Testdisk 'Recovers Files' but they do not show Topic is solved
threadburner
#1 Post by threadburner »
Hello all, I have used TestDisk to recover files from a botched re-size operation to an EXT-4 partition.
TestDisk successfully detected those files and copied them to a pen-drive, however I don't see them. The files took some space of the pen-drive, but I don't see them even folders. They're weren't meant to be hidden
I am using TESTDISK-7.2-WIP on Debian.
threadburner
Re: Testdisk 'Recovers Files' but they do not show
#2 Post by threadburner »
Solved, it appears that I need to copy one by one..
#3 Post by recuperation »
How did you select invisible files? Please describe your solution in a way that others can learn from it!
