Sage / Simply Accounting Files
shamal
#1 Post by shamal »
I would like to propose 2 file extenions for TestDisk and Photrecovery.
Thet are SDW and SDB, extensions used by Sage Software an accounting program known also as Simply Accounting.
Both of these extension files are used by the file-save procedure, and are required for the program to open a file.
I have tested these using your URL test page, and got negative results.
Thank you for any help.
Both programs work very well for me, no problems, excellent recovery results. I am working with images created using dd.
Albie
Re: Sage / Simply Accounting Files
I have found the sdw file you uploaded but not the other one.
I have published a new 7.2-WIP version. With it, the sdw file is recognized:
https://www.cgsecurity.org/photorec/sca ... 83698859e3
