I've accidentally deleted my partition using disk cleanup software
shiro643
#1 Post by shiro643 »
I've accidentally deleted my partition using a disk cleanup software. I stopped deletion after like 20-30 seconds after i've noticed my mistake. I've tried to get it back using testdisk software but i'm getting "Can't open filesystem. Filesystem seems damaged." error. I've tried rebuilding boot sector but had no luck.I am not seeing my files when i try to list them either.
Trying to fix my partition with chkdsk command also gets me this error:
The type of the file system is NTFS.
Unable to determine volume version and state.  CHKDSK aborted.
Heres my testdisk.log:
Sectors are identical.
$MFT has invalid magic.
ntfs_mft_load(): Failed.
New geometry
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 129202 240 63 sector_size=512
NTFS at 7057/16/1
 1 P HPFS - NTFS           7057  16  1 129201  40 24 1846818816
     NTFS, blocksize=4096, 945 GB / 880 GiB
Not an exFAT boot sector.
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
filesystem size           1846818816
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
rebuild_NTFS_BS
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
Boot sector                        Backup boot sector
0000 ffffffeb52ffffff904e 54465320   .R.NTFS   ffffffeb52ffffff904e 54465320   .R.NTFS
0008 20202000 02080000      .....  20202000 02080000      .....
0010 00000000 00fffffff80000   ........  00000000 00fffffff80000   ........
0018 3f00fffffff000 00285c06   ?....(\.  3f00fffffff000 00285c06   ?....(\.
0020 00000000 ffffff8000ffffff8000   ........  00000000 ffffff8000ffffff8000   ........
0028 ffffffff37146e 00000000   .7.n....  ffffffff37146e 00000000   .7.n....
0030 00000c00 00000000   ........  00000c00 00000000   ........
0038 02000000 00000000   ........  02000000 00000000   ........
0040 fffffff6000000 01000000   ........  fffffff6000000 01000000   ........
0048 ffffffc0ffffffb745ffffffce 0146ffffffce38   ..E..F.8  ffffffc0ffffffb745ffffffce 0146ffffffce38   ..E..F.8
0050 00000000 fffffffa33ffffffc0ffffff8e   .....3..  00000000 fffffffa33ffffffc0ffffff8e   .....3..
0058 ffffffd0ffffffbc007c fffffffb68ffffffc007   ...|.h..  ffffffd0ffffffbc007c fffffffb68ffffffc007   ...|.h..
0060 1f1e6866 00ffffffcbffffff8816   ..hf....  1f1e6866 00ffffffcbffffff8816   ..hf....
0068 0e0066ffffff81 3e03004e   ..f.>..N  0e0066ffffff81 3e03004e   ..f.>..N
0070 54465375 15ffffffb441ffffffbb   TFSu..A.  54465375 15ffffffb441ffffffbb   TFSu..A.
0078 ffffffaa55ffffffcd13 720cffffff81fffffffb   .U..r...  ffffffaa55ffffffcd13 720cffffff81fffffffb   .U..r...
0080 55ffffffaa7506 fffffff7ffffffc10100   U.u.....  55ffffffaa7506 fffffff7ffffffc10100   U.u.....
0088 7503ffffffe9ffffffdd 001effffff83ffffffec   u.......  7503ffffffe9ffffffdd 001effffff83ffffffec   u.......
0090 18681a00 ffffffb448ffffff8a16   .h...H..  18681a00 ffffffb448ffffff8a16   .h...H..
0098 0e00ffffff8bfffffff4 161fffffffcd13   ........  0e00ffffff8bfffffff4 161fffffffcd13   ........
00A0 ffffff9fffffff83ffffffc418 ffffff9e581f72   .....X.r  ffffff9fffffff83ffffffc418 ffffff9e581f72   .....X.r
00A8 ffffffe13b060b 0075ffffffdbffffffa3   .;...u..  ffffffe13b060b 0075ffffffdbffffffa3   .;...u..
00B0 0f00ffffffc12e 0f00041e   ........  0f00ffffffc12e 0f00041e   ........
00B8 5a33ffffffdbffffffb9 00202bffffffc8   Z3... +.  5a33ffffffdbffffffb9 00202bffffffc8   Z3... +.
00C0 66ffffffff0611 0003160f   f.......  66ffffffff0611 0003160f   f.......
00C8 00ffffff8effffffc2ffffffff 061600ffffffe8   ........  00ffffff8effffffc2ffffffff 061600ffffffe8   ........
00D0 4b002bffffffc8 77ffffffefffffffb800   K.+.w...  4b002bffffffc8 77ffffffefffffffb800   K.+.w...
00D8 ffffffbbffffffcd1a66 23ffffffc0752d   ...f#.u-  ffffffbbffffffcd1a66 23ffffffc0752d   ...f#.u-
00E0 66ffffff81fffffffb54 43504175   f..TCPAu  66ffffff81fffffffb54 43504175   f..TCPAu
00E8 24ffffff81fffffff902 01721e16   $....r..  24ffffff81fffffff902 01721e16   $....r..
00F0 6807ffffffbb16 68700e16   h...hp..  6807ffffffbb16 68700e16   h...hp..
00F8 68090066 53665366   h..fSfSf  68090066 53665366   h..fSfSf
0100 55161616 68ffffffb80166   U...h..f  55161616 68ffffffb80166   U...h..f
0108 610e07ffffffcd 1a33ffffffc0ffffffbf   a....3..  610e07ffffffcd 1a33ffffffc0ffffffbf   a....3..
0110 2810ffffffb9ffffffd8 0ffffffffcfffffff3ffffffaa   (.......  2810ffffffb9ffffffd8 0ffffffffcfffffff3ffffffaa   (.......
0118 ffffffe95f01ffffff90 ffffff9066601e   ._...f`.  ffffffe95f01ffffff90 ffffff9066601e   ._...f`.
0120 0666ffffffa111 00660306   .f...f..  0666ffffffa111 00660306   .f...f..
0128 1c001e66 68000000   ...fh...  1c001e66 68000000   ...fh...
0130 00665006 53680100   .fP.Sh..  00665006 53680100   .fP.Sh..
0138 681000ffffffb4 42ffffff8a160e   h...B...  681000ffffffb4 42ffffff8a160e   h...B...
0140 00161fffffff8b fffffff4ffffffcd1366   .......f  00161fffffff8b fffffff4ffffffcd1366   .......f
0148 595b5a66 5966591f   Y[ZfYfY.  595b5a66 5966591f   Y[ZfYfY.
0150 0fffffff821600 66ffffffff0611   ....f...  0fffffff821600 66ffffffff0611   ....f...
0158 0003160f 00ffffff8effffffc2ffffffff   ........  0003160f 00ffffff8effffffc2ffffffff   ........
0160 0e160075 ffffffbc071f66   ...u...f  0e160075 ffffffbc071f66   ...u...f
0168 61ffffffc3ffffffa0fffffff8 01ffffffe80900   a.......  61ffffffc3ffffffa0fffffff8 01ffffffe80900   a.......
0170 ffffffa0fffffffb01ffffffe8 0300fffffff4ffffffeb   ........  ffffffa0fffffffb01ffffffe8 0300fffffff4ffffffeb   ........
0178 fffffffdffffffb401ffffff8b fffffff0ffffffac3c00   ......<.  fffffffdffffffb401ffffff8b fffffff0ffffffac3c00   ......<.
0180 7409ffffffb40e ffffffbb0700ffffffcd   t.......  7409ffffffb40e ffffffbb0700ffffffcd   t.......
0188 10ffffffebfffffff2ffffffc3 0d0a4469   ......Di  10ffffffebfffffff2ffffffc3 0d0a4469   ......Di
0190 736b206f 6b756d61   sk okuma  736b206f 6b756d61   sk okuma
0198 20686174 6173ffffff8d20    hatas.   20686174 6173ffffff8d20    hatas.
01A0 6f6c75ffffff9f 7475000d   olu.tu..  6f6c75ffffff9f 7475000d   olu.tu..
01A8 0a424f4f 544d4752   .BOOTMGR  0a424f4f 544d4752   .BOOTMGR
01B0 20656b73 696b000d    eksik..  20656b73 696b000d    eksik..
01B8 0a424f4f 544d4752   .BOOTMGR  0a424f4f 544d4752   .BOOTMGR
01C0 2073ffffff8d6b ffffff8dffffff9f74ffffff8d    s.k..t.  2073ffffff8d6b ffffff8dffffff9f74ffffff8d    s.k..t.
01C8 72ffffff8d6c6d ffffff8dffffff9f000d   r.lm....  72ffffff8d6c6d ffffff8dffffff9f000d   r.lm....
01D0 0a59656e 6964656e   .Yeniden  0a59656e 6964656e   .Yeniden
01D8 206261ffffff9f 6c61743a    ba.lat:  206261ffffff9f 6c61743a    ba.lat:
01E0 20437472 6c2b416c    Ctrl+Al  20437472 6c2b416c    Ctrl+Al
01E8 742b4465 6c0d0a00   t+Del...  742b4465 6c0d0a00   t+Del...
01F0 73746172 740d0a00   start...  73746172 740d0a00   start...
01F8 ffffff8cffffffa7ffffffb7ffffffcf 000055ffffffaa   ......U.  ffffff8cffffffa7ffffffb7ffffffcf 000055ffffffaa   ......U.
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
Change partition type:
 1 P NTFS                  7057  16  1 129201  40 24 1846818816
Heres the full longer log file: https://files.catbox.moe/n157e3.log
Am i out of luck?
Re: I've accidentally deleted my partition using disk cleanup software
Sun Nov 17 04:04:07 2024
ext2fs lib: 1.45.3, ntfs lib: available, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=1000203804160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=480101007360
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=580667834368
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=419533160448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=4000650625024
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-22BN5A0, S/N:WD-WCC3F1STHJVJ, FW:01.0
Disk \\.\PhysicalDrive1 - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - TOSHIBA- TR200, S/N:893B81RBK4FP, FW:SBFA
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - SAMSUNG HD103SI, S/N:S23HJ90S900443, FW:1AG0
Disk \\.\PhysicalDrive2 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - TOSHIBA HDWD240, S/N:34B2S75SS5HH, FW:KQ00
Disk \\.\PhysicalDrive4 - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - WDC WD6400AACS-00G8B, S/N:WD-WCAUF0745979, FW:05.0
Drive F: - 580 GB / 540 GiB - CHS 70595 255 63, sector size=512
Drive H: - 419 GB / 390 GiB - CHS 51005 255 63, sector size=512
Drive J: - 4000 GB / 3725 GiB - CHS 7813770752 1 1, sector size=512
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - SAMSUNG HD103SI
Analyse Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 121601 255 63
recover_EXT2: s_block_group_nr=0/1024, s_mnt_count=236/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 33554432
recover_EXT2: part_size 268435456
Last mount time:    Wed Nov  6 17:07:39 2024
     Linux                79791 240  2 96501  70 17  268435456 [data]
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 137 GB / 128 GiB
NTFS at 121601/25/24
heads/cylinder 240 (NTFS) != 255 (HD)
mftmirr_lcn               2
     HPFS - NTFS           6641 241  1 121601  25 24 1846818816
     NTFS found using backup sector, blocksize=4096, 945 GB / 880 GiB
mftmirr_lcn               2
NTFS: Can't read MFT
     HPFS - NTFS          121601  25 24 236560  64 47 1846818816
This partition ends after the disk limits. (start=1953521663, size=1846818816, end=3800340478, disk end=1953523055)
The hard disk (1000 GB / 931 GiB) seems too small! (< 1945 GB / 1812 GiB)
Warning: the current number of heads per cylinder is 255 but the correct value may be 128.
 1 P HPFS - NTFS           6641 241  1 121601  25 24 1846818816
write!
Store new MBR code
ntfs_boot_sector
NTFS at 6641/241/1
filesystem size           9303505544076478677 1846818816
sectors_per_cluster       147 8
mft_lcn                   6486600856115723394 786432
mftmirr_lcn               3276332374983626885 2
clusters_per_mft_record   -121 -10
clusters_per_index_record -116 1
Status: Bad
Warning: number of heads/cylinder mismatches 240 (NTFS) != 255 (HD)
Status: OK
Sectors are not identical.
copy backup boot sector over boot sector
ntfs_boot_sector
NTFS at 6641/241/1
NTFS at 6641/241/1
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 6641/241/1
NTFS at 6641/241/1
mftmirr_lcn               2
Status: OK
Status: OK
rebuild_NTFS_BS
ntfs_boot_sector
NTFS at 6641/241/1
NTFS at 6641/241/1
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 6641/241/1
NTFS at 6641/241/1
mftmirr_lcn               2
Status: OK
Status: OK
rebuild_NTFS_BS
Search mft stopped:     655360/1846818816
ntfs_boot_sector
NTFS at 6641/241/1
NTFS at 6641/241/1
mftmirr_lcn               2
Status: OK
Status: OK
repair_MFT
NTFS at 6641/241/1
ntfs_boot_sector
NTFS at 6641/241/1
NTFS at 6641/241/1
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 6641/241/1
NTFS at 6641/241/1
mftmirr_lcn               2
Status: OK
Status: OK
New geometry
NTFS at 7057/16/1
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
rebuild_NTFS_BS
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 7057/16/1
NTFS at 7057/16/1
mftmirr_lcn               2
Status: OK
Status: OK
During 20-30 seconds "disk cleanup" you roughly erased 2 GB to 5 GB of disk space unfortunately.
Try out commercial software. If that fails, use PhotoRec.
