I had an unclean shutdown of unraid and now my nvme drive can't be mounted.
I used test disk and it found the partition I want to recover when I used deeper search and it says that the hard disk seems too small!!
I'm pretty sure I need to adjust the cylinder in the geometry tab.
Can someone please help let me know what I should set the cylinder at to make it work?
My wife is so mad at me rn.
Below is the log
Fri Aug 23 11:46:55 2024
OS: Windows 8 (9200)
ext2fs lib: 1.45.3, ntfs lib: available, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4096805658624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=61530439680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1998011236352
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4096787480576
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=61528342528
Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WD_BLACK SN850X 2000GB, S/N:E823_8FA6_BF53_0001_001B_448B_4BDE_F46C., FW:620281WD
Disk \\.\PhysicalDrive1 - 4096 GB / 3815 GiB - CHS 498074 255 63, sector size=512 - TEAM TM8FPW004T, S/N:0000_0000_0000_0000_0C82_D500_8050_0005., FW:H231217a
Disk \\.\PhysicalDrive2 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WD_BLACK SN850X 2000GB, S/N:E823_8FA6_BF53_0001_001B_448B_4A53_E3B8., FW:620361WD
Disk \\.\PhysicalDrive3 - 61 GB / 57 GiB - CHS 7480 255 63, sector size=512 - USB SanDisk 3.2Gen1, S/N:0901a19ebefbdb9f3812, FW:1.00
Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - WD_BLACK SN850X 2000GB
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - CHS 243201 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 3907029167)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P Linux filesys. data 2048 3907029167 3907027120
recover_btrfs: part_size 3907027120
btrfs blocksize=4096 Backup superblock, 2000 GB / 1863 GiB
Linux filesys. data 132992 3907160111 3907027120
This partition ends after the disk limits. (start=132992, size=3907027120, end=3907160111, disk end=3907029168)
The hard disk (2000 GB / 1863 GiB) seems too small! (< 2000 GB / 1863 GiB)
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
