I want to delete, not undelete
jidanni
#1 Post by jidanni »
I want to delete, not undelete. Alas, all I can choose is:
Use Left arrow to go back, Right to change directory, h to hide Alternate Data Stream
q to quit, : to select the current file, a to select all files
C to copy the selected files, c to copy the current file
No, I cannot delete the normal way:
ntfs_mst_post_read_fixup_warn: magic: 0x00000000  size: 4096   usa_ofs: 0  usa_count: 0: Invalid argument
Corrupt index block signature: vcn 0
# \rm -rf  xxxx/BADDIR
rm: cannot remove 'xxxx/BADDIR': Directory not empty
# find xxxx/BADDIR
Input/output error
By the way, q is mislabeled. It doesn't quit. It just goes back one view or climbs up one directory.
There is no quit command.
Re: I want to delete, not undelete
Testdisk is not a program to delete files but to recover information.
