ive been looking for a way to recover my usb that has been configured for use with my xbox360, it has my profile and saves on it. problem is, pcs cant read xbox "language" without special software like this: https://gruntmods.com/usb-xtaf-explorer/ in my search i was recommended testdisk/photorec
i tried the testdisk exe, and got to a point where i got these options: "A: add partition, L: Load backup, Enter: to continue" pressing enter gives me a message that says "No partition found or selected for recovery", has it simply not found anything or should i add partition? i dont want to accidentally do something that overwrites or breaks something, i dont really know what this option does exactly
after this i tried the photorec exe, it gave me xbox stuff for sure, but its only a few hundred mb, mostly .png, .avi, .wav and .txt etc, with a few .gz or .tff, basically screenshots, menu icons, intro movies and that kind of thing, i had something like 12 gb on that usb. the photorec exe didnt have any option for xbox like the testdisk one did - it seems like it couldnt see most of it? it also gave me all that in 4 different folders which i thought was kinda weird
how i got here is, i had bought a 2nd xbox360 i wanted to use for a backup, i formatted a usb in the 1st xbox, but when i put it in the 2nd xbox, it couldnt see what was on there for some reason and only gave me the option to configure it again. so i decided to try that, then transfer everything again, even tho it took a long time
well my dumb ass assumed it copied the files, but it moves them. so i just formatted the usb with my 14 or 15 year old profile and a bunch of my saves with no backup. now instead of making a backup, im looking for ways to get my stuff back. i made it way worse lol
i cancelled the format as soon as i started it when i realized i should probably check what it does
i dont own much other than my xbox. so if someone can show me how i can fix all this, itll be a massive save
Recovering an xbox360 usb
Re: Recovering an xbox360 usb
USB is an interface. Please specify exactly for what kind of device your "usb" stands for.
Your download contains a manual in the pdf file format. Further documentation is online:
Photorec typically does not need that information. You can provide this information by use of the command line. Search your manual for the term "xbox"!
As recovery tool of last resort Photorec tries to recover files that are saved in one folder after another. Photorec does not recover metada information such as folder structures.like the testdisk one did - it seems like it couldnt see most of it? it also gave me all that in 4 different folders which i thought was kinda weird
e3e33e33e3ee3e3e3
its a usb flash drive, which i put my xbox profile and game saves onrecuperation wrote: 25 Sep 2023, 21:51USB is an interface. Please specify exactly for what kind of device your "usb" stands for.Your download contains a manual in the pdf file format. Further documentation is online:
https://www.cgsecurity.org/wiki/TestDisk_Step_By_StepPhotorec typically does not need that information. You can provide this information by use of the command line. Search your manual for the term "xbox"!
after this i tried the photorec exe, it gave me xbox stuff for sure, but its only a few hundred mb, mostly .png, .avi, .wav and .txt etc, with a few .gz or .tff, basically screenshots, menu icons, intro movies and that kind of thing, i had something like 12 gb on that usb. the photorec exe didnt have any option for xboxAs recovery tool of last resort Photorec tries to recover files that are saved in one folder after another. Photorec does not recover metada information such as folder structures.like the testdisk one did - it seems like it couldnt see most of it? it also gave me all that in 4 different folders which i thought was kinda weirdhow i got here is, i had bought a 2nd xbox360 i wanted to use for a backup, i formatted a usb in the 1st xbox, but when i put it in the 2nd xbox, it couldnt see what was on there for some reason and only gave me the option to configure it again. so i decided to try that, then transfer everything again, even tho it took a long time
i tried running testdisk again - selecting xbox, it says "bad xbox partition, invalid signature". i read that it defaults to whatever it detects as the partition type, and found that it defaults to "none", so i decided to try that. it showed me a partition, with a certain number of sectors which, after i did the conversions, was the correct 15 gb. so i went ahead and copied the files, even though it was shown as fat32. but when i did this, even though what im after should be 15 gb, it gave me a file of only 8,192 kb.
this is similar to what happens with photorec, where what i got was only 367 mb. i found the option for keeping corrupted files and this only got it to 374 mb
so, unless im reading the "number of sectors" wrong or theres something i dont know, im confident theres 15 gb there, and that there is xbox stuff on it from looking at the files i got - but i cant seem to get it all back
also, in photorec, i enabled all filetypes and turned on advanced mode, when i went to start analysing again, i got "Try to unformat a FAT filesystem (Y/N)" what will this do?
also, how can i enter commands, to have it look for xbox stuff?
Photorec will try to reverse the FORMAT command on a FAT32 partition. The xbox file system seems to be a FAT32 derivate. Running this function may be detrimental.e3e33e33e3ee3e3e3 wrote: 27 Sep 2023, 14:37 also, in photorec, i enabled all filetypes and turned on advanced mode, when i went to start analysing again, i got "Try to unformat a FAT filesystem (Y/N)" what will this do?
There is no need for that.
