Bad BS repair
JW1977
Bad BS repair
#1 Post by JW1977 »
Hi!
I accidentally started formatting an external drive. After a second or so i ripped the cord out.
The diskmanager now shows the disk as RAW.
Testdisk can find a FAT 16 partition but it states BAD Boot sector.
I choose to rebuild the BS. After several hours i got the question if a directory was found. My options where Yes, no, Quit, Abort interactive mode.
There was a list of some kind with strange dates in it. I was not sure so i choose to abort.
Unfortunately i havent got the posibility to save the picture online so i cant post it here.
Can someone please guide me?
Re: Bad BS repair
Please post a Testdisk log file.
7. What is the size of your disk?
8. Who is the maker of your failed drive?
9. What is the model?
13. How many partitions have been on the broken drive, what was their size, what was their file system?
JW1977
Re: Bad BS repair
#3 Post by JW1977 »
7. I think its a 1TB drive.
8. Buffalo
9. Buffalo Ministation HD-PCTU3
13. It was just one. Cant remember the filesystem but i would suspect it was NTFS
Mon Dec 26 13:45:28 2022
TestDisk 7.2-WIP, Data Recovery Utility, November 2022
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249446338560
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202043392
Disk \\.\PhysicalDrive0 - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 970 EVO 250GB, S/N:0025_3858_81B1_C3A5., FW:1B2QEXE7
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - BUFFALO HD-PCTU3, S/N:B311000874, FW:0001
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - BUFFALO HD-PCTU3
Analyse Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63
test_FAT()
1 P FAT16 >32M 0 32 33 121601 25 24 1953519616
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
Re: Bad BS repair
Here are step by step instructions:
If trying to list your files using the "p"-key fails even upon deep search, use another (commercial) recovery software or use Photorec.
