MemoryStick adapter block microsd size
oleguer
#1 Post by oleguer »
I have 256Gb micro sd card and I try to put in the psp with memory stick adapter,
If I format the micro sd card on FAT32 with 64kb (32768 bytes) cluster size (using sd card reader) and copy the ms folders.
(Later plug my micro sd card on memory stick adapter) My psp recognized the ms with 235Gb of memory (loose data when format)
...but If I try to copy (using the memory stick adapter) more than 104 gb of data (I dont know the reason of 104gb y think the flash of the adapter) when windows copy to this point have error 0x80070057 wrong parameter (I think for the adapter) and cant copy any more data...
...And if try to copy the data using sd card reader (without memory stick adapter) can copy all of data without errors BUT when I plug in the memory stick adapter and plug in the psp HALF DATA (I think if writed more than 104gb) are damaged data and cant use in the psp.....
For this reason (I think) the problem is the memory stick adapter more think the "flash" of the adapter..... for this reason I want to know what I need to dellete this limitation on the flash of the adapter but I cant have knowledge to do this ^^""
Now I explain more clear?? Thanks for any help forum!!
I try with different adapters and have the same fail!!
I try to search one pc app like fake flash test to enhanced the memory but stop the test on 104gb and cant try more space....
Re: MemoryStick adapter block microsd size
As Testdisk does not recognize the correct size of your micro SD card, you can't use Testdisk anyway.
Use h2testw on Windows or f3 on linux to recognize fake cards.
Try out other micro SD cards that you have or buy quality cards and compare how they behave in your setting.
oleguer
#3 Post by oleguer »
The card have good quality and space! BUT the memory stick adapter is the fail! because the ms adapter limit the usefull space of the card to 104gb ((the card have 256gb andthe psp detect the all space!)) ((from 104gb to 256gb is borken space when you use the ms adapter from the firnware of the adapter (i think) i want any tip or tips to dellete or clean the firmware data of the memory stick!
you understand me? any suggest?? thanks forum!!
