HP Elitebook x360 1040 G6, BIOS 01.27.00 is current. UEFI diags show both
memory and disk are OK.
After a crash, third partition is RAW.
Disk is an Intel HBRPEKNX0202AH. BIOS claims it's 512 GB.
Running analyze shows "can't read MFT" for both the second
(MS Reserved) and c: partitions and "This partition ends after the disk limits"
as well as:
The hard disk (512 GB / 476 GiB) seems too small! (< 1024 GB / 953 GiB)
MS Data 1000204287 1001609214 1404928
NTFS, blocksize=4096, 719 MB / 686 MiB
MS Data 1000212479 2000422910 1000210432
NTFS, blocksize=4096, 512 GB / 476 GiB
I also ran the deep search without any change.
As testdisk warns that the disk capacity must be correctly detected for a successful
recovery, I'm afraid I must ask for guidance. Thanks in advance for any pointers.
Cheers
Fri May 17 10:53:45 2024
OS: Windows 8 (9200)
ext2fs lib: 1.45.3, ntfs lib: available, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=61958258688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=511094816768
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=61956161536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=719323136
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=3162112
Disk \\.\PhysicalDrive0 - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - INTEL HBRPEKNX0202AH, S/N:0000_0000_0100_0000_E4D2_5C38_6ADA_5101., FW:HPS1
Disk \\.\PhysicalDrive1 - 61 GB / 57 GiB - CHS 7532 255 63, sector size=512 - Patriot Memory, S/N:037B00196040, FW:PMAP
Drive X: - 3162 KB / 3088 KiB - CHS 193 16 2, sector size=512 - Microsoft Corporation RamDisk
Disk \\.\PhysicalDrive0 - 512 GB / 476 GiB - INTEL HBRPEKNX0202AH
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive0 - 512 GB / 476 GiB - CHS 62260 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1000210671 (expected 1000215215)
hdr_lba_start=34
hdr_lba_end=1000210638
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P MS Reserved 534528 567295 32768 [Microsoft reserved partition]
3 P MS Data 567296 998799359 998232064 [Basic data partition]
1 P EFI System 2048 534527 532480 [EFI system partition]
4 P Windows Recovery Env 998799360 1000204287 1404928 [Basic data partition]
FAT32 at 0/32/33
FAT1 : 7166-7678
FAT2 : 7679-8191
Data : 8192-532479
sectors : 532480
cluster_size : 8
no_of_cluster : 65536 (2 - 65537)
fat_length 513 calculated 513
FAT32 at 0/32/33
FAT: cluster=2(0x2), pos=10240
EFI System 2048 534527 532480 [EFI System Partition] [SYSTEM]
FAT32, blocksize=4096, 272 MB / 260 MiB
NTFS at 49/75/19
filesystem size 998232064
mftmirr_lcn 2
NTFS part_offset=405467136, part_size=511094816768, sector_size=512
NTFS at 49/75/19
mftmirr_lcn 2
MS Data 791928 999023991 998232064
NTFS, blocksize=4096, 511 GB / 475 GiB
NTFS at 62196/189/50
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
MS Data 999184523 999190696 6174
mft_lcn 2058
mftmirr_lcn 5162
MS Data 999190696 999196869 6174 [Boot]
NTFS at 62259/213/34
filesystem size 1404928
mft_lcn 58538
mftmirr_lcn 2
MS Data 998799360 1000204287 1404928 [Windows RE Tools]
NTFS found using backup sector, blocksize=4096, 719 MB / 686 MiB
mft_lcn 58538
mftmirr_lcn 2
NTFS: Can't read MFT
This partition ends after the disk limits. (start=1000204287, size=1404928, end=1001609214, disk end=1000215216)
NTFS at 62260/88/36
filesystem size 1000210432
mftmirr_lcn 2
MS Data 2048 1000212479 1000210432
NTFS found using backup sector, blocksize=4096, 512 GB / 476 GiB
NTFS at 62260/88/36
mftmirr_lcn 2
This partition ends after the disk limits. (start=1000212479, size=1000210432, end=2000422910, disk end=1000215216)
file_win32_pread(504,11,buffer,1000215208(62260/131/56)) read err: read after end of file
file_win32_pread(504,11,buffer,1000215212(62260/131/60)) read err: read after end of file
file_win32_pread(504,8,buffer,1000215211(62260/131/59)) read err: read after end of file
file_win32_pread(504,14,buffer,1000215204(62260/131/52)) read err: read after end of file
file_win32_pread(504,14,buffer,1000215205(62260/131/53)) read err: read after end of file
file_win32_pread(504,14,buffer,1000215206(62260/131/54)) read err: read after end of file
file_win32_pread(504,14,buffer,1000215207(62260/131/55)) read err: read after end of file
file_win32_pread(504,14,buffer,1000215208(62260/131/56)) read err: read after end of file
file_win32_pread(504,14,buffer,1000215210(62260/131/58)) read err: read after end of file
file_win32_pread(504,14,buffer,1000215212(62260/131/60)) read err: read after end of file
file_win32_pread(504,14,buffer,1000215214(62260/131/62)) read err: read after end of file
can't read MFT / hard disk seems too small
Re: can't read MFT / hard disk seems too small
The internet tells me that it's 512 GB.Administratorte wrote: 17 May 2024, 18:25 HP Elitebook x360 1040 G6, BIOS 01.27.00 is current. UEFI diags show both
The disk size is correctly identified, see my text below.I also ran the deep search without any change.
Disk has been correctly identified, see size in bytes above.Cheers
Can you access the content of this partition (number 3) above?disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=61958258688
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 0/32/33
FAT1 : 7166-7678
FAT2 : 7679-8191
Data : 8192-532479
sectors : 532480
cluster_size : 8
FAT32 at 0/32/33
NTFS at 49/75/19
mftmirr_lcn 2
NTFS at 49/75/19
mftmirr_lcn 2
mft_lcn 2058
mftmirr_lcn 5162
mft_lcn 2058
mftmirr_lcn 5162
mft_lcn 58538
mftmirr_lcn 2
mft_lcn 58538
mftmirr_lcn 2
NTFS at 62260/88/36
mftmirr_lcn 2
NTFS at 62260/88/36
mftmirr_lcn 2
Administratorte
Thank you for taking the time to reply.
I thought there was a size issue due to these lines:
To answer your other question, no, I can't access anything on partition 3. It tells me the file system is raw. However, it also tells
me that it's locked with bitlocker, so I'm trying to track down a recovery key and if that is successful, I'll see if manage-bde
is able to unlock it.
Cheers.
Cheers.
Administratorte
Continuing ...
None of the recover keys found work. In retrospect, this doesn't seem surprising
as the partition is raw. I suspect nothing will work until/unless the bitlocker
partitions have a proper file system on them.
Indeed, mange-bde -status gives an 80070057 error.
Some people seemed to have fixed the problem with chkdsk, but however
that worked, here it fails to run claiming it does not work on raw file systems.
repair-bde seems to be the next thing to try.
Cheers.
Cheers.
