How to fix this POST 1 TB SATA-III TOSHIBA HDWD110 HDD Internal storage device in this POST case ?
amoaalabuba
#1 Post by amoaalabuba »
First i enabled an user and admin BIOS password in a ASUS
PRIMEB360M-C/CSM motherboard intel core i7 8700 pc, then i
installed and configured in previoulsy mentioned motherboard bios in
a 1 TB SATA-III TOSHIBA HDWD110 HDD Internal storage device, then i
formatted that drive in previoulsy mentioned motherboard bios, and
then the previoulsy mentioned storage device damaged, using a ROG MAXIMUS XI Gene with the same processor that used
previosuly mentioned pc: intel core i7 8700 @3.20 GHz 3192 MHz pc,
,when using "Create and format hard disk partitions" default Windows
11 Pro Version 23H2 Build 22631.4037 installation app,after the app
finished loading then appear in this url: Image attached image in that Window: "OK" button there appears the follwoing error:"Data Error(cyclic redundancy check)." in a windows named: "Virtual Disk Manager". How can i fix that issue ?
amoaalabuba
Re: How to fix this POST 1 TB SATA-III TOSHIBA HDWD110 HDD Internal storage device in this POST case ?
#2 Post by amoaalabuba »
i want to fix the issue in Windows
11 Pro Version 23H2 Build 22631.4112 i am gonif to give you a url that shows my disk label: https://abuelametraumolaab.wixsite.com/websitei only have a ROG MAXIMUS XI Gene board PC i wnat to fix that issue with latest Driver Genius software free verison or Driver Genius Platinum version 23.0.0.137 the frist image is in this link: https://abuelametraumolaab.wixsite.com/my-site-1
amoaalabuba
#3 Post by amoaalabuba »
i want to do it using Test Disk
amoaalabuba
#4 Post by amoaalabuba »
drive serial number 48J6URBFS 9WG
#5 Post by recuperation »
I may not have been precise: When I told you to search another forum I did not mean another subforum at cgsecurity.org but another forum in the world wide web outside of forum.cgsecurity.org.
Thank you!
