The harddisk seems too small! - The following partitions can't be recovered Topic is solved
Eeyikes
#1 Post by Eeyikes »
So, I added a fifth 6TB SATA drive to my existing non-encrypted, single-VD 4x6TB RAID 5.
I told the Dell H710 RAID controller to reconfigure to a larger size, as I've done in the past without issue.
And it finished the reconfigure with no errors or issues.
The original 18TB VD was now showing up as a 24TB virtual disk.
The RAID controller sees the correct size and is very happy. All drives appear healthy.
The RAID log is clean.
But for some reason, ESXi 7.6 doesn't see a proper file system any longer. The VMFS6 datastore is showing up as a "0" file size.
So, I booted to Hirems Live CD and ran your cool TestDisk scan utility. But it looks like I'm out of luck? The results look like it cannot help.
I didn't touch any read/write settings.
MESSAGE:
Eeyikes
Re: The harddisk seems too small! - The following partitions can't be recovered
#2 Post by Eeyikes »
This is the TestDisk log:
Mon Aug 22 18:29:49 2022
TestDisk 7.2-WIP, Data Recovery Utility, May 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=27999965544448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=24002424733696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=8002732032
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=3162112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Y:)=8001683456
Disk \\.\PhysicalDrive0 - 27 TB / 25 TiB - CHS 3404135 255 63, sector size=512 - DELL PERC H710, S/N:00e0fe57096830912a006af016c0110b, FW:3.13
Disk \\.\PhysicalDrive1 - 24 TB / 21 TiB - CHS 2918128 255 63, sector size=512 - DELL PERC H710, S/N:0068137805418ab022006af016c0110b, FW:3.13
Disk \\.\PhysicalDrive2 - 8002 MB / 7632 MiB - CHS 972 255 63, sector size=512 - SanDisk Cruzer Fit, S/N:4C530000300729105331, FW:1.00
Drive X: - 3162 KB / 3088 KiB - CHS 193 16 2, sector size=512 - Microsoft Corporation RamDisk
Disk \\.\PhysicalDrive1 - 24 TB / 21 TiB - DELL PERC H710
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive1 - 24 TB / 21 TiB - CHS 2918128 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=46879735807 (expected 46879735807)
hdr_lba_start=34
hdr_lba_end=46879735774
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
aa31e02a 400f 11db 95 90 00 0c 29 11 d1 b8
 1 P Unknown                     2048 46879735774 46879733727
     Unknown                     2048       2047          0
     VMFS 6, 0 B
Partition not added.
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/308, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
recover_EXT2: s_blocks_count 10097664
recover_EXT2: part_size 80781312
Filesystem created: Thu Apr 27 17:57:15 2017
     Linux filesys. data     11660814   92442125   80781312
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 41 GB / 38 GiB
LVM magic value at 16449/186/54
LVM magic value at 17033/10/39
FAT12 at 24157/65/45
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
     EFI System             388086344  388089223       2880 [EFI System Partition] [EFISECTOR]
FAT12 at 24157/111/27
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System             388089224  388092103       2880 [EFI System Partition] [EFISECTOR]
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/308, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
     Linux filesys. data    484429662  565210973   80781312
     BeFS                   620446518 3399592405543893 3399591785097376 [ºŠ)%×7ÆÕ„±4°
°$ôôÎä^£(ÄgC}Þ]
     BeFS blocksize=8192, 1740590 TB / 1583058 TiB
This partition ends after the disk limits. (start=620446518, size=3399591785097376, end=3399592405543893, disk end=46879735808)
LVM magic value at 65437/50/24
block_group_nr 243
     Linux filesys. data   1272478462 1353259773   80781312
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/308, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
     Linux filesys. data   1438568350 1519349661   80781312
     Unknown               1523951850 799395790563561 799394266611712
     WBFS, 409289 TB / 372246 TiB
FAT12 at 97660/21/42
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            1568909264 1568912143       2880 [EFI System Partition] [EFISECTOR]
FAT12 at 97660/67/24
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            1568912144 1568915023       2880 [EFI System Partition] [EFISECTOR]
FAT12 at 97688/17/10
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            1569358800 1569361679       2880 [EFI System Partition] [EFISECTOR]
NTFS at 97689/37/1
filesystem size           6174
sectors_per_cluster       1
mft_lcn                   2058
mftmirr_lcn               5162
clusters_per_mft_record   2
clusters_per_index_record 8
     MS Data               1569369943 1569376116       6174
NTFS at 97689/37/1
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data               1569376116 1569382289       6174 [Boot]
LVM magic value at 100523/92/11
block_group_nr 243
     Linux filesys. data   1555054750 1635836061   80781312
FAT12 at 103240/125/22
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            1658558496 1658561375       2880 [EFI System Partition] [EFISECTOR]
NTFS at 103241/145/13
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data               1658569639 1658575812       6174
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data               1658575812 1658581985       6174 [Boot]
NTFS at 104044/34/55
filesystem size           921600
sectors_per_cluster       8
mft_lcn                   38400
mftmirr_lcn               2
clusters_per_mft_record   -10
     MS Data               1670547457 1671469056     921600
     NTFS found using backup sector, blocksize=4096, 471 MB / 450 MiB
mft_lcn                   38400
mftmirr_lcn               2
     MS Data               1671469056 1672390655     921600
     NTFS, blocksize=4096, 471 MB / 450 MiB
     Linux Swap            1699789080 1699789095         16
     SWAP2 version 0, pagesize=8192, 8192 B
recover_EXT2: s_block_group_nr=0/308, s_mnt_count=6/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
Last mount time:    Sat Nov 10 15:35:13 2018
     Linux filesys. data   1699898784 1780680095   80781312
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 41 GB / 38 GiB
SYSV4 Marker at 130235/230/4
recover_sysv4
     Unknown               2092239768 36128995265431 36126903025664 [Ž58÷„×]
     SysV4, 18496 TB / 16822 TiB
LVM magic value at 146637/62/42
LVM magic value at 146787/71/23
NTFS at 147045/151/50
filesystem size           125153280
mftmirr_lcn               2
     MS Data               2237134208 2362287487  125153280
     NTFS found using backup sector, blocksize=4096, 64 GB / 59 GiB
mftmirr_lcn               2
     MS Data               2362287487 2487440766  125153280
     NTFS, blocksize=4096, 64 GB / 59 GiB
LVM magic value at 155172/187/58
SYSV4 Marker at 158863/25/5
recover_sysv4
     Unknown               2552135674 26752412217 24200276544 [eRެ6]
     SysV4, 12 TB / 11 TiB
HFS magic value at 164132/74/39
part_size 2097154
     Mac HFS               2636785280 2638882433    2097154
     HFS blocksize=536870912, 1073 MB / 1024 MiB
HFS magic value at 166633/23/37
part_size 524290
     Mac HFS               2676960630 2677484919     524290
     HFS blocksize=2097152, 268 MB / 256 MiB
FAT12 at 176582/56/19
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     MS Data               2836793376 2836796255       2880 [NO NAME]
FAT12 at 176607/180/2
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            2837202796 2837205675       2880 [EFI System Partition] [EFISECTOR]
FAT12 at 176610/139/42
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            2837248448 2837251327       2880 [EFI System Partition] [EFISECTOR]
NTFS at 176611/56/54
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data               2837253123 2837259296       6174
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data               2837259296 2837265469       6174 [Boot]
FAT12 at 177041/147/47
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            2844172972 2844175851       2880 [EFI System Partition] [EFISECTOR]
FAT32 at 177346/227/34
FAT1 : 6622-7406
FAT2 : 7407-8191
Data : 8192-409599
sectors : 409600
cluster_size : 4
no_of_cluster : 100352 (2 - 100353)
fat_length 785 calculated 785
FAT differs, FAT sectors=0-16/785
FAT: cluster=2(0x2), pos=2849086016
FAT: cluster=3(0x3), pos=2849086020
FAT: cluster=4(0x4), pos=2849086024
FAT: cluster=5(0x5), pos=2849086028
FAT: cluster=6(0x6), pos=2849086032
FAT: cluster=7(0x7), pos=2849086036
FAT: cluster=8(0x8), pos=2849086040
FAT: cluster=9(0x9), pos=2849086044
FAT: cluster=10(0xa), pos=2849086048
FAT: cluster=11(0xb), pos=2849086052
FAT: cluster=12(0xc), pos=2849086056
FAT: cluster=13(0xd), pos=2849086060
FAT: cluster=14(0xe), pos=2849086064
FAT: cluster=15(0xf), pos=2849086068
FAT: cluster=16(0x10), pos=2849086072
FAT: cluster=17(0x11), pos=2849086076
FAT: cluster=18(0x12), pos=2849086080
FAT: cluster=19(0x13), pos=2849086084
FAT: cluster=20(0x14), pos=2849086088
FAT: cluster=21(0x15), pos=2849086092
FAT: cluster=22(0x16), pos=2849086096
FAT: cluster=23(0x17), pos=2849086100
FAT: cluster=24(0x18), pos=2849086104
FAT: cluster=25(0x19), pos=2849086108
FAT: cluster=26(0x1a), pos=2849086112
FAT: cluster=27(0x1b), pos=2849086116
FAT: cluster=28(0x1c), pos=2849086120
FAT: cluster=29(0x1d), pos=2849086124
FAT: cluster=30(0x1e), pos=2849086128
FAT: cluster=31(0x1f), pos=2849086132
FAT: cluster=32(0x20), pos=2849086136
FAT: cluster=33(0x21), pos=2849086140
FAT: cluster=34(0x22), pos=2849086144
FAT: cluster=35(0x23), pos=2849086148
FAT: cluster=36(0x24), pos=2849086152
FAT: cluster=37(0x25), pos=2849086156
FAT: cluster=38(0x26), pos=2849086160
FAT: cluster=39(0x27), pos=2849086164
FAT: cluster=40(0x28), pos=2849086168
FAT: cluster=41(0x29), pos=2849086172
FAT: cluster=42(0x2a), pos=2849086176
FAT: cluster=43(0x2b), pos=2849086180
FAT: cluster=44(0x2c), pos=2849086184
FAT: cluster=45(0x2d), pos=2849086188
FAT: cluster=46(0x2e), pos=2849086192
FAT: cluster=47(0x2f), pos=2849086196
FAT: cluster=48(0x30), pos=2849086200
FAT: cluster=49(0x31), pos=2849086204
FAT: cluster=50(0x32), pos=2849086208
FAT: cluster=51(0x33), pos=2849086212
FAT: cluster=52(0x34), pos=2849086216
FAT: cluster=53(0x35), pos=2849086220
FAT: cluster=54(0x36), pos=2849086224
FAT: cluster=55(0x37), pos=2849086228
FAT: cluster=56(0x38), pos=2849086232
FAT: cluster=57(0x39), pos=2849086236
FAT: cluster=58(0x3a), pos=2849086240
FAT: cluster=59(0x3b), pos=2849086244
FAT: cluster=60(0x3c), pos=2849086248
FAT: cluster=61(0x3d), pos=2849086252
FAT: cluster=62(0x3e), pos=2849086256
FAT: cluster=63(0x3f), pos=2849086260
FAT: cluster=64(0x40), pos=2849086264
FAT: cluster=65(0x41), pos=2849086268
FAT: cluster=66(0x42), pos=2849086272
FAT: cluster=67(0x43), pos=2849086276
FAT: cluster=68(0x44), pos=2849086280
FAT: cluster=69(0x45), pos=2849086284
FAT: cluster=70(0x46), pos=2849086288
FAT: cluster=71(0x47), pos=2849086292
FAT: cluster=72(0x48), pos=2849086296
FAT: cluster=73(0x49), pos=2849086300
FAT: cluster=74(0x4a), pos=2849086304
FAT: cluster=75(0x4b), pos=2849086308
FAT: cluster=76(0x4c), pos=2849086312
FAT: cluster=77(0x4d), pos=2849086316
FAT: cluster=78(0x4e), pos=2849086320
FAT: cluster=79(0x4f), pos=2849086324
FAT: cluster=80(0x50), pos=2849086328
FAT: cluster=81(0x51), pos=2849086332
FAT: cluster=82(0x52), pos=2849086336
FAT: cluster=83(0x53), pos=2849086340
FAT: cluster=84(0x54), pos=2849086344
FAT: cluster=85(0x55), pos=2849086348
FAT: cluster=86(0x56), pos=2849086352
FAT: cluster=87(0x57), pos=2849086356
FAT: cluster=88(0x58), pos=2849086360
FAT: cluster=89(0x59), pos=2849086364
FAT: cluster=90(0x5a), pos=2849086368
FAT: cluster=91(0x5b), pos=2849086372
FAT: cluster=92(0x5c), pos=2849086376
FAT: cluster=93(0x5d), pos=2849086380
FAT: cluster=94(0x5e), pos=2849086384
FAT: cluster=95(0x5f), pos=2849086388
FAT: cluster=96(0x60), pos=2849086392
FAT: cluster=97(0x61), pos=2849086396
FAT: cluster=98(0x62), pos=2849086400
FAT: cluster=99(0x63), pos=2849086404
FAT: cluster=100(0x64), pos=2849086408
FAT: cluster=101(0x65), pos=2849086412
FAT: cluster=102(0x66), pos=2849086416
FAT: cluster=103(0x67), pos=2849086420
FAT: cluster=104(0x68), pos=2849086424
FAT: cluster=105(0x69), pos=2849086428
FAT: cluster=106(0x6a), pos=2849086432
FAT: cluster=107(0x6b), pos=2849086436
FAT: cluster=108(0x6c), pos=2849086440
FAT: cluster=109(0x6d), pos=2849086444
FAT: cluster=110(0x6e), pos=2849086448
FAT: cluster=111(0x6f), pos=2849086452
FAT: cluster=112(0x70), pos=2849086456
FAT: cluster=113(0x71), pos=2849086460
FAT: cluster=114(0x72), pos=2849086464
FAT: cluster=115(0x73), pos=2849086468
FAT: cluster=116(0x74), pos=2849086472
FAT: cluster=117(0x75), pos=2849086476
FAT: cluster=118(0x76), pos=2849086480
FAT: cluster=119(0x77), pos=2849086484
FAT: cluster=120(0x78), pos=2849086488
FAT: cluster=121(0x79), pos=2849086492
FAT: cluster=122(0x7a), pos=2849086496
FAT: cluster=123(0x7b), pos=2849086500
FAT: cluster=124(0x7c), pos=2849086504
FAT: cluster=125(0x7d), pos=2849086508
FAT: cluster=126(0x7e), pos=2849086512
FAT: cluster=127(0x7f), pos=2849086516
FAT: cluster=128(0x80), pos=2849086520
FAT: cluster=129(0x81), pos=2849086524
FAT: cluster=130(0x82), pos=2849086528
FAT: cluster=131(0x83), pos=2849086532
FAT: cluster=132(0x84), pos=2849086536
FAT: cluster=133(0x85), pos=2849086540
FAT: cluster=134(0x86), pos=2849086544
FAT: cluster=135(0x87), pos=2849086548
FAT: cluster=136(0x88), pos=2849086552
FAT: cluster=137(0x89), pos=2849086556
FAT: cluster=138(0x8a), pos=2849086560
FAT: cluster=139(0x8b), pos=2849086564
FAT: cluster=140(0x8c), pos=2849086568
FAT: cluster=141(0x8d), pos=2849086572
FAT: cluster=142(0x8e), pos=2849086576
FAT: cluster=143(0x8f), pos=2849086580
FAT: cluster=144(0x90), pos=2849086584
FAT: cluster=145(0x91), pos=2849086588
FAT: cluster=146(0x92), pos=2849086592
FAT: cluster=147(0x93), pos=2849086596
FAT: cluster=148(0x94), pos=2849086600
FAT: cluster=149(0x95), pos=2849086604
FAT: cluster=150(0x96), pos=2849086608
FAT: cluster=151(0x97), pos=2849086612
FAT: cluster=152(0x98), pos=2849086616
FAT: cluster=153(0x99), pos=2849086620
FAT: cluster=154(0x9a), pos=2849086624
FAT: cluster=155(0x9b), pos=2849086628
FAT: cluster=156(0x9c), pos=2849086632
FAT: cluster=157(0x9d), pos=2849086636
FAT: cluster=158(0x9e), pos=2849086640
FAT: cluster=159(0x9f), pos=2849086644
FAT: cluster=160(0xa0), pos=2849086648
FAT: cluster=161(0xa1), pos=2849086652
FAT: cluster=162(0xa2), pos=2849086656
FAT: cluster=163(0xa3), pos=2849086660
FAT: cluster=164(0xa4), pos=2849086664
FAT: cluster=165(0xa5), pos=2849086668
FAT: cluster=166(0xa6), pos=2849086672
FAT: cluster=167(0xa7), pos=2849086676
FAT: cluster=168(0xa8), pos=2849086680
FAT: cluster=169(0xa9), pos=2849086684
FAT: cluster=170(0xaa), pos=2849086688
FAT: cluster=171(0xab), pos=2849086692
FAT: cluster=172(0xac), pos=2849086696
FAT: cluster=173(0xad), pos=2849086700
FAT: cluster=174(0xae), pos=2849086704
FAT: cluster=175(0xaf), pos=2849086708
FAT: cluster=176(0xb0), pos=2849086712
FAT: cluster=177(0xb1), pos=2849086716
FAT: cluster=178(0xb2), pos=2849086720
FAT: cluster=179(0xb3), pos=2849086724
FAT: cluster=180(0xb4), pos=2849086728
FAT: cluster=181(0xb5), pos=2849086732
FAT: cluster=182(0xb6), pos=2849086736
FAT: cluster=183(0xb7), pos=2849086740
FAT: cluster=184(0xb8), pos=2849086744
FAT: cluster=185(0xb9), pos=2849086748
FAT: cluster=186(0xba), pos=2849086752
FAT: cluster=187(0xbb), pos=2849086756
FAT: cluster=188(0xbc), pos=2849086760
FAT: cluster=189(0xbd), pos=2849086764
FAT: cluster=190(0xbe), pos=2849086768
FAT: cluster=191(0xbf), pos=2849086772
FAT: cluster=192(0xc0), pos=2849086776
FAT: cluster=193(0xc1), pos=2849086780
FAT: cluster=194(0xc2), pos=2849086784
FAT: cluster=195(0xc3), pos=2849086788
FAT: cluster=196(0xc4), pos=2849086792
FAT: cluster=197(0xc5), pos=2849086796
FAT: cluster=198(0xc6), pos=2849086800
FAT: cluster=199(0xc7), pos=2849086804
FAT: cluster=200(0xc8), pos=2849086808
FAT: cluster=201(0xc9), pos=2849086812
FAT: cluster=202(0xca), pos=2849086816
FAT: cluster=203(0xcb), pos=2849086820
FAT: cluster=204(0xcc), pos=2849086824
FAT: cluster=205(0xcd), pos=2849086828
FAT: cluster=206(0xce), pos=2849086832
FAT: cluster=207(0xcf), pos=2849086836
FAT: cluster=208(0xd0), pos=2849086840
FAT: cluster=209(0xd1), pos=2849086844
FAT: cluster=210(0xd2), pos=2849086848
FAT: cluster=211(0xd3), pos=2849086852
FAT: cluster=212(0xd4), pos=2849086856
FAT: cluster=213(0xd5), pos=2849086860
FAT: cluster=214(0xd6), pos=2849086864
FAT: cluster=215(0xd7), pos=2849086868
FAT: cluster=216(0xd8), pos=2849086872
FAT: cluster=217(0xd9), pos=2849086876
FAT: cluster=218(0xda), pos=2849086880
FAT: cluster=219(0xdb), pos=2849086884
FAT: cluster=220(0xdc), pos=2849086888
FAT: cluster=221(0xdd), pos=2849086892
FAT: cluster=222(0xde), pos=2849086896
FAT: cluster=223(0xdf), pos=2849086900
FAT: cluster=224(0xe0), pos=2849086904
FAT: cluster=225(0xe1), pos=2849086908
FAT: cluster=226(0xe2), pos=2849086912
FAT: cluster=227(0xe3), pos=2849086916
FAT: cluster=228(0xe4), pos=2849086920
FAT: cluster=229(0xe5), pos=2849086924
FAT: cluster=230(0xe6), pos=2849086928
FAT: cluster=231(0xe7), pos=2849086932
FAT: cluster=232(0xe8), pos=2849086936
FAT: cluster=233(0xe9), pos=2849086940
FAT: cluster=234(0xea), pos=2849086944
FAT: cluster=235(0xeb), pos=2849086948
FAT: cluster=236(0xec), pos=2849086952
FAT: cluster=237(0xed), pos=2849086956
FAT: cluster=238(0xee), pos=2849086960
FAT: cluster=239(0xef), pos=2849086964
FAT: cluster=240(0xf0), pos=2849086968
FAT: cluster=241(0xf1), pos=2849086972
FAT: cluster=242(0xf2), pos=2849086976
FAT: cluster=243(0xf3), pos=2849086980
FAT: cluster=244(0xf4), pos=2849086984
FAT: cluster=245(0xf5), pos=2849086988
FAT: cluster=246(0xf6), pos=2849086992
FAT: cluster=247(0xf7), pos=2849086996
FAT: cluster=248(0xf8), pos=2849087000
FAT: cluster=249(0xf9), pos=2849087004
FAT: cluster=250(0xfa), pos=2849087008
FAT: cluster=251(0xfb), pos=2849087012
FAT: cluster=252(0xfc), pos=2849087016
FAT: cluster=253(0xfd), pos=2849087020
FAT: cluster=254(0xfe), pos=2849087024
FAT: cluster=255(0xff), pos=2849087028
FAT: cluster=256(0x100), pos=2849087032
FAT: cluster=257(0x101), pos=2849087036
FAT: cluster=258(0x102), pos=2849087040
FAT: cluster=259(0x103), pos=2849087044
FAT: cluster=260(0x104), pos=2849087048
FAT: cluster=261(0x105), pos=2849087052
FAT: cluster=262(0x106), pos=2849087056
FAT: cluster=263(0x107), pos=2849087060
FAT: cluster=264(0x108), pos=2849087064
FAT: cluster=265(0x109), pos=2849087068
FAT: cluster=266(0x10a), pos=2849087072
FAT: cluster=267(0x10b), pos=2849087076
FAT: cluster=268(0x10c), pos=2849087080
FAT: cluster=269(0x10d), pos=2849087084
FAT: cluster=270(0x10e), pos=2849087088
FAT: cluster=271(0x10f), pos=2849087092
FAT: cluster=272(0x110), pos=2849087096
FAT: cluster=273(0x111), pos=2849087100
FAT: cluster=274(0x112), pos=2849087104
FAT: cluster=275(0x113), pos=2849087108
FAT: cluster=276(0x114), pos=2849087112
FAT: cluster=277(0x115), pos=2849087116
FAT: cluster=278(0x116), pos=2849087120
FAT: cluster=279(0x117), pos=2849087124
FAT: cluster=280(0x118), pos=2849087128
FAT: cluster=281(0x119), pos=2849087132
FAT: cluster=282(0x11a), pos=2849087136
FAT: cluster=283(0x11b), pos=2849087140
FAT: cluster=284(0x11c), pos=2849087144
FAT: cluster=285(0x11d), pos=2849087148
FAT: cluster=286(0x11e), pos=2849087152
FAT: cluster=287(0x11f), pos=2849087156
FAT: cluster=288(0x120), pos=2849087160
FAT: cluster=289(0x121), pos=2849087164
FAT: cluster=290(0x122), pos=2849087168
FAT: cluster=291(0x123), pos=2849087172
FAT: cluster=292(0x124), pos=2849087176
FAT: cluster=293(0x125), pos=2849087180
FAT: cluster=294(0x126), pos=2849087184
FAT: cluster=295(0x127), pos=2849087188
FAT: cluster=296(0x128), pos=2849087192
FAT: cluster=297(0x129), pos=2849087196
FAT: cluster=298(0x12a), pos=2849087200
FAT: cluster=299(0x12b), pos=2849087204
FAT: cluster=300(0x12c), pos=2849087208
FAT: cluster=301(0x12d), pos=2849087212
FAT: cluster=302(0x12e), pos=2849087216
FAT: cluster=303(0x12f), pos=2849087220
FAT: cluster=304(0x130), pos=2849087224
FAT: cluster=305(0x131), pos=2849087228
FAT: cluster=306(0x132), pos=2849087232
FAT: cluster=307(0x133), pos=2849087236
FAT: cluster=308(0x134), pos=2849087240
FAT: cluster=309(0x135), pos=2849087244
FAT: cluster=310(0x136), pos=2849087248
FAT: cluster=311(0x137), pos=2849087252
FAT: cluster=312(0x138), pos=2849087256
FAT: cluster=313(0x139), pos=2849087260
FAT: cluster=314(0x13a), pos=2849087264
FAT: cluster=315(0x13b), pos=2849087268
FAT: cluster=316(0x13c), pos=2849087272
FAT: cluster=317(0x13d), pos=2849087276
FAT: cluster=318(0x13e), pos=2849087280
FAT: cluster=319(0x13f), pos=2849087284
FAT: cluster=320(0x140), pos=2849087288
FAT: cluster=321(0x141), pos=2849087292
FAT: cluster=322(0x142), pos=2849087296
FAT: cluster=323(0x143), pos=2849087300
FAT: cluster=324(0x144), pos=2849087304
FAT: cluster=325(0x145), pos=2849087308
FAT: cluster=326(0x146), pos=2849087312
FAT: cluster=327(0x147), pos=2849087316
FAT: cluster=328(0x148), pos=2849087320
FAT: cluster=329(0x149), pos=2849087324
FAT: cluster=330(0x14a), pos=2849087328
FAT: cluster=331(0x14b), pos=2849087332
FAT: cluster=332(0x14c), pos=2849087336
FAT: cluster=333(0x14d), pos=2849087340
FAT: cluster=334(0x14e), pos=2849087344
FAT: cluster=335(0x14f), pos=2849087348
FAT: cluster=336(0x150), pos=2849087352
FAT: cluster=337(0x151), pos=2849087356
FAT: cluster=338(0x152), pos=2849087360
FAT: cluster=339(0x153), pos=2849087364
FAT: cluster=340(0x154), pos=2849087368
FAT: cluster=341(0x155), pos=2849087372
FAT: cluster=342(0x156), pos=2849087376
FAT: cluster=343(0x157), pos=2849087380
FAT: cluster=344(0x158), pos=2849087384
FAT: cluster=345(0x159), pos=2849087388
FAT: cluster=346(0x15a), pos=2849087392
FAT: cluster=347(0x15b), pos=2849087396
FAT: cluster=348(0x15c), pos=2849087400
FAT: cluster=349(0x15d), pos=2849087404
FAT: cluster=350(0x15e), pos=2849087408
FAT: cluster=351(0x15f), pos=2849087412
FAT: cluster=821(0x335), pos=2849089292
FAT: cluster=822(0x336), pos=2849089296
FAT: cluster=823(0x337), pos=2849089300
FAT: cluster=824(0x338), pos=2849089304
FAT: cluster=825(0x339), pos=2849089308
FAT: cluster=826(0x33a), pos=2849089312
FAT: cluster=827(0x33b), pos=2849089316
FAT: cluster=828(0x33c), pos=2849089320
FAT: cluster=829(0x33d), pos=2849089324
FAT: cluster=830(0x33e), pos=2849089328
FAT: cluster=831(0x33f), pos=2849089332
FAT: cluster=832(0x340), pos=2849089336
FAT: cluster=833(0x341), pos=2849089340
FAT: cluster=834(0x342), pos=2849089344
FAT: cluster=835(0x343), pos=2849089348
FAT: cluster=836(0x344), pos=2849089352
FAT: cluster=837(0x345), pos=2849089356
FAT: cluster=838(0x346), pos=2849089360
FAT: cluster=839(0x347), pos=2849089364
FAT: cluster=840(0x348), pos=2849089368
FAT: cluster=841(0x349), pos=2849089372
FAT: cluster=842(0x34a), pos=2849089376
FAT: cluster=843(0x34b), pos=2849089380
FAT: cluster=844(0x34c), pos=2849089384
FAT: cluster=845(0x34d), pos=2849089388
FAT: cluster=846(0x34e), pos=2849089392
FAT: cluster=847(0x34f), pos=2849089396
FAT: cluster=848(0x350), pos=2849089400
FAT: cluster=849(0x351), pos=2849089404
FAT: cluster=850(0x352), pos=2849089408
FAT: cluster=851(0x353), pos=2849089412
FAT: cluster=852(0x354), pos=2849089416
FAT: cluster=853(0x355), pos=2849089420
FAT: cluster=854(0x356), pos=2849089424
FAT: cluster=855(0x357), pos=2849089428
FAT: cluster=856(0x358), pos=2849089432
FAT: cluster=857(0x359), pos=2849089436
FAT: cluster=858(0x35a), pos=2849089440
FAT: cluster=859(0x35b), pos=2849089444
FAT: cluster=860(0x35c), pos=2849089448
FAT: cluster=861(0x35d), pos=2849089452
FAT: cluster=862(0x35e), pos=2849089456
FAT: cluster=863(0x35f), pos=2849089460
FAT: cluster=864(0x360), pos=2849089464
FAT: cluster=865(0x361), pos=2849089468
FAT: cluster=866(0x362), pos=2849089472
FAT: cluster=867(0x363), pos=2849089476
FAT: cluster=868(0x364), pos=2849089480
FAT: cluster=869(0x365), pos=2849089484
FAT: cluster=870(0x366), pos=2849089488
FAT: cluster=871(0x367), pos=2849089492
FAT: cluster=872(0x368), pos=2849089496
FAT: cluster=873(0x369), pos=2849089500
FAT: cluster=874(0x36a), pos=2849089504
FAT: cluster=875(0x36b), pos=2849089508
FAT: cluster=876(0x36c), pos=2849089512
FAT: cluster=877(0x36d), pos=2849089516
FAT: cluster=878(0x36e), pos=2849089520
FAT: cluster=879(0x36f), pos=2849089524
FAT: cluster=880(0x370), pos=2849089528
FAT: cluster=881(0x371), pos=2849089532
FAT: cluster=882(0x372), pos=2849089536
FAT: cluster=883(0x373), pos=2849089540
FAT: cluster=884(0x374), pos=2849089544
FAT: cluster=885(0x375), pos=2849089548
FAT: cluster=886(0x376), pos=2849089552
FAT: cluster=887(0x377), pos=2849089556
FAT: cluster=888(0x378), pos=2849089560
FAT: cluster=889(0x379), pos=2849089564
FAT: cluster=890(0x37a), pos=2849089568
FAT: cluster=891(0x37b), pos=2849089572
FAT: cluster=892(0x37c), pos=2849089576
FAT: cluster=893(0x37d), pos=2849089580
FAT: cluster=894(0x37e), pos=2849089584
FAT: cluster=895(0x37f), pos=2849089588
FAT: cluster=896(0x380), pos=2849089592
FAT: cluster=897(0x381), pos=2849089596
FAT: cluster=898(0x382), pos=2849089600
FAT: cluster=899(0x383), pos=2849089604
FAT: cluster=900(0x384), pos=2849089608
FAT: cluster=901(0x385), pos=2849089612
FAT: cluster=902(0x386), pos=2849089616
FAT: cluster=903(0x387), pos=2849089620
FAT: cluster=904(0x388), pos=2849089624
FAT: cluster=905(0x389), pos=2849089628
FAT: cluster=906(0x38a), pos=2849089632
FAT: cluster=907(0x38b), pos=2849089636
FAT: cluster=908(0x38c), pos=2849089640
FAT: cluster=909(0x38d), pos=2849089644
FAT: cluster=910(0x38e), pos=2849089648
FAT: cluster=911(0x38f), pos=2849089652
FAT: cluster=912(0x390), pos=2849089656
FAT: cluster=913(0x391), pos=2849089660
FAT: cluster=914(0x392), pos=2849089664
FAT: cluster=915(0x393), pos=2849089668
FAT: cluster=916(0x394), pos=2849089672
FAT: cluster=917(0x395), pos=2849089676
FAT: cluster=918(0x396), pos=2849089680
FAT: cluster=919(0x397), pos=2849089684
FAT: cluster=920(0x398), pos=2849089688
FAT: cluster=921(0x399), pos=2849089692
FAT: cluster=922(0x39a), pos=2849089696
FAT: cluster=923(0x39b), pos=2849089700
FAT: cluster=924(0x39c), pos=2849089704
FAT: cluster=925(0x39d), pos=2849089708
FAT: cluster=926(0x39e), pos=2849089712
FAT: cluster=927(0x39f), pos=2849089716
FAT: cluster=928(0x3a0), pos=2849089720
FAT: cluster=929(0x3a1), pos=2849089724
FAT: cluster=930(0x3a2), pos=2849089728
FAT: cluster=931(0x3a3), pos=2849089732
FAT: cluster=932(0x3a4), pos=2849089736
FAT: cluster=933(0x3a5), pos=2849089740
FAT: cluster=934(0x3a6), pos=2849089744
FAT: cluster=935(0x3a7), pos=2849089748
FAT: cluster=936(0x3a8), pos=2849089752
FAT: cluster=937(0x3a9), pos=2849089756
FAT: cluster=938(0x3aa), pos=2849089760
FAT: cluster=939(0x3ab), pos=2849089764
FAT: cluster=940(0x3ac), pos=2849089768
FAT: cluster=941(0x3ad), pos=2849089772
FAT: cluster=942(0x3ae), pos=2849089776
FAT: cluster=943(0x3af), pos=2849089780
FAT: cluster=944(0x3b0), pos=2849089784
FAT: cluster=945(0x3b1), pos=2849089788
FAT: cluster=946(0x3b2), pos=2849089792
FAT: cluster=947(0x3b3), pos=2849089796
FAT: cluster=948(0x3b4), pos=2849089800
FAT: cluster=949(0x3b5), pos=2849089804
FAT: cluster=950(0x3b6), pos=2849089808
FAT: cluster=951(0x3b7), pos=2849089812
FAT: cluster=952(0x3b8), pos=2849089816
FAT: cluster=953(0x3b9), pos=2849089820
FAT: cluster=954(0x3ba), pos=2849089824
FAT: cluster=955(0x3bb), pos=2849089828
FAT: cluster=956(0x3bc), pos=2849089832
FAT: cluster=957(0x3bd), pos=2849089836
FAT: cluster=958(0x3be), pos=2849089840
FAT: cluster=959(0x3bf), pos=2849089844
FAT: cluster=960(0x3c0), pos=2849089848
FAT: cluster=961(0x3c1), pos=2849089852
FAT: cluster=962(0x3c2), pos=2849089856
FAT: cluster=963(0x3c3), pos=2849089860
FAT: cluster=964(0x3c4), pos=2849089864
FAT: cluster=965(0x3c5), pos=2849089868
FAT: cluster=966(0x3c6), pos=2849089872
FAT: cluster=967(0x3c7), pos=2849089876
FAT: cluster=968(0x3c8), pos=2849089880
FAT: cluster=969(0x3c9), pos=2849089884
FAT: cluster=970(0x3ca), pos=2849089888
FAT: cluster=971(0x3cb), pos=2849089892
FAT: cluster=972(0x3cc), pos=2849089896
FAT: cluster=973(0x3cd), pos=2849089900
FAT: cluster=974(0x3ce), pos=2849089904
FAT: cluster=975(0x3cf), pos=2849089908
FAT: cluster=976(0x3d0), pos=2849089912
FAT: cluster=977(0x3d1), pos=2849089916
FAT: cluster=978(0x3d2), pos=2849089920
FAT: cluster=979(0x3d3), pos=2849089924
FAT: cluster=980(0x3d4), pos=2849089928
FAT: cluster=981(0x3d5), pos=2849089932
FAT: cluster=982(0x3d6), pos=2849089936
FAT: cluster=983(0x3d7), pos=2849089940
FAT: cluster=984(0x3d8), pos=2849089944
FAT: cluster=985(0x3d9), pos=2849089948
FAT: cluster=986(0x3da), pos=2849089952
FAT: cluster=987(0x3db), pos=2849089956
FAT: cluster=988(0x3dc), pos=2849089960
FAT: cluster=989(0x3dd), pos=2849089964
FAT: cluster=990(0x3de), pos=2849089968
FAT: cluster=991(0x3df), pos=2849089972
FAT: cluster=992(0x3e0), pos=2849089976
FAT: cluster=993(0x3e1), pos=2849089980
FAT: cluster=994(0x3e2), pos=2849089984
FAT: cluster=995(0x3e3), pos=2849089988
FAT: cluster=996(0x3e4), pos=2849089992
FAT: cluster=997(0x3e5), pos=2849089996
FAT: cluster=998(0x3e6), pos=2849090000
FAT: cluster=999(0x3e7), pos=2849090004
FAT: cluster=1000(0x3e8), pos=2849090008
FAT: cluster=1001(0x3e9), pos=2849090012
FAT: cluster=1002(0x3ea), pos=2849090016
FAT: cluster=1003(0x3eb), pos=2849090020
FAT: cluster=1004(0x3ec), pos=2849090024
FAT: cluster=1005(0x3ed), pos=2849090028
FAT: cluster=1006(0x3ee), pos=2849090032
FAT: cluster=1007(0x3ef), pos=2849090036
FAT: cluster=1008(0x3f0), pos=2849090040
FAT: cluster=1009(0x3f1), pos=2849090044
FAT: cluster=1010(0x3f2), pos=2849090048
FAT: cluster=1011(0x3f3), pos=2849090052
FAT: cluster=1012(0x3f4), pos=2849090056
FAT: cluster=1013(0x3f5), pos=2849090060
FAT: cluster=1014(0x3f6), pos=2849090064
FAT: cluster=1015(0x3f7), pos=2849090068
FAT: cluster=1016(0x3f8), pos=2849090072
FAT: cluster=1017(0x3f9), pos=2849090076
FAT: cluster=1018(0x3fa), pos=2849090080
FAT: cluster=1019(0x3fb), pos=2849090084
FAT: cluster=1020(0x3fc), pos=2849090088
FAT: cluster=1021(0x3fd), pos=2849090092
FAT: cluster=1022(0x3fe), pos=2849090096
FAT: cluster=1023(0x3ff), pos=2849090100
FAT: cluster=1024(0x400), pos=2849090104
FAT: cluster=1025(0x401), pos=2849090108
     MS Data               2849077824 2849487423     409600 [NO NAME]
     FAT32, blocksize=2048, 209 MB / 200 MiB
NTFS at 177392/70/23
mftmirr_lcn               2
     MS Data               2724653633 2849806912  125153280
mftmirr_lcn               2
     MS Data               2849806912 2974960191  125153280
     Unknown               3100005048 3594718103  494713056
     FATX, 253 GB / 235 GiB
LVM magic value at 195634/110/43
check_FAT: Unusual, only one FAT
FAT16 at 197828/254/43
FAT1 : 1-138
FAT2 : 1-138
start_rootdir : 139
Data : 140-141159
sectors : 141160
cluster_size : 4
no_of_cluster : 35255 (2 - 35256)
fat_length 138 calculated 138
heads/cylinder 16 (FAT) != 255 (HD)
     MS Data               3178122864 3178264023     141160
     FAT16, blocksize=2048, 72 MB / 68 MiB
FAT12 at 198039/51/41
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            3181499788 3181502667       2880 [EFI System Partition] [EFISECTOR]
FAT12 at 198039/97/23
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            3181502668 3181505547       2880 [EFI System Partition] [EFISECTOR]
block_group_nr 64418
recover_EXT2: part_offset problem
FAT12 at 203644/156/33
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            3271550720 3271553599       2880 [EFI System Partition] [EFISECTOR]
FAT12 at 203644/202/15
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            3271553600 3271556479       2880 [EFI System Partition] [EFISECTOR]
FAT12 at 204657/194/6
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            3287826932 3287829811       2880 [EFI System Partition] [EFISECTOR]
FAT12 at 204657/239/51
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     EFI System            3287829812 3287832691       2880 [EFI System Partition] [EFISECTOR]
LVM magic value at 217445/161/6
NTFS at 225518/99/22
heads/cylinder 47 (NTFS) != 255 (HD)
sect/track 36 (NTFS) != 63 (HD)
filesystem size           775862272
mftmirr_lcn               2
     MS Data               2847090657 3622952928  775862272
     NTFS found using backup sector, blocksize=4096, 397 GB / 369 GiB
mftmirr_lcn               2
     MS Data               3622952928 4398815199  775862272
     NTFS, blocksize=4096, 397 GB / 369 GiB
LVM magic value at 278120/253/22
HFS magic value at 282915/14/12
part_size 168034306
     Mac HFS               4545030368 4713064673  168034306
     HFS blocksize=67108864, 86 GB / 80 GiB
HFS magic value at 297524/28/38
part_size 2148007938
     Mac HFS               4779724861 6927732798 2148007938 [
     HFS blocksize=134217728, 1099 GB / 1024 GiB
     BeFS                  7053418769 5453856875762140 5453849822343372 [›Õõ>Š×ç!“sÞëñiJúj½G‹¼@ÔŽ¯`ô ]
     BeFS blocksize=256, 2792371 TB / 2539646 TiB
This partition ends after the disk limits. (start=7053418769, size=5453849822343372, end=5453856875762140, disk end=46879735808)
cramfs Marker at 485884/11/25
recover_cramfs
     Linux filesys. data   7805727177 7810007479    4280302 [žï‡-)$=1{{
ŒD]
     cramfs, 2191 MB / 2089 MiB
LVM magic value at 523816/55/53
block_group_nr 1
recover_EXT2: "e2fsck -b 3268592533 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=1/0, s_mnt_count=145/0, s_blocks_per_group=3268592533, s_inodes_per_group=117503883
recover_EXT2: part_size 2
Filesystem created: Thu Jan  1 00:03:20 1970
Last mount time:    Thu Apr 27 23:44:41 2045
     Linux filesys. data   1878340462 1878340463          2 [8]
     ext4 blocksize=1024 Sparse_SB Journal_dev Backup_SB, 1024 B
block_group_nr 1
     Linux filesys. data   1878340464 1878340465          2 [8]
LVM magic value at 524207/161/14
HFS magic value at 526706/176/23
part_size 4159700994
     Mac HFS               8461543000 12621243993 4159700994
     HFS blocksize=268435456, 2129 GB / 1983 GiB
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/308, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
     Linux filesys. data   12618569406 12699350717   80781312
recover_EXT2: s_block_group_nr=0/60, s_mnt_count=6/4294967295, s_blocks_per_group=8192, s_inodes_per_group=2048
recover_EXT2: s_blocks_count 498688
recover_EXT2: part_size 997376
Last mount time:    Sat Nov 10 15:35:15 2018
     Linux filesys. data   12878653600 12879650975     997376
     ext2 blocksize=1024 Large_file Sparse_SB, 510 MB / 487 MiB
LVM magic value at 810589/107/41
     Unknown               13099363427 32228760493780066 32228747394416640
     WBFS, 16501118 TB / 15007680 TiB
FAT32 at 815580/188/17
FAT1 : 32-858
FAT2 : 859-1685
start_rootdir : 1686 root cluster : 2
Data : 1686-847869
sectors : 847872
cluster_size : 8
no_of_cluster : 105773 (2 - 105774)
fat_length 827 calculated 827
FAT: cluster=2(0x2), pos=13102306246
     MS Data               13102304560 13103152431     847872 [NO NAME]
     FAT32, blocksize=4096, 434 MB / 414 MiB
SYSV4 Marker at 820629/86/16
recover_sysv4
     Unknown               13183410318 315073144461 301889734144 [÷¤*Uzç]
     SysV4, 154 TB / 140 TiB
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/308, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
     Linux filesys. data   13394407550 13475188861   80781312
recover_EXT2: s_block_group_nr=0/308, s_mnt_count=8/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
Last mount time:    Sat Nov 10 20:09:13 2018
     Linux filesys. data   13567662936 13648444247   80781312
cramfs Marker at 855671/62/4
recover_cramfs
     Linux filesys. data   13746358524 13752273638    5915114 [ËÔOü
‘ázµP÷O_]
     cramfs, 3028 MB / 2888 MiB
LVM magic value at 858881/45/7
LVM magic value at 861659/14/33
Last mount time:    Fri Nov  9 18:15:08 2018
     Linux filesys. data   13868703832 13869701207     997376
LVM magic value at 865835/126/36
recover_btrfs: part_size 26677055634145280
     Linux filesys. data   13961840367 26677069595985647 26677055634145280 []
     btrfs blocksize=2302966851 Backup superblock, 13658652 TB / 12422472 TiB
This partition ends after the disk limits. (start=13961840367, size=26677055634145280, end=26677069595985647, disk end=46879735808)
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/308, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
     Linux filesys. data   13960013398 14040794709   80781312
LVM magic value at 887105/228/21
Last mount time:    Fri Nov  9 18:15:06 2018
     Linux filesys. data   14305762320 14386543631   80781312
     Linux Swap            14508201480 14508201495         16
recover_EXT2: s_block_group_nr=0/308, s_mnt_count=11/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
I had to remove a bunch of the lines that look like this, in order to fit the log here: FAT: cluster=137(0x89), pos=2849086556
I also have an LSI RAID controller log but it was too large to post here.
#3 Post by recuperation »
Eeyikes wrote: 29 Aug 2022, 02:07 So, I added a fifth 6TB SATA drive to my existing non-encrypted, single-VD 4x6TB RAID 5.
Speaking to me in full words increase your recovery chances.
https://en.wikipedia.org/wiki/VD
I don't know the way your software is using the RAID array. Furthermore you don't waste any word on saying what structure existed on your RAID array before the incident.
MESSAGE:
Please use a different recovery software.
Eeyikes
#4 Post by Eeyikes »
Hi recuperation, thank you for your time in reviewing my posts.
recuperation wrote: 29 Aug 2022, 08:45
Sorry, "VD" is short for "Virtual Disk". The "drive" that is presented to the Operating System by the hardware RAID controller.
Eeyikes wrote: 29 Aug 2022, 02:07 I told the Dell H710 RAID controller to reconfigure to a larger size, as I've done in the past without issue.
But for some reason, ESXi 7.1 doesn't see a proper file system any longer. The VMFS6 datastore is showing up as a "0" file size.
Rather than having the hardware RAID controller split the space into multiple virtual disks, I used 100% of the space as a single RAID 5 volume.
The volume/Virtual Disk was presented to ESXi 7.1 as a bare hard drive.
I had ESXi 7.1 format this drive as VMFS6 and then I added 100% of it as a single datastore.
I used that datastore to hold a few Virtual Machine hard drives (VMDK's).
Eeyikes wrote: 29 Aug 2022, 02:07 So, I booted to Hirems Live CD and ran your cool TestDisk scan utility. But it looks like I'm out of luck? The results look like it cannot help.
MESSAGE:
Based on what I've mentioned so far, would you have any recommendations on software?
I previously tried VMFS Recovery™ by DiskInternals but it didn't find anything to recover.
#5 Post by recuperation »
Now I understand what you did!
I have no recommendation, unfortunately.
Honestly, I never heard about VMFS6 before and I have never seen ads where a recovery software claimed to support VMFS6.
If this observation fits reality I expect any professional help to be pretty expensive as your virtualizing software is supposed to be run in a professional environment with most likely daily backups. So I guess recovery requests for VMFS6 are therefore pretty rare and if a lab gets contacted for this kind of task it smells the despair factor and prices accordingly.
Eeyikes
#6 Post by Eeyikes »
recuperation wrote: 29 Aug 2022, 17:41 So I guess recovery requests for VMFS6 are therefore pretty rare and if a lab gets contacted for this kind of task it smells the despair factor and prices accordingly.
Hah, you're not kidding!
The quotes I received were all in the $10K-$15K range from Drive Savers and the other big and little names.
Unfortunately, this is my private storage and I messed with my backup of it at the wrong time. :roll:
I had hoped the TestDisk software would give me a better idea about what specifically was wrong.
Thanks again for your time!
