TestDisk Doesn't Find The Broken Partition
mh4data
#1 Post by mh4data »
I made a backup of the 4TB external HDD, ran TestDisk Analyze Quick & Deeper.
There is no partition listed that matches the original ~3.7TB NTFS partition.
This problem originated because I was making a new LiveUSB, I ran fdisk -l, got my device list, then connected a storage device for the ISO, in that time the fdisk list changed my sdb around. Therefore 1.4MB of the ISO were written to the storage device itself until the feed was cut off. So I know that most of the data is still good, but I have a DD of death on the first 1.4MB on a 4TB external harddrive.
Is there any advice how to proceed if Deep Scan doesn't find the write partition? The largest partition found is under 1TB, and there are many results, but not even that many NTFS, which the partition was.
TestDisk.log attached:
Wed Oct 26 18:09:15 2022
OS: Linux, kernel 5.10.0-19-amd64 (#1 SMP Debian 5.10.149-2 (2022-10-21)) x86_64
Compiler: GCC 9.2
ext2fs lib: 1.46.2, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.1
Disk /dev/sda - 4000 GB / 3726 GiB - CHS 3815447 64 32, sector size=512 - Seagate OneTouch HDD, FW:0004
Disk /dev/sda - 4000 GB / 3726 GiB - Seagate OneTouch HDD
Analyse Disk /dev/sda - 4000 GB / 3726 GiB - CHS 3815447 64 32
BAD_RS LBA=588 2103294
check_part_i386 2 type EF: no test
2 P EFI (FAT-12/16/32) 0 18 13 1 44 12 2880
FAT12 at 0/18/13
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
heads/cylinder 2 (FAT) != 64 (HD)
sect/track 18 (FAT) != 32 (HD)
FAT12 at 0/18/13
FAT12 0 18 13 1 44 12 2880 [NO NAME]
Warning: the current number of heads per cylinder is 64 but the correct value may be 255.
L FAT12 0 18 13 1 44 12 2880 [NO NAME]
echo "0 2880 linear /dev/sda 588" | dmsetup create test0
SIGINT detected! TestDisk has been killed.
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=2366367 (expected 7814037166)
hdr_lba_start=64
hdr_lba_end=2366304
hdr_lba_table=2
hdr_entries=248
hdr_entsz=128
1 P MS Data 64 2366303 2366240 [ISOHybrid]
Warning: number of heads/cylinder mismatches 2 (FAT) != 64 (HD)
Warning: number of sectors per track mismatches 18 (FAT) != 32 (HD)
2 P MS Data 588 3467 2880 [ISOHybrid1] [NO NAME]
FAT12 at 0/18/13
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 0/18/13
MS Data 588 3467 2880 [NO NAME]
recover_EXT2: s_block_group_nr=0/15, s_mnt_count=1/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1936
recover_EXT2: s_blocks_count 123904
recover_EXT2: part_size 247808
Filesystem created: Mon Aug 24 14:19:48 2020
Last mount time: Mon Aug 24 14:19:48 2020
Linux filesys. data 189256448 189504255 247808 [pmOS_boot]
ext2 blocksize=1024 Large_file Sparse_SB, 126 MB / 121 MiB
recover_EXT2: s_block_group_nr=0/4, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=20000
recover_EXT2: s_blocks_count 153600
recover_EXT2: part_size 1228800
Linux filesys. data 189504256 190733055 1228800 [pmOS_root]
ext4 blocksize=4096 Large_file Sparse_SB, 629 MB / 600 MiB
LVM magic value at 96213/57/1
LVM2 magic value at 97030/42/18
part_size 0
Linux LVM 198718801 198718800 0
LVM2, 0 B
Partition not added.
FAT12 at 97857/24/9
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 97857/24/9
EFI System 200411912 200414791 2880 [EFI System Partition] [EFISECTOR]
NTFS at 97862/42/29
heads/cylinder 16 (NTFS) != 64 (HD)
sect/track 2 (NTFS) != 32 (HD)
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
MS Data 200416575 200422748 6174
NTFS at 97862/42/29
mft_lcn 2058
mftmirr_lcn 5162
MS Data 200422748 200428921 6174 [Boot]
FAT12 at 102850/20/25
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 210637464 210640343 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 102851/46/25
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 210640344 210643223 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 106848/18/17
check_FAT: Unusual media descriptor (0xf8!=0xf0)
FAT1 : 1-5
FAT2 : 6-10
start_rootdir : 11
Data : 43-1599
sectors : 1600
cluster_size : 1
no_of_cluster : 1557 (2 - 1558)
fat_length 5 calculated 5
heads/cylinder 1 (FAT) != 64 (HD)
sect/track 63 (FAT) != 32 (HD)
MS Data 218825296 218826895 1600 [NO NAME]
FAT12, blocksize=512, 819 KB / 800 KiB
FAT16 at 106924/54/21
FAT1 : 1-64
FAT2 : 65-128
start_rootdir : 129
Data : 161-131064
sectors : 131072
cluster_size : 8
no_of_cluster : 16363 (2 - 16364)
fat_length 64 calculated 64
heads/cylinder 16 (FAT) != 64 (HD)
MS Data 218982100 219113171 131072 [EFISYS]
FAT16, blocksize=4096, 67 MB / 64 MiB
FAT16 at 106989/2/5
FAT1 : 1-64
FAT2 : 65-128
start_rootdir : 129
Data : 161-131064
sectors : 131072
cluster_size : 8
FAT16 at 106989/2/5
MS Data 219113540 219244611 131072 [EFISYS]
NTFS at 113045/0/1
heads/cylinder 255 (NTFS) != 64 (HD)
sect/track 63 (NTFS) != 32 (HD)
filesystem size 997877760
mftmirr_lcn 2
NTFS part_offset=118536273920, part_size=510913413120, sector_size=512
NTFS at 113045/0/1
mftmirr_lcn 2
MS Data 231516160 1229393919 997877760
NTFS, blocksize=4096, 510 GB / 475 GiB
FAT12 at 627055/53/13
FAT1 : 1-5
FAT2 : 6-10
start_rootdir : 11
Data : 43-5662
sectors : 5664
cluster_size : 4
no_of_cluster : 1405 (2 - 1406)
EFI System 1284210348 1284216011 5664 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 2899 KB / 2832 KiB
FAT32 at 627118/41/19
Bad root_cluster
FAT12 at 627118/41/20
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT differs, FAT sectors=0-9/9
MS Data 1284338995 1284341874 2880 [NO NAME]
FAT12 at 630966/46/25
FAT1 : 1-5
FAT2 : 6-10
start_rootdir : 11
Data : 43-5662
sectors : 5664
cluster_size : 4
TRUNCATED
LVM magic value at 1781148/59/6
FAT12 at 1783089/21/9
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 3651766952 3651769831 2880 [EFI System Partition] [EFISECTOR]
FAT12 at 1783347/46/1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
EFI System 3652296128 3652299007 2880 [EFI System Partition] [EFISECTOR]
NTFS at 1785593/3/32
filesystem size 114315264
mftmirr_lcn 2
MS Data 3542579328 3656894591 114315264
NTFS found using backup sector, blocksize=4096, 58 GB / 54 GiB
mftmirr_lcn 2
MS Data 3656894591 3771209854 114315264
NTFS, blocksize=4096, 58 GB / 54 GiB
NTFS at 1786816/6/1
mft_lcn 2058
mftmirr_lcn 5162
MS Data 3659393187 3659399360 6174
NTFS at 1786816/6/1
mft_lcn 2058
mftmirr_lcn 5162
MS Data 3659399360 3659405533 6174 [Boot]
cramfs Marker at 1786841/12/26
recover_cramfs
Linux filesys. data 3659450777 3660822760 1371983 [GW��ث݊��(b�dS�]
cramfs, 702 MB / 669 MiB
cramfs Marker at 1786841/12/27
recover_cramfs
Linux filesys. data 3659450778 3660822761 1371983 [GW��ث݊��(b�dS�]
NTFS at 1786955/27/9
mft_lcn 2058
mftmirr_lcn 5162
MS Data 3659678539 3659684712 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 3659684712 3659690885 6174
NTFS at 1789880/4/25
mft_lcn 2058
mftmirr_lcn 5162
MS Data 3665668219 3665674392 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 3665674392 3665680565 6174
NTFS at 1789908/34/9
mft_lcn 2058
mftmirr_lcn 5162
MS Data 3665726507 3665732680 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 3665732680 3665738853 6174
HFS magic value at 1799074/61/16
part_size 252840
Mac HFS 3684505519 3684758358 252840 [dler3]
HFS blocksize=4096, 129 MB / 123 MiB
HFS magic value at 1799074/61/18
part_size 252840
Mac HFS 3684252683 3684505522 252840 [dler3]
HFS found using backup sector!, 129 MB / 123 MiB
LVM magic value at 1964579/28/26
LVM magic value at 2172759/31/17
SYSV4 Marker at 3244729/33/17
recover_sysv4
Unknown 6645206064 6645206063 0 [�A�Lo_]
SysV4, 0 B
NTFS at 1273778/5/1
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 1273781/6/17
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 1273784/8/1
mft_lcn 2058
mftmirr_lcn 5162
P MS Data 588 3467 2880 [NO NAME]
Linux filesys. data 189256446 189504253 247808 [pmOS_boot]
ext2 blocksize=1024 Large_file Sparse_SB Backup_SB, 126 MB / 121 MiB
Linux filesys. data 189504254 190733053 1228800 [pmOS_root]
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 629 MB / 600 MiB
Linux filesys. data 190032816 191261615 1228800 [pmOS_root]
ext4 blocksize=4096 Large_file Sparse_SB Recover, 629 MB / 600 MiB
Linux filesys. data 190053992 191282791 1228800 [pmOS_root]
P EFI System 200411912 200414791 2880 [EFI System Partition] [EFISECTOR]
P EFI System 210637464 210640343 2880 [EFI System Partition] [EFISECTOR]
P EFI System 210640344 210643223 2880 [EFI System Partition] [EFISECTOR]
P MS Data 218825296 218826895 1600 [NO NAME]
P MS Data 218982100 219113171 131072 [EFISYS]
P MS Data 219113540 219244611 131072 [EFISYS]
EFI System 232899724 232900363 640 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 327 KB / 320 KiB
MS Data 233032755 233035634 2880 [NO NAME]
EFI System 252988804 252989699 896 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 458 KB / 448 KiB
MS Data 253137915 253140794 2880 [NO NAME]
MS Data 261504332 261507211 2880 [NO NAME]
MS Data 307521340 307524219 2880 [BALDER10]
MS Data 307524190 307527069 2880 [BALDER10]
MS Data 307555636 307558515 2880 [BALDER10]
MS Data 307558486 307561365 2880 [BALDER10]
MS Data 316556736 316587455 30720 [UEFI]
FAT16, blocksize=2048, 15 MB / 15 MiB
Linux filesys. data 316587456 316595647 8192 [KNOPPIX-DATA]
ReiserFS 3.6 with non standard journal blocksize=4096, 4194 KB / 4096 KiB
Linux filesys. data 316587480 316595671 8192 [KNOPPIX-DATA]
ReiserFS 3.6 with non standard journal blocksize=4096, need recovery, 4194 KB / 4096 KiB
Linux filesys. data 316587512 316595703 8192 [KNOPPIX-DATA]
Linux filesys. data 316587536 316595727 8192 [KNOPPIX-DATA]
Linux filesys. data 316587560 316595751 8192 [KNOPPIX-DATA]
Linux filesys. data 316587584 316595775 8192 [KNOPPIX-DATA]
Linux filesys. data 316587616 316595807 8192 [KNOPPIX-DATA]
Linux filesys. data 316587640 316595831 8192 [KNOPPIX-DATA]
Linux filesys. data 316587664 316595855 8192 [KNOPPIX-DATA]
EFI System 328647436 328648907 1472 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 753 KB / 736 KiB
EFI System 328664900 328665539 640 [EFI System Partition] [NO NAME]
MS Data 328668571 328671450 2880 [NO NAME]
Mac HFS 330500820 332726799 2225980
HFS+ found using backup sector!, 1139 MB / 1086 MiB
EFI System 332405408 332406879 1472 [EFI System Partition] [NO NAME]
Mac HFS 332726796 334952775 2225980
HFS+ blocksize=2048, 1139 MB / 1086 MiB
EFI System 332727436 332733851 6416 [EFI System Partition] [EFI-LIVE]
FAT12, blocksize=2048, 3284 KB / 3208 KiB
MS Data 335373313 335374912 1600 [EFISYS]
Solaris /home 335374929 336969552 1594624
UFS2 blocksize=4096, 816 MB / 778 MiB
Solaris /home 335374993 336969616 1594624
Solaris /home 335375041 336969664 1594624
Solaris /home 335375105 336969728 1594624
MS Data 336708689 336710288 1600 [EFISYS]
MS Data 336969553 337043280 73728 [PFSENSE]
FAT32, blocksize=512, 37 MB / 36 MiB
MS Data 336969555 337043282 73728 [PFSENSE]
MS Data 442792448 443316735 524288 [boot]
FAT32, blocksize=512, 268 MB / 256 MiB
MS Data 442792454 443316741 524288 [pies of suc]
Linux filesys. data 452257024 468526335 16269312 [rootfs]
ext4 blocksize=4096 Large_file Sparse_SB, 8329 MB / 7944 MiB
Mac HFS 612046804 614272783 2225980
Mac HFS 614272780 616498759 2225980
HFS+ blocksize=2048 + Backup, 1139 MB / 1086 MiB
EFI System 614273420 614279835 6416 [EFI System Partition] [EFI-LIVE]
MS Data 616475439 616478318 2880 [NO NAME]
MS Data 616475459 616478338 2880 [NO NAME]
MS Data 616476247 616479126 2880 [NO NAME]
Mac HFS 616498756 618724735 2225980
Mac HFS 1058827486 1058860569 33084
HFS found using backup sector!, 16 MB / 16 MiB
Mac HFS 1058860566 1058893649 33084
HFS blocksize=2048, 16 MB / 16 MiB
P EFI System 1284210348 1284216011 5664 [EFI System Partition] [NO NAME]
P MS Data 1284338995 1284341874 2880 [NO NAME]
P EFI System 1292219864 1292225527 5664 [EFI System Partition] [NO NAME]
P MS Data 1292348551 1292351430 2880 [NO NAME]
P MS Data 1300142927 1300145806 2880 [NO NAME]
Linux filesys. data 1331467006 1347736317 16269312 [rootfs]
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 8329 MB / 7944 MiB
Linux filesys. data 1331467008 1347736319 16269312 [rootfs]
P MS Data 1364724763 1364727642 2880 [NO NAME]
P EFI System 1464354720 1464362655 7936 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 4063 KB / 3968 KiB
P EFI System 1556815020 1556878507 63488 [EFI System Partition] [PARABOLAISO]
FAT16, blocksize=2048, 32 MB / 31 MiB
P EFI System 1561796316 1561797787 1472 [EFI System Partition] [NO NAME]
P EFI System 1561813772 1561814411 640 [EFI System Partition] [NO NAME]
P MS Data 1561817443 1561820322 2880 [NO NAME]
P EFI System 1569605952 1569607423 1472 [EFI System Partition] [NO NAME]
MS Data 1811692984 1811695863 2880 [BALDER10]
MS Data 1811695834 1811698713 2880 [BALDER10]
P EFI System 1813152764 1813158843 6080 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 3112 KB / 3040 KiB
P EFI System 1817061976 1817062615 640 [EFI System Partition] [NO NAME]
P EFI System 1820713120 1820721055 7936 [EFI System Partition] [NO NAME]
Mac HFS 1951037027 3413339311 1462302285
HFS found using backup sector!, 748 GB / 697 GiB
EFI System 2036820380 2036821243 864 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 442 KB / 432 KiB
MS Data 2036830135 2036833014 2880 [NO NAME]
EFI System 2094478592 2096807167 2328576 [EFI System Partition] [TAILS]
FAT32, blocksize=4096, 1192 MB / 1137 MiB
MS Data 2094478598 2096807173 2328576 [Tails]
MS Data 2094478604 2096807179 2328576 [TAILS]
EFI System 2099045532 2099111067 65536 [EFI System Partition] [grub_uefi]
FAT12, blocksize=16384, 33 MB / 32 MiB
Linux filesys. data 2167227134 2183496445 16269312 [rootfs]
Linux filesys. data 2167227136 2183496447 16269312 [rootfs]
Linux filesys. data 2171713616 2187982927 16269312 [rootfs]
ext4 blocksize=4096 Large_file Sparse_SB Recover, 8329 MB / 7944 MiB
Linux filesys. data 2171743552 2188012863 16269312 [rootfs]
Linux filesys. data 2171748336 2188017647 16269312 [rootfs]
Linux filesys. data 2171766480 2188035791 16269312 [rootfs]
Linux filesys. data 2171766656 2188035967 16269312 [rootfs]
Linux filesys. data 2171787952 2188057263 16269312 [rootfs]
Linux filesys. data 2177043336 2238950504 61907169
LUKS 0 (Data size unknown), 31 GB / 29 GiB
EFI System 2184601988 2184602883 896 [EFI System Partition] [NO NAME]
MS Data 2184751099 2184753978 2880 [NO NAME]
EFI System 2229937984 2229940031 2048 [EFI System Partition] [EFI]
FAT12, blocksize=2048, 1048 KB / 1024 KiB
EFI System 2260985672 2260988551 2880 [EFI System Partition] [EFISECTOR]
MS Data 2260986447 2260992620 6174
MS Data 2260992620 2260998793 6174 [Boot]
EFI System 2444041792 2444043839 2048 [EFI System Partition] [EFI]
Mac HFS 2579013148 2581850155 2837008
HFS+ found using backup sector!, 1452 MB / 1385 MiB
Mac HFS 2581850152 2584687159 2837008
HFS+ blocksize=2048, 1452 MB / 1385 MiB
EFI System 2581850840 2581859175 8336 [EFI System Partition] [EFI-LIVE]
FAT12, blocksize=2048, 4268 KB / 4168 KiB
Mac HFS 2584060968 2586897975 2837008
MS Data 2586861219 2586864098 2880 [NO NAME]
MS Data 2586861239 2586864118 2880 [NO NAME]
MS Data 2586862015 2586864894 2880 [NO NAME]
Mac HFS 2586897972 2589734979 2837008
EFI System 2605308880 2605311759 2880 [EFI System Partition] [EFISECTOR]
EFI System 2606771424 2606774303 2880 [EFI System Partition] [EFISECTOR]
MS Data 2608691331 2608697504 6174
MS Data 2608697504 2608703677 6174 [Boot]
MS Data 2608697523 2608703696 6174
MS Data 2608703696 2608709869 6174 [Boot]
MS Data 2608703715 2608709888 6174
MS Data 2608709888 2608716061 6174 [Boot]
MS Data 2608709907 2608716080 6174
MS Data 2608716080 2608722253 6174 [Boot]
EFI System 3320440824 3320446007 5184 [EFI System Partition] [NO NAME]
FAT12, blocksize=2048, 2654 KB / 2592 KiB
MS Data 3320545275 3320548154 2880 [NO NAME]
MS Data 3406959359 3406965532 6174
MS Data 3406965532 3406971705 6174 [Boot]
EFI System 3407007560 3407010439 2880 [EFI System Partition] [EFISECTOR]
EFI System 3407010440 3407013319 2880 [EFI System Partition] [EFISECTOR]
Mac HFS 3413339308 4875641592 1462302285
HFS blocksize=33554432, 748 GB / 697 GiB
EFI System 3415778700 3415781579 2880 [EFI System Partition] [EFISECTOR]
MS Data 3415782883 3415789056 6174
MS Data 3415789056 3415795229 6174 [Boot]
EFI System 3423757048 3423759927 2880 [EFI System Partition] [EFISECTOR]
EFI System 3423759928 3423762807 2880 [EFI System Partition] [EFISECTOR]
EFI System 3426497784 3426502967 5184 [EFI System Partition] [NO NAME]
MS Data 3426602235 3426605114 2880 [NO NAME]
EFI System 3462121980 3462124859 2880 [EFI System Partition] [EFISECTOR]
MS Data 3462144319 3462150492 6174
MS Data 3462150492 3462156665 6174 [Boot]
EFI System 3462192460 3462195339 2880 [EFI System Partition] [EFISECTOR]
EFI System 3462195340 3462198219 2880 [EFI System Partition] [EFISECTOR]
MS Data 3525355521 3639670784 114315264
MS Data 3638007041 3639031040 1024000
NTFS found using backup sector, blocksize=4096, 524 MB / 500 MiB
MS Data 3638044137 3639068136 1024000
MS Data 3638646784 3639670783 1024000
MS Data 3639031040 3640055039 1024000
NTFS, blocksize=4096, 524 MB / 500 MiB
MS Data 3639068136 3640092135 1024000
MS Data 3639095219 3639101392 6174
MS Data 3639101392 3639107565 6174
MS Data 3639670783 3640694782 1024000
MS Data 3639670784 3753986047 114315264
Mac HFS 3642767523 3643020362 252840 [dler3]
Mac HFS 3643020359 3643273198 252840 [dler3]
Linux filesys. data 3659450777 3660822760 1371984 [GW��ث݊��(b�dS�]
Linux filesys. data 3659450778 3660822761 1371984 [GW��ث݊��(b�dS�]
echo "0 247808 linear /dev/sda 189256446" | dmsetup create test1
echo "0 247808 linear /dev/sda 189256448" | dmsetup create test2
echo "0 1228800 linear /dev/sda 189504254" | dmsetup create test3
echo "0 1228800 linear /dev/sda 189504256" | dmsetup create test4
echo "0 1228800 linear /dev/sda 190032816" | dmsetup create test5
echo "0 1228800 linear /dev/sda 190053992" | dmsetup create test6
echo "0 2880 linear /dev/sda 200411912" | dmsetup create test7
echo "0 6174 linear /dev/sda 200416575" | dmsetup create test8
echo "0 6174 linear /dev/sda 200422748" | dmsetup create test9
echo "0 2880 linear /dev/sda 210637464" | dmsetup create test10
echo "0 2880 linear /dev/sda 210640344" | dmsetup create test11
echo "0 1600 linear /dev/sda 218825296" | dmsetup create test12
echo "0 131072 linear /dev/sda 218982100" | dmsetup create test13
echo "0 131072 linear /dev/sda 219113540" | dmsetup create test14
echo "0 997877760 linear /dev/sda 231516160" | dmsetup create test15
echo "0 640 linear /dev/sda 232899724" | dmsetup create test16
echo "0 2880 linear /dev/sda 233032755" | dmsetup create test17
echo "0 896 linear /dev/sda 252988804" | dmsetup create test18
echo "0 2880 linear /dev/sda 253137915" | dmsetup create test19
echo "0 2880 linear /dev/sda 261504332" | dmsetup create test20
echo "0 2880 linear /dev/sda 307521340" | dmsetup create test21
echo "0 2880 linear /dev/sda 307524190" | dmsetup create test22
echo "0 2880 linear /dev/sda 307555636" | dmsetup create test23
echo "0 2880 linear /dev/sda 307558486" | dmsetup create test24
echo "0 30720 linear /dev/sda 316556736" | dmsetup create test25
echo "0 8192 linear /dev/sda 316587456" | dmsetup create test26
echo "0 8192 linear /dev/sda 316587480" | dmsetup create test27
echo "0 8192 linear /dev/sda 316587512" | dmsetup create test28
echo "0 8192 linear /dev/sda 316587536" | dmsetup create test29
echo "0 8192 linear /dev/sda 316587560" | dmsetup create test30
echo "0 8192 linear /dev/sda 316587584" | dmsetup create test31
echo "0 8192 linear /dev/sda 316587616" | dmsetup create test32
echo "0 8192 linear /dev/sda 316587640" | dmsetup create test33
echo "0 8192 linear /dev/sda 316587664" | dmsetup create test34
echo "0 1472 linear /dev/sda 328647436" | dmsetup create test35
echo "0 640 linear /dev/sda 328664900" | dmsetup create test36
echo "0 2880 linear /dev/sda 328668571" | dmsetup create test37
echo "0 2225980 linear /dev/sda 330500820" | dmsetup create test38
echo "0 1472 linear /dev/sda 332405408" | dmsetup create test39
echo "0 2225980 linear /dev/sda 332726796" | dmsetup create test40
echo "0 6416 linear /dev/sda 332727436" | dmsetup create test41
echo "0 1600 linear /dev/sda 335373313" | dmsetup create test42
echo "0 1594624 linear /dev/sda 335374929" | dmsetup create test43
echo "0 1594624 linear /dev/sda 335374993" | dmsetup create test44
echo "0 1594624 linear /dev/sda 335375041" | dmsetup create test45
echo "0 1594624 linear /dev/sda 335375105" | dmsetup create test46
echo "0 1600 linear /dev/sda 336708689" | dmsetup create test47
echo "0 73728 linear /dev/sda 336969553" | dmsetup create test48
echo "0 73728 linear /dev/sda 336969555" | dmsetup create test49
echo "0 524288 linear /dev/sda 442792448" | dmsetup create test50
echo "0 524288 linear /dev/sda 442792454" | dmsetup create test51
echo "0 16269312 linear /dev/sda 452257024" | dmsetup create test52
echo "0 2225980 linear /dev/sda 612046804" | dmsetup create test53
echo "0 2225980 linear /dev/sda 614272780" | dmsetup create test54
echo "0 6416 linear /dev/sda 614273420" | dmsetup create test55
echo "0 2880 linear /dev/sda 616475439" | dmsetup create test56
echo "0 2880 linear /dev/sda 616475459" | dmsetup create test57
echo "0 2880 linear /dev/sda 616476247" | dmsetup create test58
echo "0 2225980 linear /dev/sda 616498756" | dmsetup create test59
echo "0 33084 linear /dev/sda 1058827486" | dmsetup create test60
echo "0 33084 linear /dev/sda 1058860566" | dmsetup create test61
echo "0 5664 linear /dev/sda 1284210348" | dmsetup create test62
echo "0 2880 linear /dev/sda 1284338995" | dmsetup create test63
echo "0 5664 linear /dev/sda 1292219864" | dmsetup create test64
echo "0 2880 linear /dev/sda 1292348551" | dmsetup create test65
echo "0 2880 linear /dev/sda 1300142927" | dmsetup create test66
echo "0 16269312 linear /dev/sda 1331467006" | dmsetup create test67
echo "0 16269312 linear /dev/sda 1331467008" | dmsetup create test68
echo "0 2880 linear /dev/sda 1364724763" | dmsetup create test69
echo "0 7936 linear /dev/sda 1464354720" | dmsetup create test70
echo "0 63488 linear /dev/sda 1556815020" | dmsetup create test71
echo "0 1472 linear /dev/sda 1561796316" | dmsetup create test72
echo "0 640 linear /dev/sda 1561813772" | dmsetup create test73
echo "0 2880 linear /dev/sda 1561817443" | dmsetup create test74
echo "0 1472 linear /dev/sda 1569605952" | dmsetup create test75
echo "0 2880 linear /dev/sda 1811692984" | dmsetup create test76
echo "0 2880 linear /dev/sda 1811695834" | dmsetup create test77
echo "0 6080 linear /dev/sda 1813152764" | dmsetup create test78
echo "0 640 linear /dev/sda 1817061976" | dmsetup create test79
echo "0 7936 linear /dev/sda 1820713120" | dmsetup create test80
echo "0 1462302285 linear /dev/sda 1951037027" | dmsetup create test81
echo "0 864 linear /dev/sda 2036820380" | dmsetup create test82
echo "0 2880 linear /dev/sda 2036830135" | dmsetup create test83
echo "0 2328576 linear /dev/sda 2094478592" | dmsetup create test84
echo "0 2328576 linear /dev/sda 2094478598" | dmsetup create test85
echo "0 2328576 linear /dev/sda 2094478604" | dmsetup create test86
echo "0 65536 linear /dev/sda 2099045532" | dmsetup create test87
echo "0 16269312 linear /dev/sda 2167227134" | dmsetup create test88
echo "0 16269312 linear /dev/sda 2167227136" | dmsetup create test89
echo "0 16269312 linear /dev/sda 2171713616" | dmsetup create test90
echo "0 16269312 linear /dev/sda 2171743552" | dmsetup create test91
echo "0 16269312 linear /dev/sda 2171748336" | dmsetup create test92
echo "0 16269312 linear /dev/sda 2171766480" | dmsetup create test93
echo "0 16269312 linear /dev/sda 2171766656" | dmsetup create test94
echo "0 16269312 linear /dev/sda 2171787952" | dmsetup create test95
echo "0 61907169 linear /dev/sda 2177043336" | dmsetup create test96
echo "0 896 linear /dev/sda 2184601988" | dmsetup create test97
echo "0 2880 linear /dev/sda 2184751099" | dmsetup create test98
echo "0 2048 linear /dev/sda 2229937984" | dmsetup create test99
echo "0 2880 linear /dev/sda 2260985672" | dmsetup create test100
echo "0 6174 linear /dev/sda 2260986447" | dmsetup create test101
echo "0 6174 linear /dev/sda 2260992620" | dmsetup create test102
echo "0 2048 linear /dev/sda 2444041792" | dmsetup create test103
echo "0 2837008 linear /dev/sda 2579013148" | dmsetup create test104
echo "0 2837008 linear /dev/sda 2581850152" | dmsetup create test105
echo "0 8336 linear /dev/sda 2581850840" | dmsetup create test106
echo "0 2837008 linear /dev/sda 2584060968" | dmsetup create test107
echo "0 2880 linear /dev/sda 2586861219" | dmsetup create test108
echo "0 2880 linear /dev/sda 2586861239" | dmsetup create test109
echo "0 2880 linear /dev/sda 2586862015" | dmsetup create test110
echo "0 2837008 linear /dev/sda 2586897972" | dmsetup create test111
echo "0 2880 linear /dev/sda 2605308880" | dmsetup create test112
echo "0 2880 linear /dev/sda 2606771424" | dmsetup create test113
echo "0 6174 linear /dev/sda 2608691331" | dmsetup create test114
echo "0 6174 linear /dev/sda 2608697504" | dmsetup create test115
echo "0 6174 linear /dev/sda 2608697523" | dmsetup create test116
echo "0 6174 linear /dev/sda 2608703696" | dmsetup create test117
echo "0 6174 linear /dev/sda 2608703715" | dmsetup create test118
echo "0 6174 linear /dev/sda 2608709888" | dmsetup create test119
echo "0 6174 linear /dev/sda 2608709907" | dmsetup create test120
echo "0 6174 linear /dev/sda 2608716080" | dmsetup create test121
echo "0 5184 linear /dev/sda 3320440824" | dmsetup create test122
echo "0 2880 linear /dev/sda 3320545275" | dmsetup create test123
echo "0 6174 linear /dev/sda 3406959359" | dmsetup create test124
echo "0 6174 linear /dev/sda 3406965532" | dmsetup create test125
echo "0 2880 linear /dev/sda 3407007560" | dmsetup create test126
echo "0 2880 linear /dev/sda 3407010440" | dmsetup create test127
echo "0 1462302285 linear /dev/sda 3413339308" | dmsetup create test128
echo "0 2880 linear /dev/sda 3415778700" | dmsetup create test129
echo "0 6174 linear /dev/sda 3415782883" | dmsetup create test130
echo "0 6174 linear /dev/sda 3415789056" | dmsetup create test131
echo "0 2880 linear /dev/sda 3423757048" | dmsetup create test132
echo "0 2880 linear /dev/sda 3423759928" | dmsetup create test133
echo "0 5184 linear /dev/sda 3426497784" | dmsetup create test134
echo "0 2880 linear /dev/sda 3426602235" | dmsetup create test135
echo "0 2880 linear /dev/sda 3462121980" | dmsetup create test136
echo "0 6174 linear /dev/sda 3462144319" | dmsetup create test137
echo "0 6174 linear /dev/sda 3462150492" | dmsetup create test138
echo "0 2880 linear /dev/sda 3462192460" | dmsetup create test139
echo "0 2880 linear /dev/sda 3462195340" | dmsetup create test140
echo "0 114315264 linear /dev/sda 3525355521" | dmsetup create test141
echo "0 114315264 linear /dev/sda 3542579328" | dmsetup create test142
echo "0 1024000 linear /dev/sda 3638007041" | dmsetup create test143
echo "0 1024000 linear /dev/sda 3638044137" | dmsetup create test144
echo "0 1024000 linear /dev/sda 3638646784" | dmsetup create test145
echo "0 1024000 linear /dev/sda 3639031040" | dmsetup create test146
echo "0 1024000 linear /dev/sda 3639068136" | dmsetup create test147
echo "0 6174 linear /dev/sda 3639095219" | dmsetup create test148
echo "0 6174 linear /dev/sda 3639101392" | dmsetup create test149
echo "0 1024000 linear /dev/sda 3639670783" | dmsetup create test150
echo "0 114315264 linear /dev/sda 3639670784" | dmsetup create test151
echo "0 252840 linear /dev/sda 3642767523" | dmsetup create test152
echo "0 252840 linear /dev/sda 3643020359" | dmsetup create test153
echo "0 2880 linear /dev/sda 3651766952" | dmsetup create test154
echo "0 2880 linear /dev/sda 3652296128" | dmsetup create test155
echo "0 114315264 linear /dev/sda 3656894591" | dmsetup create test156
echo "0 6174 linear /dev/sda 3659393187" | dmsetup create test157
echo "0 6174 linear /dev/sda 3659399360" | dmsetup create test158
echo "0 1371984 linear /dev/sda 3659450777" | dmsetup create test159
echo "0 1371984 linear /dev/sda 3659450778" | dmsetup create test160
echo "0 6174 linear /dev/sda 3659678539" | dmsetup create test161
echo "0 6174 linear /dev/sda 3659684712" | dmsetup create test162
echo "0 6174 linear /dev/sda 3665668219" | dmsetup create test163
echo "0 6174 linear /dev/sda 3665674392" | dmsetup create test164
echo "0 6174 linear /dev/sda 3665726507" | dmsetup create test165
echo "0 6174 linear /dev/sda 3665732680" | dmsetup create test166
echo "0 252840 linear /dev/sda 3684252683" | dmsetup create test167
echo "0 252840 linear /dev/sda 3684505519" | dmsetup create test168
1 P MS Data 588 3467 2880 [NO NAME]
2 P EFI System 200411912 200414791 2880 [EFI System Partition] [EFISECTOR]
3 P EFI System 210637464 210640343 2880 [EFI System Partition] [EFISECTOR]
4 P EFI System 210640344 210643223 2880 [EFI System Partition] [EFISECTOR]
5 P MS Data 218825296 218826895 1600 [NO NAME]
6 P MS Data 218982100 219113171 131072 [EFISYS]
7 P MS Data 219113540 219244611 131072 [EFISYS]
8 P EFI System 1284210348 1284216011 5664 [EFI System Partition] [NO NAME]
9 P MS Data 1284338995 1284341874 2880 [NO NAME]
10 P EFI System 1292219864 1292225527 5664 [EFI System Partition] [NO NAME]
11 P MS Data 1292348551 1292351430 2880 [NO NAME]
12 P MS Data 1300142927 1300145806 2880 [NO NAME]
13 P MS Data 1364724763 1364727642 2880 [NO NAME]
14 P EFI System 1464354720 1464362655 7936 [EFI System Partition] [NO NAME]
15 P EFI System 1556815020 1556878507 63488 [EFI System Partition] [PARABOLAISO]
16 P EFI System 1561796316 1561797787 1472 [EFI System Partition] [NO NAME]
17 P EFI System 1561813772 1561814411 640 [EFI System Partition] [NO NAME]
18 P MS Data 1561817443 1561820322 2880 [NO NAME]
19 P EFI System 1569605952 1569607423 1472 [EFI System Partition] [NO NAME]
20 P EFI System 1813152764 1813158843 6080 [EFI System Partition] [NO NAME]
21 P EFI System 1817061976 1817062615 640 [EFI System Partition] [NO NAME]
22 P EFI System 1820713120 1820721055 7936 [EFI System Partition] [NO NAME]
New options :
Dump : No
Align partition: Yes
Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=64
hdr_lba_end=2366304
hdr_lba_table=2
hdr_entries=248
hdr_entsz=128
Re: TestDisk Doesn't Find The Broken Partition
Please correct the size figures on the first two lines of your posting to avoid confusing other readers!
Did you remove the disk from its enclosure?
If yes, put it back in and rerun Testdisk (the drive should be in its initial setting).
If that does not yield a result you can
1. Run Photorec
2. Run any other recovery software that will deal with the remains of metadata on your former NTFS partition
For the advanced user (no support here)
3. a) Buy the same Seagate disk again and backup it's partition structure using Testdisk,
b) find out the sector size of the disk at the interface
c) build a new partition table according to the information from 3. a)
d) enter the partition data of the new Seagate disk into the old one
e) check if that improves your chances running 1. or 2.
mh4data
#3 Post by mh4data »
recuperation wrote: 28 Oct 2022, 21:09 Please correct the size figures on the first two lines of your posting to avoid confusing other readers!
1. Run Photorec
Hi and thanks for the reply. I left the desired HDD in the original enclosure. I also purchased a larger internal drive to save $30, so a perfect new partition data is a very interesting idea but not possible for me.
So I ran my old version of miniTool Partition Data Recovery for days and ended up with hundreds of thousands of unnamed files. The raw file data recovery is sort of useless when trying to navigate and find the desired pdf, mp4, mp3.
Would PhotoRec do a better job of raw file data recovery?
I wonder if an upgrade miniTool recovery software would handle it better, or if You might suggest a better software?
I suppose TestDisk could handle ext4 better than NTFS for the future.
I used to work in IT for many years but currently working elsewhere and don't have much time.
Thank You Again!
mh4data wrote: 14 Nov 2022, 15:28
1. Run Photorec
Please try it out if PhotoRec does better. Results may vary depending on the file type and the use of knowledge about the internals of file types.
The search principle of Photorec typically does not allow recovery of file names and folder structures.
As I am lacking the experience and haven't read a qualified test of recovery software I can't tell.
Testdisk uses external libraries for each file system as far as I remember. This question is too general anyway.
