External hard drive mistakenly formatted while creating a bootable key
vince99
#1 Post by vince99 »
"Hello,
I created a bootable key to install the latest Linux Mint, and by mistake (in haste), I created the "bootable key" on the 1.5TB HD where I kept my backups. As a result, I lost all my data.
I ran TestDisk, but it couldn't find any partitions initially. Then, while trying to go back (pressing 'q'), it started a 'cylinder analysis'.
The result of this analysis is as follows:
Christophe GRENIER grenier@cgsecurity.org
Disk /dev/sda - 1500 GB / 1397 GiB - CHS 182397 255 63
The harddisk (1500 GB / 1397 GiB) seems too small! (< 3000 GB / 2794 GiB)
It's better to see it in an image:
testdisk
testdisk
Capture d’écran du 2023-07-26 18-08-41 cadre.png (52.61 KiB) Viewed 161061 times
Does anyone have an idea of what this means?
Could creating a 'bootable key' on my HD interfere with TestDisk's analysis of the disk?
Would it be better for me to remove the Linux installation files from the disk to have a greater chance of data recovery?
Or any other suggestions, of course.
Thank you for your responses.
Re: External hard drive mistakenly formatted while creating a bootable key
Please upload your picture on this website using the attachments tab to the left on the bottom of this page.
vince99
#3 Post by vince99 »
I tried a new search by selecting 'EF GPT' and I got the following message:
Capture d’écran du 2023-07-29 13-12-59.png (35.99 KiB) Viewed 160950 times
Should I try selecting other options?
Does anyone have any other ideas?
Thank you.
vince99 wrote: 27 Jul 2023, 11:43 "Hello,
There is a small partition at the end of the disk.
You should not create another one before having finished all your recovery efforts.
Do not alter the crime scene unless being in certain corner cases where Testdisk is awakening the death.
vince99
#5 Post by vince99 »
Thank you recuperation.
"Oh no, I don't want to create anything more :? , I just wanted to know if creating the bootable key beforehand could hinder TestDisk's analysis when it is searching for partition table.
I must have made a poor translation.
While searching on this forum, I found Jamsah's case and I was wondering if I could try this solution?
Screenshot 2023-07-29 at 21-00-22 the following partition can't be recovered_ filesystem damaged - cgsecurity.org.png
Screenshot 2023-07-29 at 21-00-22 the following partition can't be recovered_ filesystem damaged - cgsecurity.org.png (114.48 KiB) Viewed 160910 times
Is it dangerous for the data? Should I create an image of the disk first?"
Thank you.
