed for along time and lost track.
FYI I bought her a new computer with an external SSD for backups and explained her how to Do. Sure payback day already happened, I just hope that you'll be less hard during judgment Day.
