Testdisk reporting excessive disk size
gmilliorn
#1 Post by gmilliorn »
My disk became RAW: after my graphics card committed suicide. I've been running TestDisk and
so far finding nothing. In diskmgr i see:
which is odd because both disk 0 and 1 are 2TB disks.
Running Testdisk most recently shows this (I've run multiple times, takes about 8 hrs or so):
Mon Dec 11 16:03:55 2023
TestDisk 7.2-WIP, Data Recovery Utility, February 2023
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499460190208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=4000773570560
Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000VN004-2E4164, S/N:Z5293ZTD, FW:SC60
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000VN004-2E4164, S/N:Z529403A, FW:SC60
Disk \\.\PhysicalDrive2 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Samsung SSD 970 EVO 500GB, S/N:0025_385A_0144_5D9D., FW:2B2QEXE7
Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - ST2000VN004-2E4164
Analyse Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - CHS 243201 255 63
 1 P EFI GPT                  0   0  2 267349  89  4 4294967295
Bad sector count.
recover_EXT2: s_block_group_nr=0/18, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 622544
recover_EXT2: part_size 4980352
Filesystem created: Fri Dec 20 17:08:32 2019
Last mount time:    Sat Dec 28 09:34:52 2019
     Linux                    0  32 33   310  35 45    4980352 [1.42.6-23824]
     ext4 blocksize=4096 Large_file Sparse_SB, 2549 MB / 2431 MiB
BAD_RS LBA=2954758104 3206608
     FAT16 LBA            183925  47 19 295319 134  3 1789550076
This partition ends after the disk limits. (start=2954758104, size=1789550076, end=4744308179, disk end=3907029168)
BAD_RS LBA=4018951817 16099123
     FAT32 LBA            250168  45 63 308937 246 14  944136600
This partition ends after the disk limits. (start=4018951817, size=944136600, end=4963088416, disk end=3907029168)
BAD_RS LBA=4210342367 361558
     FAT12                262081 176 15 520159 142 60 4146020974
This partition ends after the disk limits. (start=4210342367, size=4146020974, end=8356363340, disk end=3907029168)
The hard disk (2000 GB / 1863 GiB) seems too small! (< 4278 GB / 3984 GiB)
   * Linux                    0  32 33   310  41 51    4980736 [1.42.6-23824]
     ext4 blocksize=4096 Large_file Sparse_SB, 2550 MB / 2432 MiB
dir_partition inode=2
ext2fs_dir_iterate failed with error 2133571363.
interface_load
Change partition type:
   * ext4                     0  32 33   310  41 51    4980736 [1.42.6-23824]
 1 * Linux                    0  32 33   310  41 51    4980736 [1.42.6-23824]
NTFS at 1/5/5
filesystem size           7814010880
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS              1   5  5 486400 178 50 7814010880
     NTFS, blocksize=4096, 4000 GB / 3726 GiB
This partition ends after the disk limits. (start=16384, size=7814010880, end=7814027263, disk end=3907029168)
Disk 0 is the failing disk, which used to be "F:". Disk 1 is only there for pending backup/copy purposes. Both
are 2TB disks, but Windows DiskMgr shows the failed disk as 3.726GB somehow.
Running testdisk, scan and deepscan seem to always insist it is Linux EXT4, but this has only been used for
Windows and is FAT32 as best I recall. Forcing the FS type to NTFS or FAT32 shows no files. PhotoRec
does find lots of files, though, so data is still there.
When I look at the logs, it seems like TestDisk is also annoyed by the incorrect size.
https://milliorn.org/testdisk1.log
Is that related? Is this "incorrect size" related to why I can't find files/a filesystem?
Here's a snippet of PhotoRec.log if interesting:
en
translator not installed
Tue Dec 12 08:59:25 2023
PhotoRec 7.2-WIP, Data Recovery Utility, February 2023
Compiler: GCC 11.2, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, ewf lib: 20140608, libjpeg: libjpeg-turbo-2.1.1
Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB (RO) - ST2000VN004-2E4164
 1 P MS Reserved              0   0 35     2  10  8      32734 [Microsoft reserved partition]
 2 P MS Data                  2  10  9 486401 183 54 7814010880 [Basic data partition]
     Unknown                  0   0  1 243201  80 63 3907029168 [Whole disk]
742 first-level signatures enabled
blocksize=1024, offset=0
C:/recover1/recup_dir.1/f0002050.ext	 2050-2051
C:/recover1/recup_dir.1/f0016400.mft	 16400-16401
C:/recover1/recup_dir.1/f0016402.mft	 16402-16403
C:/recover1/recup_dir.1/f0016404.mft	 16404-16405
C:/recover1/recup_dir.1/f0016406.mft	 16406-16407
C:/recover1/recup_dir.1/f0016544.xml	 16544-16549
C:/recover1/recup_dir.1/f0031096.xml	 31096-31103
C:/recover1/recup_dir.1/f0031104.jpg	 31104-31203
where it seems to find MSoft partitions
Thanks for any suggestions!
Re: TestDisk
Have you removed your disk from an external housing when trying to rescue your data?
Did you partition the disk?
If so, did you choose GPT or MBR?
The log entries rather suggest that you used the GPT scheme.
It seems very strange to me that the Photorec logfile shows different partition information than Testdisk does.
It appears to me that you are doing something wrong but I don't know what that is, unfortunately.
gmilliorn
Re: TestDisk
#3 Post by gmilliorn »
Thanks for responding.
The disk is in a desktop PC attached to a SATA port.
I don't have a record of when I first attached it, however it was not intended to be
bootable so I believe I just partitioned it to whatever Windows offered to use the
entire disk. It probably was GPT, as you say.
Looking at TestDisk's filesystem report, it shows:
> 1 P MS Reserved                   34      32767      32734 [Microsoft reserved partition]
  2 P MS Data                    32768 7814043647 7814010880 [Basic data partition]
TestDisk correctly identified the disk info (2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512) which all checks out,
so I guess not only the GPT but something important to the filesystem got wiped out as well? I am not seeing an option about
that though.
Re: TestDisk
Your statement
> The disk is in a desktop PC attached to a SATA port."
does not answer my question
unfortunately.
Try to follow the standard procedure outlined in
and don't forget to check each partition for recoverable content using the p-key ("list files").
Using "Testdisk" as a title for a posting leaves others successfully in the dark which is sad.
gmilliorn
Re: Testdisk reporting excessive disk size
#5 Post by gmilliorn »
No, it is and still was on a motherboard SATA port.
As of 36 hours of quick search + deeper search, the status is:
Analyse cylinder 193485/243200: 79%
  Mac HFS                373519215  407073904   33554690
  Mac HFS                339964529  373519218   33554690
  Mac HFS                396905541 3263204760 2866299220 ["M-w DM-g M-;Q~] i^X^C^B^DJUm^D]
  Mac HFS                431967556  432065989      98434
  Mac HFS                431869126  431967559      98434
  Linux filesys. data    647516131  655383471    7867340 [wH^?M-$^HT M-&~CM-H;Xv]
  Linux filesys. data    647516132  655383472    7867340 [wH^?M-$^HT M-&~CM-H;Xv]
  Mac HFS                798529199  856200919   57671721
  Mac HFS                740857482  798529202   57671721
  Linux filesys. data    836536283  844403623    7867340 [wH^?M-$^HT M-&~CM-H;Xv]
  Linux filesys. data    836536284  844403624    7867340 [wH^?M-$^HT M-&~CM-H;Xv]
  Mac HFS                850602815 4947984766 4097381952 [BM-?M-R~A^^~? M-%9^B]
  Mac HFS                874768826 1513875899  639107074
  Mac HFS                235661756  874768829  639107074        check_FAT: Bad jump in FAT partition        check_FAT: Bad jump in FAT partition                              72 [^GM-<Y~Q
M-$,^B^BFM-1^WM->^\^[^^-~\^W~]9M- M-#M-)M-/~Q Ka        check_FAT: Bad jump in FAT partition
check_FAT: Bad jump in F3062387899 22874242966639801 22874239904251904
The first 6 were found on the previous run, zero of them contained any files using 'p'.
Since this disk was never Mac HFS or Linux, not really surprising. I am letting it run to
completion anyway, it will probably take 4-5 more hours. Perhaps it will find a windows GPT somewhere.
