what is the proper way to access a partition directly in testdisk?
Kyopsis23
#1 Post by Kyopsis23 »
long story short, I did a deep search (which took nearly 30 hours) and found the files I was looking for, but had a pc crash before I could finish recovering all my files and I really dont want to wait another 30 hours for the deep scan to finish
if I understand it correctly, I can add a partition manually, but this is where I am a bit unsure of what to do here
I see I need to enter the starting and ending cylinder, head, and sector, but the order of the numbers confuses me, I took a screenshot (also have info from log)
any helps appreciated
https://ibb.co/YBq3nNm
Re: what is the proper way to access a partition directly in testdisk?
Please post your Testdisk log file.
Uploading a full picture to this site provides more information than posting a cut of a screenshot.
Kyopsis23
#3 Post by Kyopsis23 »
attached
testdisk.log
(3.37 KiB) Downloaded 859 times
If you used that drive without any sector size manipulating enclosure you must have selected GPT when partitioning. Otherwise you would have been able to access only 2 TB out of 8 TB.
You ran Testdisk in MBR mode which appears to be wrong.
After the quick search you may enter the data of your lost partition.
