HPE MSA 1060 Volume showing RAW format on Windows Server 2012
sservais01
#1 Post by sservais01 »
Hello everyone, I need your help to solve my problem.
In fact we acquired a SAN storage device, the HPE MSA 1060. We've been using it for more than a month now and we had no problem until this morning.
We found that the iSCSI disk is unreadable on our Windows Server and presents the disk as a RAW format disk.
I searched the forum but couldn't find anything that helped. I tried what this link suggests but nothing positive.
Here is the link:
viewtopic.php?p=29977&hilit=iscsi+raw#p29977
I followed what is suggested in the last position. That is to say do:
Append --> /dev/sdb --> EFI GPT --> Analyze --> Quit and post the new testdisk.log here:
This is the content of testdisk.log ofter the operation:
Thu Feb 23 19:08:03 2023
TestDisk 7.2-WIP, Data Recovery Utility, February 2023
OS: Windows Server 2012 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=299966445568
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=7159458824192
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=299321554432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=7159439949824
Disk \\.\PhysicalDrive0 - 299 GB / 279 GiB - CHS 36468 255 63, sector size=512 - HPE LOGICAL VOLUME, S/N:PZXNN0BRHH16OY, FW:5.00
Disk \\.\PhysicalDrive1 - 7159 GB / 6667 GiB - CHS 870421 255 63, sector size=512 - HPE MSA 1060 iSCSI, S/N:00c0fff6145700007fffa16301000000, FW:I110
Disk \\.\PhysicalDrive1 - 7159 GB / 6667 GiB - HPE MSA 1060 iSCSI
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive1 - 7159 GB / 6667 GiB - CHS 870421 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=13983318015 (expected 13983318015)
hdr_lba_start=34
hdr_lba_end=13983317982
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34      32767      32734 [Microsoft reserved partition]
 2 P MS Data                    32768 13983313919 13983281152 [Basic data partition]
NTFS at 2/10/9
filesystem size           13983281152
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=16777216, part_size=7159439949824, sector_size=512
NTFS at 2/10/9
mftmirr_lcn               2
     NTFS, blocksize=4096, 7159 GB / 6667 GiB
file_win32_pread(544,11,buffer,13983318010(870421/73/47)) read err: read after end of file
file_win32_pread(544,8,buffer,13983318013(870421/73/50)) read err: read after end of file
file_win32_pread(544,14,buffer,13983318004(870421/73/41)) read err: read after end of file
file_win32_pread(544,14,buffer,13983318005(870421/73/42)) read err: read after end of file
file_win32_pread(544,14,buffer,13983318006(870421/73/43)) read err: read after end of file
file_win32_pread(544,14,buffer,13983318007(870421/73/44)) read err: read after end of file
file_win32_pread(544,14,buffer,13983318008(870421/73/45)) read err: read after end of file
file_win32_pread(544,14,buffer,13983318010(870421/73/47)) read err: read after end of file
file_win32_pread(544,14,buffer,13983318012(870421/73/49)) read err: read after end of file
file_win32_pread(544,14,buffer,13983318014(870421/73/51)) read err: read after end of file
 1 P MS Data                    32768 13983313919 13983281152
Thu Feb 23 20:23:39 2023
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 2/10/9
mftmirr_lcn               2
NTFS at 2/10/9
mftmirr_lcn               2
file_win32_pread(524,11,buffer,13983318010(870421/73/47)) read err: read after end of file
file_win32_pread(524,8,buffer,13983318013(870421/73/50)) read err: read after end of file
file_win32_pread(524,14,buffer,13983318004(870421/73/41)) read err: read after end of file
file_win32_pread(524,14,buffer,13983318005(870421/73/42)) read err: read after end of file
file_win32_pread(524,14,buffer,13983318006(870421/73/43)) read err: read after end of file
file_win32_pread(524,14,buffer,13983318007(870421/73/44)) read err: read after end of file
file_win32_pread(524,14,buffer,13983318008(870421/73/45)) read err: read after end of file
file_win32_pread(524,14,buffer,13983318010(870421/73/47)) read err: read after end of file
file_win32_pread(524,14,buffer,13983318012(870421/73/49)) read err: read after end of file
file_win32_pread(524,14,buffer,13983318014(870421/73/51)) read err: read after end of file
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Re: HPE MSA 1060 Volume showing RAW format on Windows Server 2012
You can try
- "chkdsk /f d:" (Replace d: by the correct drive letter).
- testdisk, Advanced, List
If it doesn't work, it's probably best to restore from backup
