delete files after being recovered
Mike420
#1 Post by Mike420 »
i want to delete the files that where recovered, that i dont want. when i go to its location to where files where saved i click the delete button but it says access denied how can i delete these files?
Re: delete files after being recovered
Make sure that you have the necessary rights and that you do not store anything on your broken source disk.
Mike420
#3 Post by Mike420 »
"Change the owner of the files, example sudo chown -R username recup_dir.* or sudo chown -R username /home/username/testdisk-6.14/recup_dir.*
im using thiese commands keep in mind im new to this whole linux. but in my case im not sure how i would write the code. any guidance would help please and thank you
Mike420 wrote: 14 Apr 2023, 14:28 "Change the owner of the files, example sudo chown -R username recup_dir.* or sudo chown -R username /home/username/testdisk-6.14/recup_dir.*
I had to look this up on the internet.
https://stackoverflow.com/questions/832 ... l-contents
Instead of changing the owner you could enable rights "free for all style":
chmod -R 777 /home/username/testdisk-6.14/
Mike420
#5 Post by Mike420 »
im using Manjaro will this work on majaro? also is the 6.14 the version of testdisk? do i need to change that?
#6 Post by recuperation »
Mike420 wrote: 14 Apr 2023, 15:42 im using Manjaro will this work on majaro? also is the 6.14 the version of testdisk? do i need to change that?
What is majaro as opposed to Manjaro?
What is "this"? Try to be specific and prevent misinterpretation.
The most recent version of Testdisk is 7.2-WIP.
SystemRescueCD, Gparted-Live, Knoppix-CD and Knoppix-DVD have version 7.1 of Testdisk built in.
I prefer Linux Mint with the XFCE desktop. You can run Linux Mint in Live Mode (without installation) When keying in "testdisk" in a shell you are being told what to do to install Testdisk. You just need a working internet connection.
https://www.cgsecurity.org/wiki/TestDisk_Livecd
When trying to run the most recent version 7.2-WIP (which is not beta software but rather the most current version) you don't need to compile the Testdisk source code. You can download precompiled binaries:
https://www.cgsecurity.org/wiki/OS_Note ... d_binaries
