Intel RAID 0 BitLocker
an3k
#1 Post by an3k »
Good day,
I have two M.2 SSDs configured in a RAID 0 using Intel RST. On that drive was a single BitLocker partition used as a secondary data volume. I followed the steps mentioned here but it doesn't work. TestDisk finds nothing. I assume because of BitLocker. Or maybe because I booted into Windows without removing the Intel RST driver, which is not possible because the OS Disk is also a RAID. I was not able to see the RAID Volume but the contents of the "non-member disk" (three partitions and 99% unallocated space). Interestingly the boot RAID drive has not lost a member disk, just the data RAID drive.
So, my question is: How to recover Intel RAID data on a bitlocker drive? Or is it already too late?
EDIT: After more than 12 hours of a quick analyze it found something:
Disk \\.\PhysicalDrive1 - 8001 GB / 7452 GiB - CHS 972802 255 63
Analyse cylinder 87783/972801: 09%
  MS Data                     4224    1087615    1083392
  BeFS                   282952429 7104808843291417 7104808560338989 [ h^P˦)M-7M-v~A^?M-+M-&~OdV^KM-~M-$PM-n lT}^V
  Unknown                517864456 4159697859 3641833404
  Linux filesys. data    812128968  814545571    2416603 [^LM-!^\^PM-.
xO^Rl~[;1^?t]
Stop
Re: Intel RAID 0 BitLocker
TestDisk only supports some linux RAID structures.
Your post does not contain a proper case description which would explain how your system worked and what is different now.
an3k
#3 Post by an3k »
Sorry for missing the case description.
My laptop runs Windows 11 but I have a lot of issues. Wanted to install Windows 10 because I bet the issues were because of Windows 11. I removed all four M.2 SSDs (2x 2TB in RAID0 as boot drive and system + 2x 4TB in RAID0 as data drive), installed a different M.2, tried to install Windows 10 which failed (no drive visible), disabled Intel RST and installed Windows 10 (worked now). Laptop works fine with Windows 10 but because I don't have time to do the migration now -> I removed the new M.2, installed the previous M.2s again and made sure to put them in the very same slots they were before, re-enabled Intel RST and booted. Windows 11 loaded perfectly fine and I had my C: in good condition. But D: was missing a size info and I additionally got E: and F:. Checked disk manager and Intel Optane software and saw that I do not have the raid but a single 4TB M.2 (the previous data RAID0 member-disk).
an3k
#4 Post by an3k »
I kept it runing and currently it's showing this. Does it look saveable or is all lost?
Analyse cylinder 440035/972801: 45%
xO^Rl~[;1^?t]
  Unknown               1999880959 2525510139  525629181
  Linux filesys. data   2805228689 2806234440    1005751 [-~WM-;]M-'qsdM-$~SM-wWvM-%
  Unknown               4264661750 797593974182645 797589709520896 [ }M-=M-x~N]
  Unknown               4275158093 17792746028 13517587936 [ʑF 7]
  Unknown               4520489340 2995225113979 2990704624640
