lost volume of my partition and data
noorasim
#1 Post by noorasim »
Hello every one! Need quick help from you guys.
I had 1tb hdd installed on my laptop, I added a 512gb ssd. I used the window boot from ssd and formated the c drive of hdd. Later when I was coping the data from harddrive to ssd mistakenly I deleted the volume of hdd which resulted in 833gb drive ( d+e drive got merged) along with formated c drive. I tried running test disk to recover both the partitions and the data but I couldnot find the data. Eventually I deleted the c volume and the hdd became a single drive with no partitions. I again tried test disk but it didn't helped. I also used a licensed version of Easeus recovery software but not working. Can any one help me how to get the data if not partitions. Thank you.
