How to fix this POST 1 TB SATA-III TOSHIBA HDWD110 HDD Internal storage device in this POST case ?
amoaalabuba
#1 Post by amoaalabuba »
First i enabled an user and admin BIOS password in a ASUS
PRIMEB360M-C/CSM motherboard intel core i7 8700 pc, then i
installed and configured in previoulsy mentioned motherboard bios in
a 1 TB SATA-III TOSHIBA HDWD110 HDD Internal storage device, then i
formatted that drive in previoulsy mentioned motherboard bios, and
then the previoulsy mentioned storage device damaged, using a ROG MAXIMUS XI Gene with the same processor that used
previosuly mentioned pc: intel core i7 8700 @3.20 GHz 3192 MHz pc,
,when using "Create and format hard disk partitions" default Windows
11 Pro Version 23H2 Build 22631.4037 installation app,after the app
finished loading then appear in this POST
attached image Image and after i clickedin that Window: "OK" button there appears the follwoing error:"Data Error(cyclic redundancy check)." in a windows named: "Virtual Disk Manager". HYowcan i fix that issue ?
Re: How to fix this POST 1 TB SATA-III TOSHIBA HDWD110 HDD Internal storage device in this POST case ?
amoaalabuba wrote: 31 Aug 2024, 00:47 First i enabled an user and admin BIOS password in a ASUS
Please ask in another forum, this is not the right one.
Thank you!
