Keeping existing partitions Topic is solved
gonecurl
#1 Post by gonecurl »
I'm using TestDisk in Windows 10.
I had two partitions:
  MS Data      264192 10737682431 10737418240 [Partition A]
  MS Data 17180133376 23437766655  6257633280 [Partition B]
Unfortunately, Partition A was deleted by a supposedly reliable partition resizer. I did a scan with TestDisk and found this:
D MS Data      264192 23437768703 23437504512 [Old Partition A]
Originally, Partition A had taken the whole disk. At some point in the past, I resized it and added Partition B.
I checked the file list and it looked good. I knew I would lose Partition B if I restored this, so I copied everything from Partition B to another drive. Then I restored Old Partition A.
Hooray! TestDisk worked. :D I was able to access everything from Partition A. I resized it back to what I wanted.
This what I now see in the current scan results:
P MS Data      264192 10737682431 10737418240 [Partition A]
The problem is that I want to restore Partition B. When I do a quick search, I get this:
D MS Data 17180133376 23437766655  6257633280 [Partition B]
All the data seems to be there. I can browse the file list and it looks fine. However, I don't see Partition A. I only see the Old Partition A that I used for the original restore. I don't want that.
My question is: if I restore Partition B, will it delete the current Partition A?
Thanks!
Re: Keeping existing partitions
Logfile?!
gonecurl
#3 Post by gonecurl »
Hi recuperation,
Is the log file necessary? I'm asking a general question about how this program works.
Before I start "Quick Search" it shows the existing partition.
After the scan, I see the missing partition and not the existing one.
Is it going to keep the existing one if I restore the missing one?
gonecurl
#4 Post by gonecurl »
[Details moved to first post]
gonecurl
#5 Post by gonecurl »
I'm still not clear on this. I don't want to lose the current partition.
Can anyone confirm the behavior of TestDisk?
Should I also see the active partition in quick search? Or is it safe to restore Partition B without that?
gonecurl
#6 Post by gonecurl »
I manually restored the Partition B files from backup.
It's disappointing not to get an answer. I think others will have this question:
Does TestDisk delete an existing partition if it isn't in the quick search list?
However, TestDisk did get Partition A back for me and that saved me a lot of time and work.
Thank you!
