CHS and LBA don't match
havrenomode
#1 Post by havrenomode »
Tried recovering some files via testdisk but not sure what step to take next.
If anyone has some time to help guide me on my next step, I would appreciate the help.
The disk is a 128gb Lexar CF card.
Tried dumping the photos via card reader and shows no files in the card, but card shows it has less than half the space available.
This is the screen message I got on testdisk
___________
TestDisk 7.2-WIP, Data Recovery Utility, February 2023
Disk /dev/disk1 - 128 GB / 119 GiB - 250085376 sectors
Warning: number of heads/cylinder mismatches 16 (FAT) != 1 (HD)
Warning: number of sectors per track mismatches 63 (FAT) != 1 (HD)
1 P FAT32 LBA 63 250085375 250085313 [EOS_DIGITAL]
___________
Appreciate any help.
Re: CHS and LBA don't match
Use Photorec instead.
havrenomode
#3 Post by havrenomode »
on photorec I receive the following message:
____________________
Disk capacity must be correct Referenced from: /var/root/Desktop/testdisk-7.2-WIP/photorecisted above has an incorrect size, check HD jumper settings and BIOS
detection, Expected in: /usr/lib/libSystem.B.dylibk drivers.
dyld: Symbol not found: ____chkstk_darwin
Abort trap: 6
logout
-n Saving session...
-ne
...copying shared history...
-ne
...saving history...
-n truncating history files...
-ne
completed.
[Process completed]
_____________________
Please check if you comply with the Apple requirements. Read Chapter 6, "Starting the tools".
