wrong fs type
pierpiotr
wrong fs type
#1 Post by pierpiotr »
I have a message in Dolphin (Ubuntu 24.04 LTS) when I plug in my 1To external drive : "wrong fs type, bad option, bad superblock on /dev/sda1"
I am kind of a noob: I had a hard time launching testdisk in a terminal and then I could not find how to fix this storage (still accessible via windows). Can someone walk me through recovery, please?
Re: wrong fs type
Please generate a TestDisk log file. This documents shows you how:
Please describe how your disk was partitioned (how many partitions, how big, which file systems being used).
pierpiotr
Re: wrong fs type
#3 Post by pierpiotr »
I do not know how to find the log after I went to "Create"
Here is something though:
Re: wrong fs type
I don't know.
In Windows the file testdisk.log is written into the folder where the TestDisk executable resides.
When using linux, look into that directory, look into your home directory and look into your working directory - use the pwd command to show it.
Please run the analyse function in TestDisk to ensure that the file exists because I don't know at which moment the file will be created in linux.
pierpiotr
Re: wrong fs type
#5 Post by pierpiotr »
i found it insde /home (FYI),
Here it is :
Thu Feb 13 14:28:01 2025
OS: Linux, kernel 6.8.0-53-generic (#55-Ubuntu SMP PREEMPT_DYNAMIC Fri Jan 17 15:37:52 UTC 2025) x86_64
Compiler: GCC 13.2
ext2fs lib: 1.47.0, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.4
User is not root!
Using locale 'fr_FR.UTF-8'.
Command line: TestDisk /debug
Compiler: GCC 13.2
/dev/sda: size       234441648 sectors
/dev/sda: user_max   234441648 sectors
/dev/sda: native_max 234441648 sectors
/dev/sdb: size       1953525168 sectors
/dev/sdb: user_max   1953525168 sectors
Warning: can't get size for Disk /dev/loop37 - 0 B - 0 sectors, sector size=512
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - Samsung SSD 840 Series, S/N:S19HNEBD304831A, FW:DXT07B0Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1CH162, S/N:Z1D70JCR, FW:CC47
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - LaCie Mobile Drive, FW:0003
Disk /dev/loop0 - 4096 B - 8 sectors (RO), sector size=512
Disk /dev/loop1 - 182 MB / 174 MiB - 357312 sectors (RO), sector size=512
Disk /dev/loop10 - 69 MB / 66 MiB - 135624 sectors (RO), sector size=512
Disk /dev/loop11 - 71 MB / 67 MiB - 138768 sectors (RO), sector size=512
Disk /dev/loop12 - 71 MB / 67 MiB - 138776 sectors (RO), sector size=512
Disk /dev/loop13 - 288 MB / 274 MiB - 562880 sectors (RO), sector size=512
Disk /dev/loop14 - 287 MB / 274 MiB - 562064 sectors (RO), sector size=512
Disk /dev/loop15 - 172 MB / 164 MiB - 337560 sectors (RO), sector size=512
Disk /dev/loop16 - 529 MB / 505 MiB - 1034424 sectors (RO), sector size=512
Disk /dev/loop17 - 366 MB / 349 MiB - 716176 sectors (RO), sector size=512
Disk /dev/loop18 - 541 MB / 516 MiB - 1056784 sectors (RO), sector size=512
Disk /dev/loop19 - 419 MB / 400 MiB - 819344 sectors (RO), sector size=512
Disk /dev/loop2 - 182 MB / 174 MiB - 357112 sectors (RO), sector size=512
Disk /dev/loop20 - 423 MB / 404 MiB - 827600 sectors (RO), sector size=512
Disk /dev/loop21 - 96 MB / 91 MiB - 187776 sectors (RO), sector size=512
Disk /dev/loop22 - 251 MB / 239 MiB - 491312 sectors (RO), sector size=512
Disk /dev/loop23 - 251 MB / 239 MiB - 491312 sectors (RO), sector size=512
Disk /dev/loop24 - 802 KB / 784 KiB - 1568 sectors (RO), sector size=512
Disk /dev/loop25 - 2191 MB / 2089 MiB - 4280128 sectors (RO), sector size=512
Disk /dev/loop26 - 179 MB / 171 MiB - 350392 sectors (RO), sector size=512
Disk /dev/loop27 - 179 MB / 171 MiB - 350592 sectors (RO), sector size=512
Disk /dev/loop28 - 221 MB / 211 MiB - 433128 sectors (RO), sector size=512
Disk /dev/loop29 - 460 MB / 438 MiB - 898704 sectors (RO), sector size=512
Disk /dev/loop3 - 58 MB / 55 MiB - 113992 sectors (RO), sector size=512
Disk /dev/loop30 - 46 MB / 44 MiB - 90720 sectors (RO), sector size=512
Disk /dev/loop31 - 46 MB / 44 MiB - 91008 sectors (RO), sector size=512
Disk /dev/loop32 - 221 MB / 210 MiB - 431744 sectors (RO), sector size=512
Disk /dev/loop33 - 220 MB / 210 MiB - 430920 sectors (RO), sector size=512
Disk /dev/loop34 - 88 MB / 84 MiB - 173016 sectors (RO), sector size=512
Disk /dev/loop35 - 88 MB / 84 MiB - 173000 sectors (RO), sector size=512
Disk /dev/loop36 - 89 MB / 85 MiB - 175256 sectors (RO), sector size=512
Disk /dev/loop4 - 58 MB / 55 MiB - 113384 sectors (RO), sector size=512
Disk /dev/loop5 - 67 MB / 63 MiB - 131016 sectors (RO), sector size=512
Disk /dev/loop6 - 66 MB / 63 MiB - 130448 sectors (RO), sector size=512
Disk /dev/loop7 - 77 MB / 73 MiB - 151288 sectors (RO), sector size=512
Disk /dev/loop8 - 77 MB / 73 MiB - 151328 sectors (RO), sector size=512
Disk /dev/loop9 - 69 MB / 66 MiB - 135512 sectors (RO), sector size=512
Re: wrong fs type
#6 Post by recuperation »
You are not operating with admin rights. TestDisk cannot perform this way. Have a look into the TestDisk manual and/or the tutorials on cgsecurity.org.
Re: wrong fs type
#7 Post by cgrenier »
Assuming you had an NTFS partition as currently listed in your screenshot, try to follow
https://www.cgsecurity.org/testdisk_doc ... oot-sector
pierpiotr
Re: wrong fs type
#8 Post by pierpiotr »
Sorry for this. Here it is again:
Fri Feb 14 16:53:57 2025
Compiler: GCC 13.2
Disk /dev/loop16 - 366 MB / 349 MiB - 716176 sectors (RO), sector size=512
Disk /dev/loop17 - 529 MB / 505 MiB - 1034424 sectors (RO), sector size=512
Disk /dev/loop7 - 77 MB / 73 MiB - 151328 sectors (RO), sector size=512
Disk /dev/loop8 - 77 MB / 73 MiB - 151288 sectors (RO), sector size=512
Disk /dev/sdd - 1000 GB / 931 GiB - LaCie Mobile Drive
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
 1 * HPFS - NTFS              0  32 33 121575 186 19 1953112064 [LaCie]
NTFS at 0/32/33
filesystem size           1953112064
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     NTFS, blocksize=4096, 999 GB / 931 GiB
NTFS at 121601/57/56
mftmirr_lcn               2
     HPFS - NTFS             25 159  7 121601  57 56 1953112064
     NTFS found using backup sector, blocksize=4096, 999 GB / 931 GiB
mftmirr_lcn               2
NTFS: Can't read MFT
     HPFS - NTFS          121601  57 56 243176 211 42 1953112064
This partition ends after the disk limits. (start=1953523711, size=1953112064, end=3906635774, disk end=1953525167)
The harddisk (1000 GB / 931 GiB) seems too small! (< 2000 GB / 1862 GiB)
echo "0 1953112064 linear /dev/sdd 2048" | dmsetup create test0
echo "0 1953112064 linear /dev/sdd 411648" | dmsetup create test1
pierpiotr
Re: wrong fs type
#9 Post by pierpiotr »
cgrenier wrote: 14 Feb 2025, 15:43 Assuming you had an NTFS partition as currently listed in your screenshot, try to follow
Itried it, but my external DD is not mountable.
Compiler: GCC 13.2
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn               2
mftmirr_lcn               2
mftmirr_lcn               2
pierpiotr
Re: wrong fs type
#10 Post by pierpiotr »
I have tried again,
>dr-xr-xr-x     0     0         0  4-Feb-2025 12:12 .
 dr-xr-xr-x     0     0         0  4-Feb-2025 12:12 ..
 dr-xr-xr-x     0     0         0  3-Feb-2025 11:27 $RECYCLE.BIN
 dr-xr-xr-x     0     0         0 30-Aug-2024 19:18 .Trash-1000
 dr-xr-xr-x     0     0         0 23-Dec-2023 22:31 1902-Japon_printable
 dr-xr-xr-x     0     0         0 31-Dec-2019 17:06 CleVieillesPix
 dr-xr-xr-x     0     0         0 12-Jan-2025 22:07 DocPCPortabPE
 dr-xr-xr-x     0     0         0 22-Nov-2019 15:40 Kii
 dr-xr-xr-x     0     0         0  4-Feb-2025 16:17 PCBureauPE
 dr-xr-xr-x     0     0         0 23-Dec-2023 22:09 Rolex
 dr-xr-xr-x     0     0         0  4-Feb-2025 17:20 System Volume Information
 dr-xr-xr-x     0     0         0 26-May-2020 19:01 found.000
 dr-xr-xr-x     0     0         0 29-Sep-2024 18:23 found.001
 -r--r--r--     0     0        56  8-Jan-2020 20:24 .dropbox.device
 -r--r--r--     0     0    106242 23-Jul-2020 19:25 linuxpostinstall-master-e7b42858da99fa0a39d7a3184eb513b9c3
                                                   Next
Use Right to change directory, h to hide Alternate Data Stream
    q to quit, : to select the current file, a to select all files
    C to copy the selected files, c to copy the current file
When I "quit the file listing" with "q", I do not have the "Write" to choose but only "List" again :
mftmirr_lcn               2
 [  Dump  ] >[  List  ]  [  Quit  ]
                           List directories and files
even if I had selected all files with "a".
It looks like I miss something. Sorry if this is the case, but please help.
