Need files back-XQD Memory Card
nguest71
#1 Post by nguest71 »
Hello! I deleted files from an Sony XQD Memory Card and ran Sony's recovery software (before I discovered you guys) :) and the software pulled over 3K worth of files.
Of those files I can see 13 of them. The others I can see the their size and clearly there is something there because I can see the size of the file and it is definitely the normal size for my images; however when I pull them into Lightroom I am unable to open them and view. The card isn't damaged. Should I use your process to go deeper into the process to extract those files? Thanks in advance for any help you can provide.
Re: Need files back-XQD Memory Card
nguest71 wrote: 11 Dec 2023, 15:19 Hello! I deleted files from an Sony XQD Memory Card and ran Sony's recovery software (before I discovered you guys) :) and the software pulled over 3K worth of files.
What is it that makes you refrain from using software from cgsecurity.com?
If that was my card I would have tried out everything.
By the way, I don't know what "your process" is and knowing (and telling!) the name of the file system used would be a definitive advantage.
#3 Post by cgrenier »
If you have used PhotoRec to recover lost videos but the recovered files don't play despite having what seems to be the correct size, try what is explained on
https://www.cgsecurity.org/testdisk_doc ... video.html
