Can't clear partition table
bbtester
#1 Post by bbtester »
Hello
I buy a new pendrive for save the pics from my wife phone, and i got a problem with this usb flash device. I try many applications and tools to figure out whats the problem but with no results.
Yesterday i download TestDisk and follow some instructions to bring to life my pendrive but again no results.
The most common problem I have with this device when trying to salvage it is this Can't clear partition table
file_win32_pwrite(588,1,buffer,0(0/0/1)) write err
Write error: Can't clear partition table.
Write error: Can't write new MBR code.
I just want to bring to life my pendrive
Re: Can't clear partition table
Please post your complete logfile.
Thank you!
bbtester
#3 Post by bbtester »
Mon Jan 16 00:14:41 2023
TestDisk 7.2-WIP, Data Recovery Utility, November 2022
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=61865984000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=238559364608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=512092012544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Z:)=61865984000
Disk \\.\PhysicalDrive0 - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - SSDPR-CX400-512-G2, S/N:GYY039714, FW:SBFM61.5
Disk \\.\PhysicalDrive1 - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - GOODRAM, S/N:4D450767062701195969, FW:SAFM22.3
Disk \\.\PhysicalDrive2 - 61 GB / 57 GiB - CHS 7521 255 63, sector size=512 - General USB Flash Disk, S/N:AA00000000000489, FW:1100
Drive D: - 512 GB / 476 GiB - CHS 62258 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 61 GB / 57 GiB - General USB Flash Disk
Analyse Disk \\.\PhysicalDrive2 - 61 GB / 57 GiB - CHS 7521 255 63
file_win32_pread(628,2,buffer,120831999(7521/113/16)) read err: read after end of file
Change partition type:
     FAT32                    0   0  1  7520 254 63  120824865
Store new MBR code
file_win32_pwrite(628,1,buffer,0(0/0/1)) write err
If your pendrive does not let you write, duplicate it using ddrescue as described in the manual and try to rescue from the copy.
bbtester
#5 Post by bbtester »
ok, pendrive copy done, but how to now rescue from copy ?
ok i found that will be done after:
ddrescue -f sda.dd /dev/sda
i will back and post if it helps
#6 Post by recuperation »
