Hello. I have a 2TB Seagate OneTouch which has recently gone RAW and I can no longer access the data. I've run Testdisk Create-->Selected Drive-->Intel Partition-->Analyze and see the following:
Disk \\.\PhysicalDrive3 - 2000 GB / 1863 GiB - CHS 243201 255 63
1 P HPFS - NTFS 0 32 33 243201 78 13 3907026944
Bad relative sector.
When I run both Quick Search and Deeper Search, no partitions are found.
I've also run Advanced-->Boot and get this:
Bad: can't read exFAT boot record.
Backup boot record
exFAT OK
Sectors are not identical.
When I run Rebuild BS, Searching for FAT table gets to 99%, and it doesn't give me an option to list. I can upload the log file if needed.
Any help would be appreciated. Thanks.
Drive gone RAW
Re: Drive gone RAW
Did you use the "p"-key trying to look into the partition found?
Re: Drive gone RAW
Unfortunately it isn't giving me that option. This is what I get after Quick Search:
Keys A: add partition, L: load backup, Enter: to continue
If I select Continue I get this:
**EDIT**
Exact same result with Deeper Search
[ Quit ] [ Return ] >[Deeper Search]
**EDIT**
Re: Drive gone RAW
Could you post the logfile, please?
Re: Drive gone RAW
Here you go...
Sun Sep 4 12:52:32 2022
TestDisk 7.2-WIP, Data Recovery Utility, May 2022
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=999655637504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=990490132480
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000397795328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=1500299265024
Disk \\.\PhysicalDrive0 - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - WDC WD15EARS-00Z5B1, S/N:WD-WMAVU2900559, FW:80.00A80
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - CT1000MX500SSD1, S/N:1842E1D20747, FW:M3CR022
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1CH162, S/N:S1D6MJDQ, FW:CC44
Disk \\.\PhysicalDrive3 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate OneTouch HDD, S/N:00000000NABPC935, FW:1707
Disk \\.\PhysicalDrive3 - 2000 GB / 1863 GiB - Seagate OneTouch HDD
Analyse Disk \\.\PhysicalDrive3 - 2000 GB / 1863 GiB - CHS 243201 255 63
BAD_RS LBA=2048 16450559
file_win32_pread(620,16,buffer,2048(0/32/33)) read err: read after end of file
file_win32_pread(620,1,buffer,2049(0/32/34)) read err: read after end of file
file_win32_pread(620,16,buffer,2047(0/32/32)) read err: read after end of file
file_win32_pread(620,16,buffer,2049(0/32/34)) read err: read after end of file
file_win32_pread(620,16,buffer,2054(0/32/39)) read err: read after end of file
file_win32_pread(620,1,buffer,2054(0/32/39)) read err: read after end of file
Re: Drive gone RAW
If you left your drive within its original housing I have no additional hint for you other than trying other recovery software.
