Samsung Micro SD 128gb corrupted
Nemo1985
#1 Post by Nemo1985 »
Hello, today after rebooting the phone it complained about the microsd being corrupted and asked for a format to use it again.
I obviously refused, then put with an adapter on my pc and executed a chkdsk with /f switch.
It said some errors got corrected (and several found.00x directory were created), I tried to open some recovered files with notepad++ to understand what they could have been.
All of them were 128kb files except one which was 256kb, some text was included but I decided to delete them all.
It was a huge mistake, while deleting the file I got the device not ready error.
I took off the adapter and put it again in the pc.
The disk was unreadable and asked for format, which I obviously refused.
With testdisk it says the partition is ntfs (while it was an exfat partition), both the primary and backup boot sector are marked bad.
Tue Dec 13 15:57:43 2022
TestDisk 7.2-WIP, Data Recovery Utility, November 2022
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1024209543168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=128043712512
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=8000976715776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1023531810816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=8000957841408
filewin32_getfilesize(\\.\E:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Funzione non corretta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=128026935296
Disk \\.\PhysicalDrive0 - 1024 GB / 953 GiB - CHS 124519 255 63, sector size=512 - Sabrent, S/N:6479_A729_5128_3131., FW:RKT303.2
Disk \\.\PhysicalDrive1 - 128 GB / 119 GiB - CHS 15567 255 63, sector size=512 - USB 2.0 SD/MMC Reader, S/N:835544140307
Disk \\.\PhysicalDrive2 - 8000 GB / 7451 GiB - CHS 972730 255 63, sector size=512 - AMD-RAID Array 1, S/N:00000dee275fc646, FW:9.3
Disk \\.\PhysicalDrive1 - 128 GB / 119 GiB - USB 2.0 SD/MMC Reader
 1 P HPFS - NTFS              2  10  9 15567  24  9  250052608
ntfs_boot_sector
filesystem size           1 0
sectors_per_cluster       0 255
mft_lcn                   0 18446744073709551615
mftmirr_lcn               0 18446744073709551615
clusters_per_mft_record   0 -1
clusters_per_index_record 0 -1
Status: Bad
Status: Bad
Sectors are not identical.
I've made a copy of the card with the option, here is also the log of the operation executed before the corruption:
Microsoft Windows [Versione 10.0.19045.2251]
(c) Microsoft Corporation. Tutti i diritti sono riservati.
C:\Users\Nemo>chkdsk h: /f
Il file system è di tipo exFAT.
Numero di serie del volume: 0000-0000
Verifica dei file e delle cartelle in corso...
È stato rilevato un errore durante l'analisi della mappa di bit del volume.
Verifica dei file e delle cartelle completata.
Correzioni apportate al file system.
Non sono necessarie ulteriori azioni.
 125009920 KB di spazio totale su disco.
  68152960 KB in 59833 file.
     85632 KB in 612 indici.
         0 KB in settori danneggiati.
       256 KB in uso dal sistema.
  56771072 KB disponibili su disco.
    131072 byte in ogni unità di allocazione.
    976640 unità totali di allocazione su disco.
    443524 unità di allocazione disponibili su disco.
C:\Users\Nemo>h:
H:\>cd FOUND.000
H:\FOUND.000>dir
 Il volume nell'unità H non ha etichetta.
 Directory di H:\FOUND.000
07/10/2022  17:09           131.072 FILE0000.CHK
07/10/2022  17:09           131.072 FILE0001.CHK
07/10/2022  17:09           131.072 FILE0002.CHK
07/10/2022  17:09           131.072 FILE0003.CHK
07/10/2022  17:09           131.072 FILE0004.CHK
07/10/2022  17:09           262.144 FILE0005.CHK
07/10/2022  17:09           131.072 FILE0006.CHK
07/10/2022  17:09           131.072 FILE0007.CHK
07/10/2022  17:09           262.144 FILE0008.CHK
07/10/2022  17:09           262.144 FILE0009.CHK
07/10/2022  17:09           262.144 FILE0010.CHK
07/10/2022  17:09           262.144 FILE0011.CHK
07/10/2022  17:09           131.072 FILE0012.CHK
07/10/2022  17:09           131.072 FILE0013.CHK
07/10/2022  17:09           131.072 FILE0014.CHK
07/10/2022  17:09           524.288 FILE0015.CHK
07/10/2022  17:09           262.144 FILE0016.CHK
07/10/2022  17:09           131.072 FILE0017.CHK
07/10/2022  17:09           131.072 FILE0018.CHK
07/10/2022  17:09           262.144 FILE0019.CHK
07/10/2022  17:09           262.144 FILE0020.CHK
07/10/2022  17:09           262.144 FILE0021.CHK
07/10/2022  17:09           131.072 FILE0022.CHK
07/10/2022  17:09           393.216 FILE0023.CHK
07/10/2022  17:09           262.144 FILE0024.CHK
07/10/2022  17:09           262.144 FILE0025.CHK
07/10/2022  17:09           262.144 FILE0026.CHK
07/10/2022  17:09           262.144 FILE0027.CHK
07/10/2022  17:09           131.072 FILE0028.CHK
07/10/2022  17:09           262.144 FILE0029.CHK
07/10/2022  17:09           131.072 FILE0030.CHK
07/10/2022  17:09           131.072 FILE0031.CHK
07/10/2022  17:09           262.144 FILE0032.CHK
07/10/2022  17:09           262.144 FILE0033.CHK
07/10/2022  17:09           262.144 FILE0034.CHK
07/10/2022  17:09           262.144 FILE0035.CHK
07/10/2022  17:09           262.144 FILE0036.CHK
07/10/2022  17:09           262.144 FILE0037.CHK
07/10/2022  17:09           262.144 FILE0038.CHK
07/10/2022  17:09           131.072 FILE0039.CHK
07/10/2022  17:09           131.072 FILE0040.CHK
07/10/2022  17:09           262.144 FILE0041.CHK
07/10/2022  17:09           131.072 FILE0042.CHK
07/10/2022  17:09           131.072 FILE0043.CHK
07/10/2022  17:09           131.072 FILE0044.CHK
07/10/2022  17:09           262.144 FILE0045.CHK
07/10/2022  17:09           262.144 FILE0046.CHK
07/10/2022  17:09           262.144 FILE0047.CHK
07/10/2022  17:09           262.144 FILE0048.CHK
07/10/2022  17:09           131.072 FILE0049.CHK
07/10/2022  17:09           262.144 FILE0050.CHK
07/10/2022  17:09           262.144 FILE0051.CHK
07/10/2022  17:09           131.072 FILE0052.CHK
07/10/2022  17:09           131.072 FILE0053.CHK
07/10/2022  17:09           131.072 FILE0054.CHK
07/10/2022  17:09           131.072 FILE0055.CHK
07/10/2022  17:09           131.072 FILE0056.CHK
07/10/2022  17:09           262.144 FILE0057.CHK
07/10/2022  17:09           131.072 FILE0058.CHK
07/10/2022  17:09           131.072 FILE0059.CHK
07/10/2022  17:09           131.072 FILE0060.CHK
07/10/2022  17:09           131.072 FILE0061.CHK
07/10/2022  17:09           131.072 FILE0062.CHK
07/10/2022  17:09           131.072 FILE0063.CHK
07/10/2022  17:09           131.072 FILE0064.CHK
07/10/2022  17:09           131.072 FILE0065.CHK
07/10/2022  17:09           131.072 FILE0066.CHK
07/10/2022  17:09           131.072 FILE0067.CHK
07/10/2022  17:09           262.144 FILE0068.CHK
07/10/2022  17:09           131.072 FILE0069.CHK
07/10/2022  17:09           131.072 FILE0070.CHK
07/10/2022  17:09           131.072 FILE0071.CHK
07/10/2022  17:09           131.072 FILE0072.CHK
07/10/2022  17:09           131.072 FILE0073.CHK
07/10/2022  17:09           131.072 FILE0074.CHK
07/10/2022  17:09           131.072 FILE0075.CHK
07/10/2022  17:09           131.072 FILE0076.CHK
07/10/2022  17:09           131.072 FILE0077.CHK
07/10/2022  17:09           131.072 FILE0078.CHK
07/10/2022  17:09           131.072 FILE0079.CHK
07/10/2022  17:09           262.144 FILE0080.CHK
07/10/2022  17:09           131.072 FILE0081.CHK
07/10/2022  17:09           131.072 FILE0082.CHK
07/10/2022  17:09           131.072 FILE0083.CHK
07/10/2022  17:09           131.072 FILE0084.CHK
07/10/2022  17:09           131.072 FILE0085.CHK
07/10/2022  17:09           131.072 FILE0086.CHK
07/10/2022  17:09           131.072 FILE0087.CHK
07/10/2022  17:09           131.072 FILE0088.CHK
07/10/2022  17:09           131.072 FILE0089.CHK
07/10/2022  17:09           262.144 FILE0090.CHK
07/10/2022  17:09           131.072 FILE0091.CHK
07/10/2022  17:09           131.072 FILE0092.CHK
07/10/2022  17:09           131.072 FILE0093.CHK
07/10/2022  17:09           131.072 FILE0094.CHK
07/10/2022  17:09           131.072 FILE0095.CHK
07/10/2022  17:09           131.072 FILE0096.CHK
07/10/2022  17:09           131.072 FILE0097.CHK
07/10/2022  17:09           131.072 FILE0098.CHK
07/10/2022  17:09           262.144 FILE0099.CHK
07/10/2022  17:09           131.072 FILE0100.CHK
07/10/2022  17:09           131.072 FILE0101.CHK
07/10/2022  17:09           131.072 FILE0102.CHK
07/10/2022  17:09           131.072 FILE0103.CHK
07/10/2022  17:09           131.072 FILE0104.CHK
07/10/2022  17:09           131.072 FILE0105.CHK
07/10/2022  17:09           131.072 FILE0106.CHK
07/10/2022  17:09           262.144 FILE0107.CHK
07/10/2022  17:09           131.072 FILE0108.CHK
07/10/2022  17:09           131.072 FILE0109.CHK
07/10/2022  17:09           262.144 FILE0110.CHK
07/10/2022  17:09           131.072 FILE0111.CHK
07/10/2022  17:09           262.144 FILE0112.CHK
07/10/2022  17:09           262.144 FILE0113.CHK
07/10/2022  17:09           131.072 FILE0114.CHK
07/10/2022  17:09           131.072 FILE0115.CHK
07/10/2022  17:09           131.072 FILE0116.CHK
07/10/2022  17:09           131.072 FILE0117.CHK
07/10/2022  17:09           131.072 FILE0118.CHK
07/10/2022  17:09           131.072 FILE0119.CHK
07/10/2022  17:09           262.144 FILE0120.CHK
07/10/2022  17:09           262.144 FILE0121.CHK
07/10/2022  17:09           262.144 FILE0122.CHK
07/10/2022  17:09           131.072 FILE0123.CHK
07/10/2022  17:09           262.144 FILE0124.CHK
07/10/2022  17:09           262.144 FILE0125.CHK
07/10/2022  17:09           131.072 FILE0126.CHK
07/10/2022  17:09           262.144 FILE0127.CHK
07/10/2022  17:09           131.072 FILE0128.CHK
07/10/2022  17:09           131.072 FILE0129.CHK
07/10/2022  17:09           262.144 FILE0130.CHK
07/10/2022  17:09           131.072 FILE0131.CHK
07/10/2022  17:09           131.072 FILE0132.CHK
07/10/2022  17:09           131.072 FILE0133.CHK
07/10/2022  17:09           131.072 FILE0134.CHK
07/10/2022  17:09           262.144 FILE0135.CHK
07/10/2022  17:09           131.072 FILE0136.CHK
07/10/2022  17:09           131.072 FILE0137.CHK
07/10/2022  17:09           131.072 FILE0138.CHK
07/10/2022  17:09           131.072 FILE0139.CHK
07/10/2022  17:09           131.072 FILE0140.CHK
07/10/2022  17:09           131.072 FILE0141.CHK
07/10/2022  17:09           262.144 FILE0142.CHK
07/10/2022  17:09           262.144 FILE0143.CHK
07/10/2022  17:09           262.144 FILE0144.CHK
07/10/2022  17:09           655.360 FILE0145.CHK
07/10/2022  17:09           131.072 FILE0146.CHK
07/10/2022  17:09           131.072 FILE0147.CHK
07/10/2022  17:09           131.072 FILE0148.CHK
07/10/2022  17:09           131.072 FILE0149.CHK
07/10/2022  17:09           131.072 FILE0150.CHK
07/10/2022  17:09           131.072 FILE0151.CHK
07/10/2022  17:09           131.072 FILE0152.CHK
07/10/2022  17:09           131.072 FILE0153.CHK
07/10/2022  17:09           131.072 FILE0154.CHK
07/10/2022  17:09           131.072 FILE0155.CHK
07/10/2022  17:09           262.144 FILE0156.CHK
07/10/2022  17:09           131.072 FILE0157.CHK
07/10/2022  17:09           131.072 FILE0158.CHK
07/10/2022  17:09           131.072 FILE0159.CHK
07/10/2022  17:09           131.072 FILE0160.CHK
07/10/2022  17:09           131.072 FILE0161.CHK
07/10/2022  17:09           131.072 FILE0162.CHK
07/10/2022  17:09           131.072 FILE0163.CHK
07/10/2022  17:09           131.072 FILE0164.CHK
07/10/2022  17:09           262.144 FILE0165.CHK
07/10/2022  17:09           262.144 FILE0166.CHK
07/10/2022  17:09           131.072 FILE0167.CHK
07/10/2022  17:09           131.072 FILE0168.CHK
07/10/2022  17:09           131.072 FILE0169.CHK
07/10/2022  17:09           131.072 FILE0170.CHK
07/10/2022  17:09           131.072 FILE0171.CHK
07/10/2022  17:09           131.072 FILE0172.CHK
07/10/2022  17:09           393.216 FILE0173.CHK
07/10/2022  17:09           131.072 FILE0174.CHK
07/10/2022  17:09           131.072 FILE0175.CHK
07/10/2022  17:09           262.144 FILE0176.CHK
07/10/2022  17:09           131.072 FILE0177.CHK
07/10/2022  17:09           262.144 FILE0178.CHK
07/10/2022  17:09           131.072 FILE0179.CHK
07/10/2022  17:09           131.072 FILE0180.CHK
07/10/2022  17:09           262.144 FILE0181.CHK
07/10/2022  17:09           262.144 FILE0182.CHK
07/10/2022  17:09           131.072 FILE0183.CHK
07/10/2022  17:09           131.072 FILE0184.CHK
07/10/2022  17:09           131.072 FILE0185.CHK
07/10/2022  17:09           131.072 FILE0186.CHK
07/10/2022  17:09           131.072 FILE0187.CHK
07/10/2022  17:09           262.144 FILE0188.CHK
07/10/2022  17:09           131.072 FILE0189.CHK
07/10/2022  17:09           131.072 FILE0190.CHK
07/10/2022  17:09           131.072 FILE0191.CHK
07/10/2022  17:09           524.288 FILE0192.CHK
07/10/2022  17:09           131.072 FILE0193.CHK
07/10/2022  17:09           262.144 FILE0194.CHK
07/10/2022  17:09           262.144 FILE0195.CHK
07/10/2022  17:09           262.144 FILE0196.CHK
07/10/2022  17:09           131.072 FILE0197.CHK
07/10/2022  17:09           131.072 FILE0198.CHK
07/10/2022  17:09           131.072 FILE0199.CHK
07/10/2022  17:09           131.072 FILE0200.CHK
07/10/2022  17:09           131.072 FILE0201.CHK
07/10/2022  17:09           262.144 FILE0202.CHK
07/10/2022  17:09           131.072 FILE0203.CHK
07/10/2022  17:09           131.072 FILE0204.CHK
07/10/2022  17:09           131.072 FILE0205.CHK
07/10/2022  17:09           131.072 FILE0206.CHK
07/10/2022  17:09           131.072 FILE0207.CHK
07/10/2022  17:09           131.072 FILE0208.CHK
07/10/2022  17:09           131.072 FILE0209.CHK
07/10/2022  17:09           131.072 FILE0210.CHK
07/10/2022  17:09           262.144 FILE0211.CHK
07/10/2022  17:09           131.072 FILE0212.CHK
07/10/2022  17:09           524.288 FILE0213.CHK
07/10/2022  17:09           262.144 FILE0214.CHK
07/10/2022  17:09           131.072 FILE0215.CHK
07/10/2022  17:09           131.072 FILE0216.CHK
07/10/2022  17:09           131.072 FILE0217.CHK
07/10/2022  17:09           131.072 FILE0218.CHK
07/10/2022  17:09           131.072 FILE0219.CHK
07/10/2022  17:09           131.072 FILE0220.CHK
07/10/2022  17:09           131.072 FILE0221.CHK
07/10/2022  17:09           131.072 FILE0222.CHK
07/10/2022  17:09           131.072 FILE0223.CHK
07/10/2022  17:09           262.144 FILE0224.CHK
07/10/2022  17:09           131.072 FILE0225.CHK
07/10/2022  17:09           131.072 FILE0226.CHK
07/10/2022  17:09           262.144 FILE0227.CHK
07/10/2022  17:09           131.072 FILE0228.CHK
07/10/2022  17:09           131.072 FILE0229.CHK
07/10/2022  17:09           131.072 FILE0230.CHK
07/10/2022  17:09           131.072 FILE0231.CHK
07/10/2022  17:09           131.072 FILE0232.CHK
07/10/2022  17:09           131.072 FILE0233.CHK
07/10/2022  17:09           131.072 FILE0234.CHK
07/10/2022  17:09           131.072 FILE0235.CHK
07/10/2022  17:09           131.072 FILE0236.CHK
07/10/2022  17:09           131.072 FILE0237.CHK
07/10/2022  17:09           131.072 FILE0238.CHK
07/10/2022  17:09           786.432 FILE0239.CHK
07/10/2022  17:09           131.072 FILE0240.CHK
07/10/2022  17:09           262.144 FILE0241.CHK
07/10/2022  17:09           131.072 FILE0242.CHK
07/10/2022  17:09           131.072 FILE0243.CHK
07/10/2022  17:09           131.072 FILE0244.CHK
07/10/2022  17:09           131.072 FILE0245.CHK
07/10/2022  17:09           131.072 FILE0246.CHK
07/10/2022  17:09           131.072 FILE0247.CHK
07/10/2022  17:09           131.072 FILE0248.CHK
07/10/2022  17:09           131.072 FILE0249.CHK
07/10/2022  17:09           131.072 FILE0250.CHK
07/10/2022  17:09           262.144 FILE0251.CHK
07/10/2022  17:09           262.144 FILE0252.CHK
07/10/2022  17:09           262.144 FILE0253.CHK
07/10/2022  17:09           131.072 FILE0254.CHK
07/10/2022  17:09           131.072 FILE0255.CHK
07/10/2022  17:09           131.072 FILE0256.CHK
07/10/2022  17:09           131.072 FILE0257.CHK
07/10/2022  17:09           131.072 FILE0258.CHK
07/10/2022  17:09           131.072 FILE0259.CHK
07/10/2022  17:09           131.072 FILE0260.CHK
07/10/2022  17:09           131.072 FILE0261.CHK
07/10/2022  17:09           131.072 FILE0262.CHK
07/10/2022  17:09           131.072 FILE0263.CHK
07/10/2022  17:09           131.072 FILE0264.CHK
07/10/2022  17:09           131.072 FILE0265.CHK
07/10/2022  17:09           262.144 FILE0266.CHK
07/10/2022  17:09           262.144 FILE0267.CHK
07/10/2022  17:09           131.072 FILE0268.CHK
07/10/2022  17:09           131.072 FILE0269.CHK
07/10/2022  17:09           131.072 FILE0270.CHK
07/10/2022  17:09           131.072 FILE0271.CHK
07/10/2022  17:09           262.144 FILE0272.CHK
07/10/2022  17:09           262.144 FILE0273.CHK
07/10/2022  17:09           131.072 FILE0274.CHK
07/10/2022  17:09           131.072 FILE0275.CHK
07/10/2022  17:09           131.072 FILE0276.CHK
07/10/2022  17:09           131.072 FILE0277.CHK
07/10/2022  17:09           262.144 FILE0278.CHK
07/10/2022  17:09           262.144 FILE0279.CHK
07/10/2022  17:09           131.072 FILE0280.CHK
07/10/2022  17:09           131.072 FILE0281.CHK
07/10/2022  17:09           131.072 FILE0282.CHK
07/10/2022  17:09           262.144 FILE0283.CHK
07/10/2022  17:09           262.144 FILE0284.CHK
07/10/2022  17:09           131.072 FILE0285.CHK
07/10/2022  17:09           131.072 FILE0286.CHK
07/10/2022  17:09           262.144 FILE0287.CHK
07/10/2022  17:09           131.072 FILE0288.CHK
07/10/2022  17:09           262.144 FILE0289.CHK
07/10/2022  17:09           262.144 FILE0290.CHK
07/10/2022  17:09           131.072 FILE0291.CHK
07/10/2022  17:09           262.144 FILE0292.CHK
07/10/2022  17:09           131.072 FILE0293.CHK
07/10/2022  17:09           262.144 FILE0294.CHK
07/10/2022  17:09           262.144 FILE0295.CHK
07/10/2022  17:09           131.072 FILE0296.CHK
07/10/2022  17:09           131.072 FILE0297.CHK
07/10/2022  17:09           131.072 FILE0298.CHK
07/10/2022  17:09           131.072 FILE0299.CHK
07/10/2022  17:09           262.144 FILE0300.CHK
07/10/2022  17:09           524.288 FILE0301.CHK
07/10/2022  17:09           131.072 FILE0302.CHK
07/10/2022  17:09           262.144 FILE0303.CHK
07/10/2022  17:09           131.072 FILE0304.CHK
07/10/2022  17:09           131.072 FILE0305.CHK
07/10/2022  17:09           131.072 FILE0306.CHK
07/10/2022  17:09           131.072 FILE0307.CHK
07/10/2022  17:09           131.072 FILE0308.CHK
07/10/2022  17:09           131.072 FILE0309.CHK
07/10/2022  17:09           131.072 FILE0310.CHK
07/10/2022  17:09           131.072 FILE0311.CHK
07/10/2022  17:09           131.072 FILE0312.CHK
07/10/2022  17:09           131.072 FILE0313.CHK
07/10/2022  17:09           131.072 FILE0314.CHK
07/10/2022  17:09           262.144 FILE0315.CHK
07/10/2022  17:09           262.144 FILE0316.CHK
07/10/2022  17:09           131.072 FILE0317.CHK
07/10/2022  17:09           131.072 FILE0318.CHK
07/10/2022  17:09           131.072 FILE0319.CHK
07/10/2022  17:09           262.144 FILE0320.CHK
07/10/2022  17:09           131.072 FILE0321.CHK
07/10/2022  17:09           131.072 FILE0322.CHK
07/10/2022  17:09           262.144 FILE0323.CHK
07/10/2022  17:09           131.072 FILE0324.CHK
07/10/2022  17:09           131.072 FILE0325.CHK
07/10/2022  17:09           262.144 FILE0326.CHK
07/10/2022  17:09           131.072 FILE0327.CHK
07/10/2022  17:09           131.072 FILE0328.CHK
07/10/2022  17:09           131.072 FILE0329.CHK
07/10/2022  17:09           131.072 FILE0330.CHK
07/10/2022  17:09           131.072 FILE0331.CHK
07/10/2022  17:09           131.072 FILE0332.CHK
07/10/2022  17:09           262.144 FILE0333.CHK
07/10/2022  17:09           262.144 FILE0334.CHK
07/10/2022  17:09           131.072 FILE0335.CHK
07/10/2022  17:09           262.144 FILE0336.CHK
07/10/2022  17:09           131.072 FILE0337.CHK
07/10/2022  17:09           131.072 FILE0338.CHK
07/10/2022  17:09           262.144 FILE0339.CHK
07/10/2022  17:09           262.144 FILE0340.CHK
07/10/2022  17:09           131.072 FILE0341.CHK
07/10/2022  17:09           131.072 FILE0342.CHK
07/10/2022  17:09           131.072 FILE0343.CHK
07/10/2022  17:09           131.072 FILE0344.CHK
07/10/2022  17:09           262.144 FILE0345.CHK
07/10/2022  17:09           262.144 FILE0346.CHK
07/10/2022  17:09           131.072 FILE0347.CHK
07/10/2022  17:09           262.144 FILE0348.CHK
07/10/2022  17:09           131.072 FILE0349.CHK
07/10/2022  17:09           262.144 FILE0350.CHK
07/10/2022  17:09           262.144 FILE0351.CHK
07/10/2022  17:09           131.072 FILE0352.CHK
07/10/2022  17:09           131.072 FILE0353.CHK
07/10/2022  17:09           131.072 FILE0354.CHK
07/10/2022  17:09           262.144 FILE0355.CHK
07/10/2022  17:09           262.144 FILE0356.CHK
07/10/2022  17:09           131.072 FILE0357.CHK
07/10/2022  17:09           262.144 FILE0358.CHK
07/10/2022  17:09           131.072 FILE0359.CHK
07/10/2022  17:09           131.072 FILE0360.CHK
07/10/2022  17:09           262.144 FILE0361.CHK
07/10/2022  17:09           131.072 FILE0362.CHK
07/10/2022  17:09           131.072 FILE0363.CHK
07/10/2022  17:09           131.072 FILE0364.CHK
07/10/2022  17:09           131.072 FILE0365.CHK
07/10/2022  17:09           131.072 FILE0366.CHK
07/10/2022  17:09           131.072 FILE0367.CHK
07/10/2022  17:09           262.144 FILE0368.CHK
07/10/2022  17:09           262.144 FILE0369.CHK
07/10/2022  17:09           262.144 FILE0370.CHK
07/10/2022  17:09           131.072 FILE0371.CHK
07/10/2022  17:09           131.072 FILE0372.CHK
07/10/2022  17:09           131.072 FILE0373.CHK
07/10/2022  17:09           262.144 FILE0374.CHK
07/10/2022  17:09         1.310.720 FILE0375.CHK
07/10/2022  17:09           131.072 FILE0376.CHK
07/10/2022  17:09           262.144 FILE0377.CHK
07/10/2022  17:09           131.072 FILE0378.CHK
07/10/2022  17:09           262.144 FILE0379.CHK
07/10/2022  17:09           262.144 FILE0380.CHK
07/10/2022  17:09           131.072 FILE0381.CHK
07/10/2022  17:09           262.144 FILE0382.CHK
07/10/2022  17:09           131.072 FILE0383.CHK
07/10/2022  17:09           131.072 FILE0384.CHK
07/10/2022  17:09           131.072 FILE0385.CHK
07/10/2022  17:09           131.072 FILE0386.CHK
07/10/2022  17:09           262.144 FILE0387.CHK
07/10/2022  17:09           131.072 FILE0388.CHK
07/10/2022  17:09           262.144 FILE0389.CHK
07/10/2022  17:09           131.072 FILE0390.CHK
07/10/2022  17:09           131.072 FILE0391.CHK
07/10/2022  17:09           393.216 FILE0392.CHK
07/10/2022  17:09           131.072 FILE0393.CHK
07/10/2022  17:09           131.072 FILE0394.CHK
07/10/2022  17:09           131.072 FILE0395.CHK
07/10/2022  17:09           131.072 FILE0396.CHK
07/10/2022  17:09           393.216 FILE0397.CHK
07/10/2022  17:09           131.072 FILE0398.CHK
07/10/2022  17:09           393.216 FILE0399.CHK
07/10/2022  17:09           131.072 FILE0400.CHK
07/10/2022  17:09           131.072 FILE0401.CHK
07/10/2022  17:09           262.144 FILE0402.CHK
07/10/2022  17:09           262.144 FILE0403.CHK
07/10/2022  17:09           262.144 FILE0404.CHK
07/10/2022  17:09           262.144 FILE0405.CHK
07/10/2022  17:09           131.072 FILE0406.CHK
07/10/2022  17:09           131.072 FILE0407.CHK
07/10/2022  17:09           131.072 FILE0408.CHK
07/10/2022  17:09           131.072 FILE0409.CHK
07/10/2022  17:09           131.072 FILE0410.CHK
07/10/2022  17:09           131.072 FILE0411.CHK
07/10/2022  17:09           262.144 FILE0412.CHK
07/10/2022  17:09           262.144 FILE0413.CHK
07/10/2022  17:09           262.144 FILE0414.CHK
07/10/2022  17:09           262.144 FILE0415.CHK
07/10/2022  17:09           262.144 FILE0416.CHK
07/10/2022  17:09           131.072 FILE0417.CHK
07/10/2022  17:09           262.144 FILE0418.CHK
07/10/2022  17:09           262.144 FILE0419.CHK
07/10/2022  17:09           131.072 FILE0420.CHK
07/10/2022  17:09           262.144 FILE0421.CHK
07/10/2022  17:09           131.072 FILE0422.CHK
07/10/2022  17:09           131.072 FILE0423.CHK
07/10/2022  17:09           655.360 FILE0424.CHK
07/10/2022  17:09           262.144 FILE0425.CHK
07/10/2022  17:09           262.144 FILE0426.CHK
07/10/2022  17:09           262.144 FILE0427.CHK
07/10/2022  17:09           524.288 FILE0428.CHK
07/10/2022  17:09           262.144 FILE0429.CHK
07/10/2022  17:09           131.072 FILE0430.CHK
07/10/2022  17:09           131.072 FILE0431.CHK
07/10/2022  17:09           131.072 FILE0432.CHK
07/10/2022  17:09           131.072 FILE0433.CHK
07/10/2022  17:09           131.072 FILE0434.CHK
07/10/2022  17:09           131.072 FILE0435.CHK
07/10/2022  17:09           131.072 FILE0436.CHK
07/10/2022  17:09           262.144 FILE0437.CHK
07/10/2022  17:09           262.144 FILE0438.CHK
07/10/2022  17:09           262.144 FILE0439.CHK
07/10/2022  17:09           131.072 FILE0440.CHK
07/10/2022  17:09           262.144 FILE0441.CHK
07/10/2022  17:09           262.144 FILE0442.CHK
07/10/2022  17:09           131.072 FILE0443.CHK
07/10/2022  17:09           131.072 FILE0444.CHK
07/10/2022  17:09           262.144 FILE0445.CHK
07/10/2022  17:09           262.144 FILE0446.CHK
07/10/2022  17:09           131.072 FILE0447.CHK
07/10/2022  17:09           131.072 FILE0448.CHK
07/10/2022  17:09           131.072 FILE0449.CHK
07/10/2022  17:09           262.144 FILE0450.CHK
07/10/2022  17:09           131.072 FILE0451.CHK
07/10/2022  17:09           131.072 FILE0452.CHK
07/10/2022  17:09           131.072 FILE0453.CHK
07/10/2022  17:09           131.072 FILE0454.CHK
07/10/2022  17:09           131.072 FILE0455.CHK
07/10/2022  17:09           262.144 FILE0456.CHK
07/10/2022  17:09           262.144 FILE0457.CHK
07/10/2022  17:09           262.144 FILE0458.CHK
07/10/2022  17:09           131.072 FILE0459.CHK
07/10/2022  17:09           131.072 FILE0460.CHK
07/10/2022  17:09           262.144 FILE0461.CHK
07/10/2022  17:09           131.072 FILE0462.CHK
07/10/2022  17:09           262.144 FILE0463.CHK
07/10/2022  17:09           262.144 FILE0464.CHK
07/10/2022  17:09           131.072 FILE0465.CHK
07/10/2022  17:09           262.144 FILE0466.CHK
07/10/2022  17:09           131.072 FILE0467.CHK
07/10/2022  17:09           131.072 FILE0468.CHK
07/10/2022  17:09           131.072 FILE0469.CHK
07/10/2022  17:09           262.144 FILE0470.CHK
07/10/2022  17:09           131.072 FILE0471.CHK
07/10/2022  17:09           262.144 FILE0472.CHK
07/10/2022  17:09           262.144 FILE0473.CHK
07/10/2022  17:09           131.072 FILE0474.CHK
07/10/2022  17:09           262.144 FILE0475.CHK
07/10/2022  17:09           262.144 FILE0476.CHK
07/10/2022  17:09           262.144 FILE0477.CHK
07/10/2022  17:09           131.072 FILE0478.CHK
07/10/2022  17:09           262.144 FILE0479.CHK
07/10/2022  17:09           131.072 FILE0480.CHK
07/10/2022  17:09           262.144 FILE0481.CHK
07/10/2022  17:09           131.072 FILE0482.CHK
07/10/2022  17:09           131.072 FILE0483.CHK
07/10/2022  17:09           262.144 FILE0484.CHK
07/10/2022  17:09           262.144 FILE0485.CHK
07/10/2022  17:09           131.072 FILE0486.CHK
07/10/2022  17:09           131.072 FILE0487.CHK
07/10/2022  17:09           262.144 FILE0488.CHK
07/10/2022  17:09           262.144 FILE0489.CHK
07/10/2022  17:09           262.144 FILE0490.CHK
07/10/2022  17:09           131.072 FILE0491.CHK
07/10/2022  17:09           131.072 FILE0492.CHK
07/10/2022  17:09           262.144 FILE0493.CHK
07/10/2022  17:09           262.144 FILE0494.CHK
07/10/2022  17:09           131.072 FILE0495.CHK
07/10/2022  17:09           131.072 FILE0496.CHK
07/10/2022  17:09           131.072 FILE0497.CHK
07/10/2022  17:09           131.072 FILE0498.CHK
07/10/2022  17:09           262.144 FILE0499.CHK
07/10/2022  17:09           131.072 FILE0500.CHK
07/10/2022  17:09           131.072 FILE0501.CHK
07/10/2022  17:09           131.072 FILE0502.CHK
07/10/2022  17:09           262.144 FILE0503.CHK
07/10/2022  17:09           131.072 FILE0504.CHK
07/10/2022  17:09           262.144 FILE0505.CHK
07/10/2022  17:09           131.072 FILE0506.CHK
07/10/2022  17:09           131.072 FILE0507.CHK
07/10/2022  17:09           131.072 FILE0508.CHK
07/10/2022  17:09           131.072 FILE0509.CHK
07/10/2022  17:09           131.072 FILE0510.CHK
07/10/2022  17:09           131.072 FILE0511.CHK
07/10/2022  17:09           393.216 FILE0512.CHK
07/10/2022  17:09           262.144 FILE0513.CHK
07/10/2022  17:09           131.072 FILE0514.CHK
07/10/2022  17:09           131.072 FILE0515.CHK
07/10/2022  17:09           262.144 FILE0516.CHK
07/10/2022  17:09           131.072 FILE0517.CHK
07/10/2022  17:09           131.072 FILE0518.CHK
07/10/2022  17:09           262.144 FILE0519.CHK
07/10/2022  17:09           262.144 FILE0520.CHK
07/10/2022  17:09           262.144 FILE0521.CHK
07/10/2022  17:09           262.144 FILE0522.CHK
07/10/2022  17:09           393.216 FILE0523.CHK
07/10/2022  17:09           262.144 FILE0524.CHK
07/10/2022  17:09           131.072 FILE0525.CHK
07/10/2022  17:09           131.072 FILE0526.CHK
07/10/2022  17:09           131.072 FILE0527.CHK
07/10/2022  17:09           131.072 FILE0528.CHK
07/10/2022  17:09           262.144 FILE0529.CHK
07/10/2022  17:09           131.072 FILE0530.CHK
07/10/2022  17:09           131.072 FILE0531.CHK
07/10/2022  17:09           131.072 FILE0532.CHK
07/10/2022  17:09           262.144 FILE0533.CHK
07/10/2022  17:09           131.072 FILE0534.CHK
07/10/2022  17:09           131.072 FILE0535.CHK
07/10/2022  17:09           262.144 FILE0536.CHK
07/10/2022  17:09           262.144 FILE0537.CHK
07/10/2022  17:09           131.072 FILE0538.CHK
07/10/2022  17:09           262.144 FILE0539.CHK
07/10/2022  17:09           131.072 FILE0540.CHK
07/10/2022  17:09           262.144 FILE0541.CHK
07/10/2022  17:09           131.072 FILE0542.CHK
07/10/2022  17:09           262.144 FILE0543.CHK
07/10/2022  17:09           262.144 FILE0544.CHK
07/10/2022  17:09           262.144 FILE0545.CHK
07/10/2022  17:09           131.072 FILE0546.CHK
07/10/2022  17:09           131.072 FILE0547.CHK
07/10/2022  17:09           393.216 FILE0548.CHK
07/10/2022  17:09           131.072 FILE0549.CHK
07/10/2022  17:09           131.072 FILE0550.CHK
07/10/2022  17:09           131.072 FILE0551.CHK
07/10/2022  17:09           262.144 FILE0552.CHK
07/10/2022  17:09           262.144 FILE0553.CHK
07/10/2022  17:09           262.144 FILE0554.CHK
07/10/2022  17:09           262.144 FILE0555.CHK
07/10/2022  17:09           262.144 FILE0556.CHK
07/10/2022  17:09           262.144 FILE0557.CHK
07/10/2022  17:09           131.072 FILE0558.CHK
07/10/2022  17:09           131.072 FILE0559.CHK
07/10/2022  17:09           131.072 FILE0560.CHK
07/10/2022  17:09           131.072 FILE0561.CHK
07/10/2022  17:09           131.072 FILE0562.CHK
07/10/2022  17:09           131.072 FILE0563.CHK
07/10/2022  17:09           262.144 FILE0564.CHK
07/10/2022  17:09           393.216 FILE0565.CHK
07/10/2022  17:09           131.072 FILE0566.CHK
07/10/2022  17:09           262.144 FILE0567.CHK
07/10/2022  17:09           262.144 FILE0568.CHK
07/10/2022  17:09           262.144 FILE0569.CHK
07/10/2022  17:09           524.288 FILE0570.CHK
07/10/2022  17:09           131.072 FILE0571.CHK
07/10/2022  17:09           262.144 FILE0572.CHK
07/10/2022  17:09           131.072 FILE0573.CHK
07/10/2022  17:09           131.072 FILE0574.CHK
07/10/2022  17:09           131.072 FILE0575.CHK
07/10/2022  17:09           131.072 FILE0576.CHK
07/10/2022  17:09           131.072 FILE0577.CHK
07/10/2022  17:09           262.144 FILE0578.CHK
07/10/2022  17:09           262.144 FILE0579.CHK
07/10/2022  17:09           262.144 FILE0580.CHK
07/10/2022  17:09           524.288 FILE0581.CHK
07/10/2022  17:09           393.216 FILE0582.CHK
07/10/2022  17:09           131.072 FILE0583.CHK
07/10/2022  17:09           131.072 FILE0584.CHK
07/10/2022  17:09           262.144 FILE0585.CHK
07/10/2022  17:09           262.144 FILE0586.CHK
07/10/2022  17:09           131.072 FILE0587.CHK
07/10/2022  17:09           131.072 FILE0588.CHK
07/10/2022  17:09           262.144 FILE0589.CHK
07/10/2022  17:09           262.144 FILE0590.CHK
07/10/2022  17:09           262.144 FILE0591.CHK
07/10/2022  17:09           262.144 FILE0592.CHK
07/10/2022  17:09           655.360 FILE0593.CHK
07/10/2022  17:09           524.288 FILE0594.CHK
07/10/2022  17:09           131.072 FILE0595.CHK
07/10/2022  17:09           131.072 FILE0596.CHK
07/10/2022  17:09           131.072 FILE0597.CHK
07/10/2022  17:09           262.144 FILE0598.CHK
07/10/2022  17:09           262.144 FILE0599.CHK
07/10/2022  17:09           262.144 FILE0600.CHK
07/10/2022  17:09           131.072 FILE0601.CHK
07/10/2022  17:09           262.144 FILE0602.CHK
07/10/2022  17:09           131.072 FILE0603.CHK
07/10/2022  17:09           131.072 FILE0604.CHK
07/10/2022  17:09           131.072 FILE0605.CHK
07/10/2022  17:09           131.072 FILE0606.CHK
07/10/2022  17:09           131.072 FILE0607.CHK
07/10/2022  17:09           131.072 FILE0608.CHK
07/10/2022  17:09           393.216 FILE0609.CHK
07/10/2022  17:09           131.072 FILE0610.CHK
07/10/2022  17:09           131.072 FILE0611.CHK
07/10/2022  17:09           131.072 FILE0612.CHK
07/10/2022  17:09           131.072 FILE0613.CHK
07/10/2022  17:09           262.144 FILE0614.CHK
07/10/2022  17:09           262.144 FILE0615.CHK
07/10/2022  17:09           131.072 FILE0616.CHK
07/10/2022  17:09           131.072 FILE0617.CHK
07/10/2022  17:09           131.072 FILE0618.CHK
07/10/2022  17:09           131.072 FILE0619.CHK
07/10/2022  17:09           131.072 FILE0620.CHK
07/10/2022  17:09           131.072 FILE0621.CHK
07/10/2022  17:09           262.144 FILE0622.CHK
07/10/2022  17:09           131.072 FILE0623.CHK
07/10/2022  17:09           393.216 FILE0624.CHK
07/10/2022  17:09           393.216 FILE0625.CHK
07/10/2022  17:09           131.072 FILE0626.CHK
07/10/2022  17:09           262.144 FILE0627.CHK
07/10/2022  17:09           131.072 FILE0628.CHK
07/10/2022  17:09           131.072 FILE0629.CHK
07/10/2022  17:09           131.072 FILE0630.CHK
07/10/2022  17:09           393.216 FILE0631.CHK
07/10/2022  17:09           393.216 FILE0632.CHK
07/10/2022  17:09           262.144 FILE0633.CHK
07/10/2022  17:09           262.144 FILE0634.CHK
07/10/2022  17:09           393.216 FILE0635.CHK
07/10/2022  17:09           262.144 FILE0636.CHK
07/10/2022  17:09           262.144 FILE0637.CHK
07/10/2022  17:09           262.144 FILE0638.CHK
07/10/2022  17:09           131.072 FILE0639.CHK
07/10/2022  17:09           131.072 FILE0640.CHK
07/10/2022  17:09           131.072 FILE0641.CHK
07/10/2022  17:09           131.072 FILE0642.CHK
07/10/2022  17:09           131.072 FILE0643.CHK
07/10/2022  17:09           131.072 FILE0644.CHK
07/10/2022  17:09           262.144 FILE0645.CHK
07/10/2022  17:09           262.144 FILE0646.CHK
07/10/2022  17:09           131.072 FILE0647.CHK
07/10/2022  17:09           131.072 FILE0648.CHK
07/10/2022  17:09           393.216 FILE0649.CHK
07/10/2022  17:09           262.144 FILE0650.CHK
07/10/2022  17:09           262.144 FILE0651.CHK
07/10/2022  17:09           262.144 FILE0652.CHK
07/10/2022  17:09           262.144 FILE0653.CHK
07/10/2022  17:09           131.072 FILE0654.CHK
07/10/2022  17:09           131.072 FILE0655.CHK
07/10/2022  17:09           393.216 FILE0656.CHK
07/10/2022  17:09           131.072 FILE0657.CHK
07/10/2022  17:09           393.216 FILE0658.CHK
07/10/2022  17:09           393.216 FILE0659.CHK
07/10/2022  17:09           393.216 FILE0660.CHK
07/10/2022  17:09           262.144 FILE0661.CHK
07/10/2022  17:09           262.144 FILE0662.CHK
07/10/2022  17:09           393.216 FILE0663.CHK
07/10/2022  17:09           262.144 FILE0664.CHK
07/10/2022  17:09           262.144 FILE0665.CHK
07/10/2022  17:09           131.072 FILE0666.CHK
07/10/2022  17:09           131.072 FILE0667.CHK
07/10/2022  17:09           262.144 FILE0668.CHK
07/10/2022  17:09           262.144 FILE0669.CHK
07/10/2022  17:09           262.144 FILE0670.CHK
07/10/2022  17:09           393.216 FILE0671.CHK
07/10/2022  17:09           262.144 FILE0672.CHK
07/10/2022  17:09           131.072 FILE0673.CHK
07/10/2022  17:09           131.072 FILE0674.CHK
07/10/2022  17:09           262.144 FILE0675.CHK
07/10/2022  17:09           131.072 FILE0676.CHK
07/10/2022  17:09           131.072 FILE0677.CHK
07/10/2022  17:09           131.072 FILE0678.CHK
07/10/2022  17:09           131.072 FILE0679.CHK
07/10/2022  17:09           131.072 FILE0680.CHK
07/10/2022  17:09           131.072 FILE0681.CHK
07/10/2022  17:09           131.072 FILE0682.CHK
07/10/2022  17:09           131.072 FILE0683.CHK
07/10/2022  17:09           262.144 FILE0684.CHK
07/10/2022  17:09           262.144 FILE0685.CHK
07/10/2022  17:09           131.072 FILE0686.CHK
07/10/2022  17:09           131.072 FILE0687.CHK
07/10/2022  17:09           393.216 FILE0688.CHK
07/10/2022  17:09           131.072 FILE0689.CHK
07/10/2022  17:09           131.072 FILE0690.CHK
07/10/2022  17:09           262.144 FILE0691.CHK
07/10/2022  17:09           262.144 FILE0692.CHK
07/10/2022  17:09           131.072 FILE0693.CHK
07/10/2022  17:09           262.144 FILE0694.CHK
07/10/2022  17:09           131.072 FILE0695.CHK
07/10/2022  17:09           262.144 FILE0696.CHK
07/10/2022  17:09           262.144 FILE0697.CHK
07/10/2022  17:09           262.144 FILE0698.CHK
07/10/2022  17:09           262.144 FILE0699.CHK
07/10/2022  17:09           131.072 FILE0700.CHK
07/10/2022  17:09           131.072 FILE0701.CHK
07/10/2022  17:09           131.072 FILE0702.CHK
07/10/2022  17:09           131.072 FILE0703.CHK
07/10/2022  17:09           131.072 FILE0704.CHK
07/10/2022  17:09           131.072 FILE0705.CHK
07/10/2022  17:09           131.072 FILE0706.CHK
07/10/2022  17:09           393.216 FILE0707.CHK
07/10/2022  17:09           131.072 FILE0708.CHK
07/10/2022  17:09           131.072 FILE0709.CHK
07/10/2022  17:09           131.072 FILE0710.CHK
07/10/2022  17:09           131.072 FILE0711.CHK
07/10/2022  17:09           262.144 FILE0712.CHK
07/10/2022  17:09           262.144 FILE0713.CHK
07/10/2022  17:09           262.144 FILE0714.CHK
07/10/2022  17:09           131.072 FILE0715.CHK
07/10/2022  17:09           131.072 FILE0716.CHK
07/10/2022  17:09           131.072 FILE0717.CHK
07/10/2022  17:09           917.504 FILE0718.CHK
07/10/2022  17:09           262.144 FILE0719.CHK
07/10/2022  17:09           262.144 FILE0720.CHK
07/10/2022  17:09           131.072 FILE0721.CHK
07/10/2022  17:09           131.072 FILE0722.CHK
07/10/2022  17:09           131.072 FILE0723.CHK
07/10/2022  17:09         1.441.792 FILE0724.CHK
07/10/2022  17:09           131.072 FILE0725.CHK
07/10/2022  17:09           131.072 FILE0726.CHK
07/10/2022  17:09         1.048.576 FILE0727.CHK
07/10/2022  17:09           131.072 FILE0728.CHK
07/10/2022  17:09           262.144 FILE0729.CHK
07/10/2022  17:09           262.144 FILE0730.CHK
07/10/2022  17:09           262.144 FILE0731.CHK
07/10/2022  17:09           262.144 FILE0732.CHK
07/10/2022  17:09           262.144 FILE0733.CHK
07/10/2022  17:09           262.144 FILE0734.CHK
07/10/2022  17:09           131.072 FILE0735.CHK
07/10/2022  17:09           131.072 FILE0736.CHK
07/10/2022  17:09           131.072 FILE0737.CHK
07/10/2022  17:09           131.072 FILE0738.CHK
07/10/2022  17:09           131.072 FILE0739.CHK
07/10/2022  17:09           131.072 FILE0740.CHK
07/10/2022  17:09           262.144 FILE0741.CHK
07/10/2022  17:09           262.144 FILE0742.CHK
07/10/2022  17:09           131.072 FILE0743.CHK
07/10/2022  17:09           262.144 FILE0744.CHK
07/10/2022  17:09           131.072 FILE0745.CHK
07/10/2022  17:09           262.144 FILE0746.CHK
07/10/2022  17:09           262.144 FILE0747.CHK
07/10/2022  17:09           131.072 FILE0748.CHK
07/10/2022  17:09           131.072 FILE0749.CHK
07/10/2022  17:09           131.072 FILE0750.CHK
07/10/2022  17:09           131.072 FILE0751.CHK
07/10/2022  17:09           131.072 FILE0752.CHK
07/10/2022  17:09           262.144 FILE0753.CHK
07/10/2022  17:09           131.072 FILE0754.CHK
             755 File    148.111.360 byte
               0 Directory  58.133.577.728 byte disponibili
H:\FOUND.000>cd..
H:\>deltree FOUND.000
"deltree" non è riconosciuto come comando interno o esterno,
 un programma eseguibile o un file batch.
H:\>del /?
Specificando
                tutti i file al suo interno
                verranno eliminati.
  /P            Chiede conferma prima di eliminare ogni file.
  /F            Forza l'eliminazione dei file di sola lettura.
  /S            Elimina i file specificati da tutte le sottodirectory.
  /Q            Modalità non interattiva, non chiede conferma per eliminazioni globali.
  /A            Seleziona i file da eliminare in base agli attributi.
  attributi    R  File di sola lettura            S  File di sistema
                H  File nascosti               A  File di archivio
                I  File non indicizzati  L  Reparse point
                O  File offline              -  Prefisso per negare l'attributo
Se le estensioni dei comandi sono attivate, i comandi DEL ed ERASE verranno
modificati come segue:
La semantica di visualizzazione dell'opzione /S viene invertita, poiché
mostra solo i file eliminati anziché quelli che non è possibile trovare.
H:\>rmdir FOUND.000
La directory non è vuota.
H:\>rmdir /?
RMDIR [/S] [/Q] [unità:]percorso
RD [/S] [/Q] [unità:]percorso
  /S        Rimuove tutte le directory e file nella directory
            specificata oltre alla directory stessa. Usato per
            rimuovere l'intero albero di una directory.
  /Q        Modalità non interattiva, non richiede alcuna conferma
            per la rimozione di un albero di directory eseguita
            con /S
H:\>rmdir FOUND.000 /q/s
H:\>rmdir FOUND.001 /q/s
H:\>rmdir FOUND.002 /q/s
H:\>rmdir FOUND.003 /q/s
Dispositivo non pronto.
H:\>dir
Parametro non corretto.
H:\>chkdsk h:
Accesso negato.
Il volume è in uso da un altro processo. Chkdsk
potrebbe rilevare errori anche in assenza di danni effettivi.
Analisi del file system effettuata. Nessun problema rilevato.
  67875328 KB in 58512 file.
     85248 KB in 609 indici.
  57049088 KB disponibili su disco.
    445696 unità di allocazione disponibili su disco.
H:\>chkdsk h: /f
Impossibile bloccare l'unità corrente.
Impossibile eseguire chkdsk. Il volume è utilizzato da un
altro processo. Smontare il volume per eseguire chkdsk.
TUTTI GLI HANDLE DEL VOLUME APERTI CESSERANNO IN QUESTO
MODO DI ESSERE VALIDI.
Forzare lo smontaggio sul volume? (S/N) s
Volume smontato.  Tutti gli handle del volume aperti non sono più validi.
La verifica del volume è stata eseguita correttamente, ma non è stato possibile
contrassegnare il volume come pulito.
H:\>dir
Il volume non contiene un file system riconosciuto.
Controllare che siano caricati tutti i driver richiesti per il file system e che il volume non sia danneggiato.
H:\>
How should I proceed to try to recover the files or even better the partition table with file names?
I tried to set the exfat partition type and now I get this:
user picture TWlB0oI.png (18.71 KiB) Viewed 3465 times
I'm not sure how should I proceed forward, any help will be appreciated
Thanks
Re: Samsung Micro SD 128gb corrupted
You did everything wrong.
Instead of running chkdsk you should have duplicated your drive using ddrescue as described in the manual:
chkdsk has brought back the logical integrity of your micro SD card at the price of the destruction of evidence that could have been useful for recovery.
If Testdisk is not able to list the content of your disk (see "p"-key to list files)
you can either run Photorec or try out lots of different commercial recovery programs.
Other recovery programs might find the remains of metadata and use that content to better recover the content of your micro SD card. If they fail Photorec is your last option but you will loose directory structures and file names. Depending of the fragmentation of your file system and possible other dammage Photorec will rescue to an extent from nothing to everything.
I modified your posting. I uploaded your picture to this site which is pretty easy to do by clicking on the attachment tab on the bottom of the page.
