I have a dual boot system with Windows 11 and Debian 12. I have a external hard drives in a teramaster case connected via USB-C. In Debian I have been digitizing my dvd collection with MakeMKV and saving to one of the external drives, with a goal of setting up a home media server. After about two weeks in only Debian I logged into Windows. When I went to directory via Windows Explorer with the new videos Windows said the file was in invalid location and could not be opened. I right clicked on the drive and went to properties>tools and ran the check disk for errors. No errors found. Next I ran disk optimization tool and it completed. Now all the video files and directories are gone. I booted into Debian and the files are gone there too. Testdisk says there are no deleted files, which I can understand since I didn't delete anything.
Wed Dec 27 19:44:47 2023
OS: Linux, kernel 6.1.0-16-amd64 (#1 SMP PREEMPT_DYNAMIC Debian 6.1.67-1 (2023-12-12)) x86_64
Compiler: GCC 12.2
ext2fs lib: 1.47.0, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.3
/dev/sda: LBA, LBA48, DCO support
/dev/sda: size 7813971633 sectors
/dev/sda: user_max 7813971633 sectors
/dev/sdb: LBA, HPA, LBA48 support
/dev/sdb: size 500118192 sectors
/dev/sdb: user_max 500118192 sectors
/dev/sdb: native_max 500118192 sectors
/dev/sdb: dco 500118193 sectors
Warning: can't get size for Disk /dev/loop0 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop1 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop2 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop3 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop4 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop5 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop6 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop7 - 0 B - 0 sectors, sector size=512
Disk /dev/sda - 4000 GB / 3725 GiB - CHS 486397 255 63, sector size=512 - WDC WD40EZRZ-00WN9B0, S/N:WD-WCC4E3JH00NN, FW:80.00A80
Disk /dev/sdb - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - MKNSSDRE256GB, S/N:MK15070810003B3D6, FW:N1007C
Disk /dev/sdc - 8001 GB / 7452 GiB - CHS 7630885 64 32, sector size=512 - TDAS TerraMaster
Disk /dev/sdd - 8001 GB / 7452 GiB - CHS 7630885 64 32, sector size=512 - TDAS TerraMaster
Disk /dev/sde - 8001 GB / 7452 GiB - CHS 7630885 64 32, sector size=512 - TDAS TerraMaster
Disk /dev/sdf - 8001 GB / 7452 GiB - CHS 7630885 64 32, sector size=512 - TDAS TerraMaster
Disk /dev/nvme0n1 - 1000 GB / 931 GiB - CHS 953869 64 32, sector size=512
Disk /dev/sde - 8001 GB / 7452 GiB - TDAS TerraMaster
Partition table type: EFI GPT
Analyse Disk /dev/sde - 8001 GB / 7452 GiB - CHS 7630885 64 32
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=15628053167 (expected 15628053167)
hdr_lba_start=34
hdr_lba_end=15628053134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Reserved 34 32767 32734 [Microsoft reserved partition]
2 P MS Data 32768 15628050431 15628017664 [Pine] [Film]
NTFS at 16/0/1
filesystem size 15628017664
mftmirr_lcn 2
NTFS part_offset=16777216, part_size=8001545043968, sector_size=512
NTFS at 16/0/1
mftmirr_lcn 2
MS Data 32768 15628050431 15628017664 [Film]
NTFS, blocksize=4096, 8001 GB / 7452 GiB
P MS Data 32768 15628050431 15628017664 [Film]
echo "0 15628017664 linear /dev/sde 32768" | dmsetup create test0
1 P MS Data 32768 15628050431 15628017664 [Film]
NTFS at 16/0/1
mftmirr_lcn 2
NTFS at 16/0/1
mftmirr_lcn 2
cramfs Marker at 60421/10/32
recover_cramfs
Linux filesys. data 123742559 129822029 6079470 [<èóü“å z•5#]]
cramfs, 3112 MB / 2968 MiB
cramfs Marker at 60421/11/1
recover_cramfs
Linux filesys. data 123742560 129822030 6079470 [<èóü“å z•5#]]
SYSV4 Marker at 513678/44/8
recover_sysv4
Unknown 1052013959 7156024570 6104010612 [çWgÒH]
SysV4, 3125 GB / 2910 GiB
Partition not added.
LVM magic value at 679857/0/19
HFS magic value at 731390/21/14
part_size 2315796546
Mac HFS 1497887405 3813683950 2315796546
HFS blocksize=67108864, 1185 GB / 1104 GiB
HFS magic value at 731390/21/16
cramfs Marker at 1041731/39/3
recover_cramfs
Linux filesys. data 2133466338 2135736259 2269921 [f#¥ÓVŠþÙ´ÜË"ÈÝF]
cramfs, 1162 MB / 1108 MiB
cramfs Marker at 1041731/39/4
recover_cramfs
Linux filesys. data 2133466339 2135736260 2269921 [f#¥ÓVŠþÙ´ÜË"ÈÝF]
HFS magic value at 1068540/33/32
part_size 4154782
Mac HFS 2188371007 2192525788 4154782 [ÊÙÂ'Ád|Â4Ë&rã \·þ¾.(v²]
HFS blocksize=32768, 2127 MB / 2028 MiB
HFS magic value at 1068540/34/2
part_size 4154782
Mac HFS 2184216229 2188371010 4154782 [ÊÙÂ'Ád|Â4Ë&rã \·þ¾.(v²]
HFS found using backup sector!, 2127 MB / 2028 MiB
LVM magic value at 1302646/19/8
Unknown 2934085607 34569748022990822 34569745088905216 [5He†´n-+ÿ|âÅbBÄ<]
BeFS blocksize=131072, 17699709 TB / 16097792 TiB
LVM magic value at 1526092/44/30
LVM magic value at 1696627/0/19
LVM magic value at 1731247/59/22
LVM magic value at 2090861/14/30
Unknown 4443541553 23181180006362440 23181175562820887 [¥e,ϨÂmHÉší"®²U8¦Ù-¦È€?F“Œº5Þ]
BeFS blocksize=1, 11868761 TB / 10794576 TiB
Unknown 4505284294 63125359046341 63120853762048
WBFS, 32317 TB / 29392 TiB
Unknown 4528262734 63125382024781 63120853762048
Unknown 4530452049 8783329661428426 8783325130976377 [/ê1´`ñ_AJjÐ’GsŽ»¡oν¹s…à:ƒVª]
BeFS blocksize=32, 4497062 TB / 4090054 TiB
Unknown 4575914478 63125429676525 63120853762048
Unknown 4650938838 63125504700885 63120853762048
Unknown 4792848717 18014403302330700 18014398509481984
WBFS, 9223372 TB / 8388608 TiB
Unknown 5013979849 8783330144956226 8783325130976377 [/ê1´`ñ_AJjÐ’GsŽ»¡oν¹s…à:ƒVª]
Unknown 5205868625 23181180768689512 23181175562820887 [¥e,ϨÂmHÉší"®²U8¦Ù-¦È€?F“Œº5Þ]
Unknown 5266476342 63126120238389 63120853762048
Unknown 5360922973 18014403870404956 18014398509481984
Unknown 5741604302 63126595366349 63120853762048
LVM magic value at 2947434/60/26
LVM magic value at 2990456/5/18
Unknown 6463792882 5165512091084529 5165505627291648
WBFS, 2644738 TB / 2405376 TiB
LVM magic value at 3292449/44/1
Unknown 6891087321 18014405400569304 18014398509481984 [ÏU·Ãý)§ë,þ$v›g¢iBþ[<s—H:‡©f‘I@]
BeFS blocksize=2147483648, 9223372 TB / 8388608 TiB
LVM magic value at 3392708/44/8
LVM magic value at 3563558/26/20
LVM magic value at 3796977/60/15
SYSV4 Marker at 4062540/36/21
recover_sysv4
Unknown 8320083092 9507362070 1187278979 [·¹¢š]
SysV4, 607 GB / 566 GiB
LVM magic value at 4091562/20/32
SYSV4 Marker at 4244641/44/3
recover_sysv4
Unknown 8693026178 52062494577 43369468400 [
'€²/¸]
SysV4, 22 TB / 20 TiB
LVM magic value at 4435359/22/10
NTFS at 7630883/63/32
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 8001 GB / 7452 GiB
mftmirr_lcn 2
NTFS: Can't read MFT
MS Data 15628050431 31256068094 15628017664
This partition ends after the disk limits. (start=15628050431, size=15628017664, end=31256068094, disk end=15628053168)
The harddisk (8001 GB / 7452 GiB) seems too small! (< 16 TB / 14 TiB)
Linux filesys. data 123742559 129822029 6079471 [<èóü“å z•5#]]
Linux filesys. data 123742560 129822030 6079471 [<èóü“å z•5#]]
Linux filesys. data 2133466338 2135736259 2269922 [f#¥ÓVŠþÙ´ÜË"ÈÝF]
Linux filesys. data 2133466339 2135736260 2269922 [f#¥ÓVŠþÙ´ÜË"ÈÝF]
echo "0 6079471 linear /dev/sde 123742559" | dmsetup create test1
echo "0 6079471 linear /dev/sde 123742560" | dmsetup create test2
echo "0 2315796546 linear /dev/sde 1497887405" | dmsetup create test3
echo "0 2269922 linear /dev/sde 2133466338" | dmsetup create test4
echo "0 2269922 linear /dev/sde 2133466339" | dmsetup create test5
echo "0 4154782 linear /dev/sde 2184216229" | dmsetup create test6
echo "0 4154782 linear /dev/sde 2188371007" | dmsetup create test7
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 27-Dec-2023 17:52 .
5 dr-xr-xr-x 0 0 0 27-Dec-2023 17:52 ..
40 dr-xr-xr-x 0 0 0 7-Feb-2022 18:33 $RECYCLE.BIN
36 dr-xr-xr-x 0 0 0 27-Dec-2023 19:28 System Volume Information
4223 dr-xr-xr-x 0 0 0 16-Jun-2019 10:45 digiK
369174 dr-xr-xr-x 0 0 0 25-Dec-2023 10:33 movie
4267 dr-xr-xr-x 0 0 0 2-Jun-2019 01:39 photo_mechanic
4660 dr-xr-xr-x 0 0 0 13-Aug-2018 19:06 photography
182 dr-xr-xr-x 0 0 0 12-Sep-2021 10:26 pictures
296864 dr-xr-xr-x 0 0 0 27-Dec-2023 06:57 tmp
123 dr-xr-xr-x 0 0 0 6-Dec-2023 08:31 video
dir_partition inode=369174
Directory /movie
369174 dr-xr-xr-x 0 0 0 25-Dec-2023 10:33 .
374478 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 12_angry_men
374473 dr-xr-xr-x 0 0 0 14-Dec-2023 13:42 a_few_good_men
369406 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 all_the_president's_men[1976]
369333 dr-xr-xr-x 0 0 0 14-Dec-2023 10:55 camelot[1967]
369336 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 cape_fear[1991]
374480 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 finding_forrester
369392 dr-xr-xr-x 0 0 0 16-Nov-2023 16:23 fitness
374488 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 gladiator
374509 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 in_america
374403 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 k19_widowmaker
374410 dr-xr-xr-x 0 0 0 13-Dec-2023 13:56 maid_to_order
369375 dr-xr-xr-x 0 0 0 22-Dec-2023 10:54 music
352020 dr-xr-xr-x 0 0 0 18-Dec-2023 10:12 my_best_friends_wedding
369382 dr-xr-xr-x 0 0 0 14-Dec-2023 10:39 phantom_of_the_opera
369197 dr-xr-xr-x 0 0 0 16-Nov-2023 12:35 ron_white
374418 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 spanglish
374470 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 the_apartment
374524 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 the_hustler
374445 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 the_sixth_sense
369394 dr-xr-xr-x 0 0 0 16-Nov-2023 18:19 the_talented_mr_ripley[1999]
374412 dr-xr-xr-x 0 0 0 13-Dec-2023 14:20 there's_something_about_mary
373945 dr-xr-xr-x 0 0 0 27-Dec-2023 11:19 wild_hogs
Support for this filesystem wasn't enabled during compilation.
Support for this filesystem hasn't been implemented.
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
dir_partition inode=40
Directory /$RECYCLE.BIN
40 dr-xr-xr-x 0 0 0 7-Feb-2022 18:33 .
43 dr-xr-xr-x 0 0 0 31-May-2019 01:41 S-1-5-18
1894 dr-xr-xr-x 0 0 0 27-Dec-2023 11:20 S-1-5-21-1862263428-2559000323-1675438401-1001
4220 dr-xr-xr-x 0 0 0 10-Sep-2021 20:35 S-1-5-21-1865726404-2256615770-1928969295-1001
4068 dr-xr-xr-x 0 0 0 27-Oct-2020 18:30 S-1-5-21-3917113064-2507771379-1107474332-1001
41 dr-xr-xr-x 0 0 0 3-Dec-2019 19:00 S-1-5-21-4184752128-4008578668-3714968331-1001
dir_partition inode=43
Directory /$RECYCLE.BIN/S-1-5-18
43 dr-xr-xr-x 0 0 0 31-May-2019 01:41 .
40 dr-xr-xr-x 0 0 0 7-Feb-2022 18:33 ..
44 -r--r--r-- 0 0 129 31-May-2019 01:41 desktop.ini
dir_partition inode=1894
Directory /$RECYCLE.BIN/S-1-5-21-1862263428-2559000323-1675438401-1001
1894 dr-xr-xr-x 0 0 0 27-Dec-2023 11:20 .
369178 dr-xr-xr-x 0 0 0 20-Sep-2023 11:03 $RGWVKNK
374537 -r--r--r-- 0 0 56 27-Dec-2023 11:20 $IGWVKNK
1899 -r--r--r-- 0 0 129 7-Feb-2022 18:33 desktop.ini
dir_partition inode=4068
Directory /$RECYCLE.BIN/S-1-5-21-3917113064-2507771379-1107474332-1001
4068 dr-xr-xr-x 0 0 0 27-Oct-2020 18:30 .
4069 -r--r--r-- 0 0 129 9-May-2020 11:24 desktop.ini
dir_partition inode=41
Directory /$RECYCLE.BIN/S-1-5-21-4184752128-4008578668-3714968331-1001
41 dr-xr-xr-x 0 0 0 3-Dec-2019 19:00 .
42 -r--r--r-- 0 0 129 30-May-2019 06:18 desktop.ini
Directory /System Volume Information
36 dr-xr-xr-x 0 0 0 27-Dec-2023 19:28 .
4071 dr-xr-xr-x 0 0 0 9-May-2020 11:24 AadRecoveryPasswordDelete
17 dr-xr-xr-x 0 0 0 27-Dec-2023 07:44 Chkdsk
4070 dr-xr-xr-x 0 0 0 9-May-2020 11:24 ClientRecoveryPasswordRotation
4112 dr-xr-xr-x 0 0 0 12-Jun-2020 18:41 EDP
38 -r--r--r-- 0 0 76 30-May-2019 06:05 IndexerVolumeGuid
37 -r--r--r-- 0 0 12 30-May-2019 06:05 WPSettings.dat
39 -r--r--r-- 0 0 20480 1-Jun-2019 10:28 tracking.log
dir_partition inode=17
Directory /System Volume Information/Chkdsk
17 dr-xr-xr-x 0 0 0 27-Dec-2023 07:44 .
36 dr-xr-xr-x 0 0 0 27-Dec-2023 19:28 ..
18 -r--r--r-- 0 0 25600 27-Dec-2023 07:44 Chkdsk20231227134447.log
Files created in Linux missing after boot into Windows
Re: Files created in Linux missing after boot into Windows
As Windows nowadays standard method of shutdown is not a really shutdown but a disguised sleep mode, your disks have not really dismounted - to express this in Linux terms. Using a dual boot system containing a recent windows version and linux is paving the way for disaster.
This is your second error. If you might have been victim of data loss, always duplicate your disk as described in the Testdisk manual. Chkdsk brings your partitions or volumes in a defined clean state but destroys the evidence that data recovery programs can evaluate.I have a external hard drives in a teramaster case connected via USB-C. In Debian I have been digitizing my dvd collection with MakeMKV and saving to one of the external drives, with a goal of setting up a home media server. After about two weeks in only Debian I logged into Windows. When I went to directory via Windows Explorer with the new videos Windows said the file was in invalid location and could not be opened. I right clicked on the drive and went to properties>tools and ran the check disk for errors.
What is "disk optimization tool"? This is error number three. Your tool might as well have wiped necessary remains that other recovery might successfully evaluate.
I doubt it, because your TestDisk logfile shows a different picture.
Although your posting does not contain a question I posted this comment for the benefit of the other forum readers.
Compiler: GCC 12.2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 16/0/1
mftmirr_lcn 2
NTFS at 16/0/1
mftmirr_lcn 2
NTFS at 16/0/1
mftmirr_lcn 2
NTFS at 16/0/1
mftmirr_lcn 2
recover_cramfs
recover_cramfs
recover_sysv4
recover_cramfs
recover_cramfs
part_size 4154782
part_size 4154782
recover_sysv4
recover_sysv4
'€²/¸]
mftmirr_lcn 2
mftmirr_lcn 2
Directory /movie
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Thank you for the reply. No, I don't have a question, I just wanted to post for others.
I know to turn off fast boot and hibernation but it seems some Windows updates reset that configuration. I checked and I did need to turn those off (again). But in the hard drive in question is external, so I don't think this applies. I say that because when the fast boot configuration is on, the internal ntfs drives can't be written to in Linux, i.e. cant' create a new file, copy a file to the drive or create a new directory. I have never had that issue with external drives when fast boot is on.
The optimization tool is also known as defragmentation. I think that was my biggest mistake.
Thanks again for the useful reply.
Try to explore that disk with TestDisk! Your TestDisk report is listing folders!
Try to copy files and folders from there and see if the files can be opened afterwards.
Thank you for posting that kind of failure report.
