recovering AWR / RAW file deleted from SanDisk SD Card via Photorec
ellipse
#1 Post by ellipse »
Hello! I tried to recover a deleted AWR file from a SanDisk SD card using Photorec.
Photorec saved 1 file in .apple file format.
The file is 121 GB, almost the size of the entire SD card. The deleted file was approx 21 MB, an uncompressed RAW file.
Can I retrieve the AWR file from the .apple file? If yes, how do I open .apple?
Is there a better way to retrieve a deleted AWR file using testdisk, or using photrec?
thank you!
Re: recovering AWR / RAW file deleted from SanDisk SD Card via Photorec
"awr" is not a file format recognized by PhotoRec:
https://www.cgsecurity.org/wiki/File_Fo ... y_PhotoRec
You will either need to create a custom fingerprint for this file or find another software that recognizes this file format.
