I was troubleshooting one of my drives and I accidentally 'cleaned' the wrong drive. The drive I cleaned had all my data (photos/documents/etc.). This is in a RAID 1.
These are the steps I performed to clean it. I have not written any data back on to it.
Diskpart > list disk
Diskpart > select disk
Diskpart > Clean
Diskpart > Create Partition Primary Align=1024
Diskpart > Format Quick FS=NTFS
Diskpart > List Partition
Diskpart > Active
Diskpart > Exit
Reboot the computer
I've never used TestDisk and I'm looking for some guidance as to what steps I should take to try and recover the partition if possible.
Diskpart - 'Cleaned' wrong disk!
Re: Diskpart - 'Cleaned' wrong disk!
To add, the drive had only one partition.
I tried a quick scan of the recommended 'EFI - GPT' option but it seems to hang at 99% (had to force quit after an hour).
Then I tried an 'Intel' quick scan and that found the new partition. So I started a deep scan and stopped it about 5% and got the results below.
https://imgur.com/a/9gvBUzn
- testdisk.log
- Log File
- (10.11 KiB) Downloaded 913 times
Please upload your picture to this site and post your TestDisk logfile.
