Recovering partitions to original structure after Buffalo NAS formatted the disk
sfh1975
#1 Post by sfh1975 »
Hi everyone,
I have a Buffalo LinkStation Pro Duo (LS-WVL) which was running two identical 4TB WD disks in a non-raid config, I will call them Disk 1 and Disk 2. I tried to install debian on it (Disk 1) but due to some reason, it couldnt boot so I decided to revert it back to stock. I deleted boot partition on Disk 1 to deliberately put it into Emergency mode and rebooted NAS with only one disk (Disk 1) which it has formatted. I know, I should have re-read the instructions more carefully :cry:
Anwyay I can see my files using UFS Explorer but I would rather prefer to have the partitions back if possible. I tried to revert partitions on Disk 1 using testdik but I am sure I have messed up again, as I will present below. Also, it is still booting in emergency mode.
Before the mess up, both disks had, apart from the system folders/ partitions, only one data partitions/ folder (with my data) in each "share" or disk. It was /Media/Movies/Movie1, Movie2, ... on Disk 1 and /Media2/TV/TVShow1, TVShow2, .... on Disk 2. There might be autogenerated hidden system folders and a rubbish bin in each too but I dont remember exactly.
When I run testdisk on the good disk (Disk 2), I get:
Quote:
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 3815447 64 32
> 1 P MS Data 2048 2002943 2000896 [primary]
2 P MS Data 2002944 12003327 10000384 [primary]
3 P MS Data 12003328 12005375 2048 [primary]
4 P MS Data 12005376 12007423 2048 [primary]
5 P MS Data 12007424 14008319 2000896 [primary]
Next
>[Quick Search] [ Backup ]
Try to locate partition
Unquote!
After proceeding to locate partitions, Disk 2 shows:
D Linux filesys. data 2048 2002815 2000768
D Linux Raid 2048 2002943 2000896 [md0]
P Linux Raid 2002944 12001263 9998320 [LS-WVL-EMF0E:1]
P Linux Raid 12007424 14008303 2000880 [LS-WVL-EMF0E:10]
>P Linux Raid 14008320 7796881007 7782872688 [LS-WVLF0E:22]
P=Primary D=Deleted
Keys A: add partition, L: load backup, T: change type,
Enter: to continue
md 1.x L.Endian Raid 1 - Array Slot : 0 (0, failed, failed, failed, failed, failed, failed, failed, failed, failed, failed), 3984 GB / 3711 GiB
Unquote!
On Disk 1, I took a screeshot of the partition scheme when I was trying to install debian on it but I dont know how to upload the photo here.
Now, when I run testdisk on the messed up disk (Disk 1), it shows only one partition. When I search for partitions, it shows:
Quote:
Disk /dev/sda - 4000 GB / 3726 GiB - CHS 3815447 64 32
P Linux Raid 14008320 7796881007 7782872688 [LS-WVL-EMF0E:21]
P Linux filesys. data 7796883456 7797383167 499712
P Linux filesys. data 7797383168 7813230591 15847424
P Linux Swap 7813230592 7814035439 804848
P=Primary D=Deleted
Enter: to continue
ext3 blocksize=4096 Large_file Sparse_SB, 1024 MB / 976 MiB
Unquote!
I ran deeper search last night and it showed:
>D Linux filesys. data 2046 2002813 2000768
D Linux Raid 2002944 12001263 9998320 [LS-WVL-EMF0E:1]
D Linux filesys. data 2004990 12003301 9998312
D Linux filesys. data 2004992 12003303 9998312
D Linux filesys. data 2012112 12010423 9998312
D Linux filesys. data 2012376 12010687 9998312
D Linux filesys. data 2012464 12010775 9998312
D Linux filesys. data 2012544 12010855 9998312
D Linux filesys. data 2012640 12010951 9998312
D Linux filesys. data 2012720 12011031 9998312
D Linux filesys. data 2012816 12011127 9998312
D Linux filesys. data 2012896 12011207 9998312
D Linux filesys. data 2012992 12011303 9998312
D Linux filesys. data 2013072 12011383 9998312
D Linux filesys. data 2013168 12011479 9998312
D Linux filesys. data 2013248 12011559 9998312
D Linux filesys. data 2013344 12011655 9998312
D Linux filesys. data 2013424 12011735 9998312
D Linux filesys. data 2013520 12011831 9998312
D Linux filesys. data 2013600 12011911 9998312
D Linux filesys. data 2013696 12012007 9998312
D Linux filesys. data 2013776 12012087 9998312
D Linux filesys. data 2013872 12012183 9998312
D Linux filesys. data 2014216 12012527 9998312
D Linux filesys. data 2014688 12012999 9998312
D Linux filesys. data 2014952 12013263 9998312
D Linux filesys. data 2015280 12013591 9998312
D Linux filesys. data 2024592 12022903 9998312
D Linux filesys. data 2024968 12023279 9998312
D Linux filesys. data 2025072 12023383 9998312
D Linux filesys. data 2025640 12023951 9998312
D Linux filesys. data 2026880 12025191 9998312
D Linux filesys. data 2027104 12025415 9998312
D Linux filesys. data 2027192 12025503 9998312
D Linux filesys. data 2027328 12025639 9998312
D Linux filesys. data 2027448 12025759 9998312
D Linux filesys. data 2027520 12025831 9998312
D Linux filesys. data 2027616 12025927 9998312
D Linux filesys. data 2027728 12026039 9998312
D Linux filesys. data 2028184 12026495 9998312
D Linux filesys. data 2028312 12026623 9998312
D Linux filesys. data 2028568 12026879 9998312
D Linux filesys. data 2028800 12027111 9998312
D Linux filesys. data 2029344 12027655 9998312
D Linux filesys. data 2029528 12027839 9998312
D Linux filesys. data 2029568 12027879 9998312
D Linux filesys. data 2029808 12028119 9998312
D Linux filesys. data 2030224 12028535 9998312
D Linux filesys. data 2030304 12028615 9998312
D Linux filesys. data 2030392 12028703 9998312
D Linux filesys. data 2030480 12028791 9998312
D Linux filesys. data 2034000 12032311 9998312
>D Linux filesys. data 2036632 12034943 9998312
D Linux filesys. data 2037576 12035887 9998312
D Linux filesys. data 2037704 12036015 9998312
D Linux filesys. data 2037816 12036127 9998312
D Linux filesys. data 2037904 12036215 9998312
D Linux filesys. data 2038048 12036359 9998312
D Linux filesys. data 2038208 12036519 9998312
D Linux filesys. data 2038376 12036687 9998312
D Linux filesys. data 2038576 12036887 9998312
D Linux filesys. data 2038720 12037031 9998312
D Linux filesys. data 2038960 12037271 9998312
D Linux filesys. data 2039168 12037479 9998312
D Linux filesys. data 2039368 12037679 9998312
D Linux filesys. data 2039584 12037895 9998312
D Linux filesys. data 2039872 12038183 9998312
D Linux filesys. data 2039976 12038287 9998312
D Linux filesys. data 2040064 12038375 9998312
D Linux filesys. data 2040168 12038479 9998312
D Linux filesys. data 2040400 12038711 9998312
D Linux filesys. data 2041056 12039367 9998312
D Linux filesys. data 2041736 12040047 9998312
D Linux filesys. data 2042152 12040463 9998312
D Linux filesys. data 2042616 12040927 9998312
D Linux filesys. data 2042664 12040975 9998312
D Linux filesys. data 2043160 12041471 9998312
D Linux filesys. data 2043232 12041543 9998312
D Linux filesys. data 2043344 12041655 9998312
D Linux filesys. data 2043400 12041711 9998312
D Linux filesys. data 2043480 12041791 9998312
D Linux filesys. data 2043736 12042047 9998312
D Linux filesys. data 2045296 12043607 9998312
D Linux filesys. data 2045392 12043703 9998312
D Linux filesys. data 2045648 12043959 9998312
D Linux filesys. data 2045776 12044087 9998312
D Linux filesys. data 2045888 12044199 9998312
D Linux filesys. data 2045944 12044255 9998312
D Linux filesys. data 2046008 12044319 9998312
D Linux filesys. data 2046176 12044487 9998312
D Linux filesys. data 2046240 12044551 9998312
D Linux filesys. data 2046328 12044639 9998312
D Linux filesys. data 2046480 12044791 9998312
D Linux filesys. data 2046576 12044887 9998312
D Linux filesys. data 2047176 12045487 9998312
D Linux filesys. data 2047336 12045647 9998312
D Linux filesys. data 2047416 12045727 9998312
D Linux filesys. data 2047520 12045831 9998312
D Linux filesys. data 2047600 12045911 9998312
D Linux filesys. data 2047984 12046295 9998312
D Linux filesys. data 2048216 12046527 9998312
D Linux filesys. data 2048264 12046575 9998312
D Linux filesys. data 2049600 12047911 9998312
D Linux filesys. data 2049648 12047959 9998312
D Linux filesys. data 2050696 12049007 9998312
D Linux filesys. data 2051808 12050119 9998312
D Linux filesys. data 2052000 12050311 9998312
D Linux filesys. data 2052096 12050407 9998312
D Linux filesys. data 2052264 12050575 9998312
D Linux filesys. data 2052440 12050751 9998312
D Linux filesys. data 2052768 12051079 9998312
D Linux filesys. data 2053032 12051343 9998312
D Linux filesys. data 2072000 12070311 9998312
D Linux Raid 12007424 14008303 2000880 [LS-WVL-EMF0E:10]
D Linux Swap 12007440 12007455 16
D Linux Swap 12007448 14008303 2000856
D Linux Raid 14008320 7796881007 7782872688 [LS-WVL-EMF0E:21]
D Linux filesys. data 14010368 7796883047 7782872680
D Linux filesys. data 1027160687 1029562246 2401560 [٫[:M-Yk^O^FM-5M-#yM-TM--]
D Linux filesys. data 1027160688 1029562247 2401560 [٫[:M-Yk^O^FM-5M-#yM-TM--]
D Linux filesys. data 3163164107 3167760893 4596787 [nnM-y/&M-Ej&M-'0~R^FM-/~S]
D Linux filesys. data 3163164108 3167760894 4596787 [nnM-y/&M-Ej&M-'0~R^FM-/~S]
. ]inux filesys. data 3384153741 3389970665 5816925 [~WSii^Q~^D^I
. ]inux filesys. data 3384153742 3389970666 5816925 [~WSii^Q~^D^I
D Linux filesys. data 7796883454 7797383165 499712
D Linux filesys. data 7796883456 7797383167 499712
D Linux filesys. data 7797383166 7813230589 15847424
D Linux filesys. data 7797383168 7813230591 15847424
D Linux Swap 7813230584 7813230599 16
>D Linux Swap 7813230592 7814035439 804848
P=Primary D=Deleted
Enter: to continue
SWAP2 version 1, pagesize=4096, 412 MB / 392 MiB
Unquote!
My questions are:
1. Which partition or patitions should I try to restore/ recover?
2. Is it possible to restore more than one partition (i.e., in the original manner), so that the NAS doesnt start formatting and reinstalling the firmware again on next boot up?
3. Less preferable but is it atleast possible to get the data partition back so that I can copy that folder and subfolders (/Media/Movies/.....) to another disk?
I have ordered another 12TB HDD in case I have to manually copy all data to another disk. I have access to both windows and linux machines.
Any help is much appreciated.
Thanks.
Re: Recovering partitions to original structure after Buffalo NAS formatted the disk
sfh1975 wrote: 20 Feb 2023, 06:07 My questions are:
Those whose content can be read by Testdisk.
I have no idea how your NAS operates, I don't even own one.
I don't know which one the data partition is nor do I know the answer to question 1. I can't do that work for you.
It might very well be that you have successfully overwritten your metadata information. Then you would need to use your commercial recovery program. Depending on the metadata remains available on your disk you might even be required to use Photorec.
