Volume deletion and merge gone wrong
krustylicious
#1 Post by krustylicious »
Hi there,
I have a shucked 14tb drive, which at the time i didn't realise it was exfat. Anyho i had copied over about 2gb of data by the time i had realsed and i really wanted ntfs. So i split the volume into two. The resaultant volumes were named deletion and media v2. roughly 5 nad 7tb in size.
so the drive had
efi stuff
deletion
media v2
volumes with media v2 at the end of othe drive. I decided to delete the deletion volume and and expand backwards (which really is not a good idea). The opertations were done using niubi partition editor free 8.0.2. Npe, suggested the steps where a success. but the drive was not accessible and was showing as raw.
I tried testdrive, and under disk selection, it had selected efi gpt and the current partition structure it shows as
Disk \\.\PhysicalDrive2 - 14 TB / 12 TiB - ST14000NE0008-2RX103
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive2 - 14 TB / 12 TiB - CHS 1702132 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=27344764927 (expected 27344764927)
hdr_lba_start=34
hdr_lba_end=27344764894
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P EFI System                    40     409639     409600 [EFI System Partition]
 2 P MS Data                   409768 27344762879 27344353112 [Basic data partition]
which i assume would be the merged volumes
But if i go into intel/pc do a search it shows the old partitions prior to it being merged via npe
NTFS at 25/159/7
filesystem size           15105581825
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS             25 159  7 940304 154 11 15105581825 [deletion]
     NTFS, blocksize=4096, 7734 GB / 7202 GiB
NTFS at 940304/174/31
filesystem size           12238768128
mftmirr_lcn               2
     HPFS - NTFS          940304 174 31 1702132 195 15 12238768128 [Media V2]
     NTFS, blocksize=4096, 6266 GB / 5835 GiB
   * HPFS - NTFS             25 159  7 940304 174 30 15105583104 [deletion]
   P HPFS - NTFS          940304 174 31 1702132 195 15 12238768128 [Media V2]
 1 * HPFS - NTFS             25 159  7 940304 174 30 15105583104 [deletion]
 2 P HPFS - NTFS          940304 174 31 1702132 195 15 12238768128 [Media V2]
so if write the data to the mbr it shows up as
NTFS at 25/159/7
Error: size boot_sector 15105581825 > partition 4294967295
Invalid NTFS or exFAT boot
 1 * HPFS - NTFS             25 159  7 267374 248  9 4294967295
 2 P HPFS - NTFS          267349  89  4 534698 178  6 4294967295
Backup partition structure
partition_save
and windows now sees 2 2tb partitions and 8.9tb unallocated.
whats the best way to try and recover as much of the data?
Thanks very much in advance
update:
just realized the 2xtb partitions are due writing volumes >2tb to an mbr.
i'm doing a deep scan under the efi/gpt route and its picking up the two original volumes ..
would that the data could be recoverable
Re: Volume deletion and merge gone wrong
