Raspberry Pi EMMC partition type
jd3rul
#1 Post by jd3rul »
  • Storage device is a Raspberry Pi CM4 emmc mounted as a MSD.
    Windows partition says it is RAW, not partitioned and gives CRC error.
  • In TestDisk my partition table type was automatically identified as Intel .
    I chose [None] (No partition media) because I had this "Not partitioned" notification before in windows.
  • TestDisk returned Partition & Backup : Bad . Identical.
    I couldn't find any filesystem/partitions using Analyze or Recover in FAT32.
jd3rul
Re: Raspberry Pi EMMC partition type
#2 Post by jd3rul »
Does anyone know what type of partition should the EMMC be?
