Recovering a partition from a drive that stopped working after a few weeks of disuse?
ryutis
#1 Post by ryutis »
A few weeks ago I suffered a catastrophic Windows failure and decided to just leave the machine alone for a while. Last night I pulled the drives out and was able to access all of them (currently on OSX and using an NTFS driver but I have a Windows VM set up as well) except one, it refuses to connect. OSX says it can't recognize the disk though it recognizes the container (but no partitions appear) and Windows' Disk Management says the drive is 'dynamic' and 'invalid'. The drive is a ""1TB"" (931GB) WD10EZEX-00BN5A0 and it was working flawlessly before the Windows installation on my other drive kicked the bucket though the drive was always around 99.99% full but it never seemed to complain. I've booted up testdisk, selected the drive > Intel > Analyse > Quick Search and it seems to find my old partition (with its actual name) after just a few seconds. If I stop the scan after that it tells me that it can't be recovered. What do?
Re: Recovering a partition from a drive that stopped working after a few weeks of disuse?
Please continue the recovery process using deep search as described here:
ryutis
#3 Post by ryutis »
recuperation wrote: 18 Nov 2023, 22:09 Please continue the recovery process using deep search as described here:
I already ran it under the Windows VM but I was tired and didn't think about saving the logs, here's the screenshot of what it found after the deep search. Currently running it again, saving logs this time in case they're useful. Unfortunately I still got that same error after that first deep scan so I can't proceed with the rest of the recovery.
ryutis
#4 Post by ryutis »
It completed again. Here's the log.
Mon Nov 20 05:20:44 2023
TestDisk 7.2-WIP, Data Recovery Utility, February 2023
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=274877906944
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=274322161664
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
Disk \\.\PhysicalDrive0 - 274 GB / 256 GiB - CHS 33418 255 63, sector size=512 - Parallels Virtual NVMe Disk, S/N:AD41_6D90_6813_CF4F_80FC_14F6_65F0_B8CA.
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 EZEX-00BN5A0, S/N:000000125326, FW:01.0
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - WDC WD10 EZEX-00BN5A0
Analyse Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63
check_part_i386 1 type 42: no test
 1 P W2K Dynamic/SFS          0   1  1 121601  48 31 1953523057
NTFS at 63/221/31
filesystem size           1953517568
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS             63 221 31 121664 181 53 1953517568 [Games]
This partition ends after the disk limits. (start=1026048, size=1953517568, end=1954543615, disk end=1953525168)
BAD_RS LBA=4730476522 14920069
     FAT32 LBA            294458 138 59 346310 109 31  833000526
This partition ends after the disk limits. (start=4730476522, size=833000526, end=5563477047, disk end=1953525168)
The hard disk (1000 GB / 931 GiB) seems too small! (< 2848 GB / 2652 GiB)
NTFS at 63/188/61
mftmirr_lcn               2
NTFS part_offset=524287488, part_size=1000200994816, sector_size=512
NTFS at 63/221/30
filesystem size           1024000
mft_lcn                   42666
mftmirr_lcn               2
     HPFS - NTFS              0  32 33    63 221 30    1024000
     NTFS found using backup sector, blocksize=4096, 524 MB / 500 MiB
NTFS at 63/221/31
mftmirr_lcn               2
The hard disk (1000 GB / 931 GiB) seems too small! (< 1000 GB / 931 GiB)
   * HPFS - NTFS              0  32 33    63 221 30    1024000
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
   P HPFS - NTFS              0  32 33    63 221 30    1024000
 1 P HPFS - NTFS              0  32 33    63 221 30    1024000
ryutis
#5 Post by ryutis »
Nope, still trying to get it to work. Someone suggested installing it back in the original machine but it's not possible at this moment.
ryutis
#6 Post by ryutis »
Still stuck. Any suggestions?
#7 Post by recuperation »
You might have unreadable sectors.
Check your SMART parameters and publish your logfile here:
viewtopic.php?f=5&t=10910
It might be necessary to duplicate your drive using ddrescue as described in the manual.
If Testdisk can't help you reading the duplicate you would need to try commercial third party software.
ryutis
#8 Post by ryutis »
recuperation wrote: 28 Nov 2023, 18:12 You might have unreadable sectors.
Hello, thanks for the help. I've attached the logfiles - diskutil lists the disk under two names so I did both and named the files accordingly. /dev/disk2s1 was the one labeled 'Windows_LDM'
I've tried using both a Sabrent and UGREEN SATA to USB 3 adapters if that matters at all - both are powered by an external power supply of course.
Should I skip straight to ddrescue? I think I might've accidentally created a new partition with testdisk the very first time I booted it up and scanned the drive.
dev-disk2s1.txt
(4.55 KiB) Downloaded 2011 times
dev-disk2.txt
(4.55 KiB) Downloaded 2147 times
#9 Post by recuperation »
I can't find any source of physical dammage in your logfiles.
As there may be some now missing electronics in your enclosure for sector size emulation you should rerun Testdisk with the disk being put in the enclosure. If that fails use Photorec or a third party tool.
ryutis
#10 Post by ryutis »
recuperation wrote: 29 Nov 2023, 07:24 I can't find any source of physical dammage in your logfiles.
Alright, I guess installing the drive back in the original motherboard was inevitable.
I'll let you know if anything changes once I've installed it back on the original motherboard and installed a copy of Windows on another drive, thanks for the help.
Hope the drive just works again, if it doesn't I need to run a deep scan with testdisk again and hope it says it can recover the partition, right?
