Lost BTRFS Partition after system freeze - recoverable?
sandreas
#1 Post by sandreas »
I use encrypted BTRFS root on my Linux Notebook (cryptsetup). Yesterday the system suddenly froze, no chance to recover the system without a hard reset. After turning it off and on, the following error occurred:
No valid Btrfs found on /dev/mapper/root
ERROR: cannot open file system
Followed by an emergency shell. I did not accidentally overwrite parts of the disk nor something that produced heavy disk load. The system just crashed and killed the filesystem.
After doing some research, I tried the following commands:
# still open after failed boot in emergency shell, so luksClose first to be sure
cryptsetup luksClose /dev/mapper/root
# reopen
cryptsetup luksOpen /dev/nvme0n1p1 root
btrfs check /dev/mapper/root
# No valid Btrfs found on /dev/mapper/root
# ERROR: cannot open file system
btrfs filesystem show /dev/mapper/root
# ERROR: no btrfs on /dev/dm-0
mount -t btrfs -o ro,usebackuproot /dev/mapper/root /mnt
# mount: /mnt: wrong fs type, bad option, bad superblock on /dev/mapper/root, missing codepage or helper program, or other error.
btrfs check --super 1 /dev/mapper/root
btrfs rescue chunk-recover /dev/mapper/root
# read super block error
# recover prepare error
# Chunk tree recovery failed
btrfs rescue super-recover -v /dev/mapper/root
# Usage or syntax errors
btrfs rescue zero-log /dev/mapper/root
# ERROR: could not open ctree
btrfs inspect-internal dump-tree --force /dev/mapper/root
# ERROR: device scan of /dev/mapper/root failed: Input/output error
btrfs inspect-internal dump-super /dev/mapper/root
# superblock: bytenr=65536, device=/dev/mapper/root
# ERROR: bad magic on superblock on /dev/mapper/root at 65536 (use --force to dump it anyway)
btrfs inspect-internal dump-super --force /dev/mapper/root
# this at least dumps some data
So, it seems that the partition is completely dead, except the `dump-super --force` part, which clearly shows that BTRFS Partition is in there. `smartctl` did not show any errors. I have no idea how this could have happened, any advice, e.g. using testdisk to recover the partition?
Best,
sandreas
Re: Lost BTRFS Partition after system freeze - recoverable?
Run TestDisk from a pen drive and post your TestDisk log file.
Your luks encryption should provide you with a virtual disk or partition that contains the decrypted content.
Run TestDisk against this device.
sandreas
#3 Post by sandreas »
Thank you for the quick response.
So I tried to analyze the disks and create logs, but somehow it seems strange. I attached the logs I created but do you have any advice regarding which commands to use?
./testdisk_static /log /dev/sdb
./testdisk_static /log /dev/mapper/....
Here are the logs:
LUKS: https://pilabor.com/testdisk_luks.log
Mapper: https://pilabor.com/testdisk_mapper.log
If I did anything wrong, feel free to give further instructions.
It appears that TestDisk did not find any valid BTRFS boot sector when you were running
TestDisk against the block device named luks-c371f9c5-7457-4cc4-8e8d-9432aa1187a4.
As there are no special features available in TestDisk for BTRFS, try out other recovery software that claim BTRFS support.
Before doing so clone that unencrypted virtual device to another block device or file.
I recommend using ddrescue as described in the manual (can be interrupted and continued) regardless of your statement that you had no SMART errors.
Use this clone or file with other recovery software.
If that fails, use PhotoRec on the clone.
Using locale 'de_DE.UTF-8'.
Wed Mar 12 09:45:06 2025
Command line: TestDisk /log /dev/sdb
TestDisk 7.3-WIP, Data Recovery Utility, September 2024
OS: Linux, kernel 6.12.18-1-lts (#1 SMP PREEMPT_DYNAMIC Fri, 07 Mar 2025 18:50:18 +0000) x86_64
Compiler: GCC 14.2
ext2fs lib: 1.47.0, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: 20120504, curses lib: ncurses 6.4
Disk /dev/sdb - 2048 GB / 1907 GiB - CHS 249038 255 63, sector size=512 - RTL9210B-CG, FW:1.00
Disk /dev/sdb - 2048 GB / 1907 GiB - RTL9210B-CG
Partition table type: None
   P Unknown                  0   0  1 249038  29 63 4000797360
Change partition type:
   P Linux LUKS               0   0  1 249038  29 63 4000797360
Analyse Disk /dev/sdb - 2048 GB / 1907 GiB - CHS 249038 255 63
heads/cylinder 64 (FAT) != 255 (HD)
FAT: cluster=2(0x2), pos=6176
     FAT32                    0  32 33   130 170 40    2097152 [EFI System Partition] [NO NAME]
     FAT32, blocksize=4096, 1073 MB / 1024 MiB
     Linux LUKS             130 170 41 178801  17 50 2870339986
     LUKS 2 (Data size unknown), 1469 GB / 1368 GiB
   P FAT32                    0  32 33   130 170 40    2097152 [EFI System Partition] [NO NAME]
   P Linux LUKS             130 170 41 178801  17 50 2870339986
Write isn't available because the partition table type "None" has been selected.
Wed Mar 12 10:24:44 2025
Command line: TestDisk /log /dev/mapper/luks-c371f9c5-7457-4cc4-8e8d-9432aa1187a4
Compiler: GCC 14.2
Disk /dev/mapper/luks-c371f9c5-7457-4cc4-8e8d-9432aa1187a4 - 2047 GB / 1906 GiB - 3998663344 sectors, sector size=512
Analyse Disk /dev/mapper/luks-c371f9c5-7457-4cc4-8e8d-9432aa1187a4 - 2047 GB / 1906 GiB - 3998663344 sectors
BAD_RS LBA=1284304443 296
     FAT16 <32M            1284304443 5405469403 4121164961
This partition ends after the disk limits.
     HFS                      1325850  688536347  687210498
     HFS blocksize=33554432, 351 GB / 327 GiB
BAD_RS LBA=2864861201 194
     FAT12                 2864861201 2878868827   14007627
BAD_RS LBA=4912640525 765
     FAT32 LBA             4912640525 7424694381 2512053857
BAD_RS LBA=3012083454 684
     FAT16 <32M            3012083454 7061650520 4049567067
BAD_RS LBA=4899200984 566
     HPFS - NTFS           4899200984 8877791243 3978590260
BAD_RS LBA=5505830617 303
     FAT32 LBA             5505830617 6108222863  602392247
BAD_RS LBA=6253422204 1067
     FAT32 LBA             6253422204 8427538031 2174115828
SIGINT detected! PhotoRec has been killed.
Wed Mar 12 10:25:59 2025
Compiler: GCC 14.2
   P Unknown                        0 3998663343 3998663344
   P btrfs                          0 3998663343 3998663344
     WBFS                  1165776088 35861397539411159 35861396373635072
     WBFS, 18361034 TB / 16699264 TiB
     WBFS                  1249136112 18014399758618095 18014398509481984
     WBFS, 9223372 TB / 8388608 TiB
     Sys=0D                1766194058 2548632426  782438369
     FATX, 400 GB / 373 GiB
     CramFS                2643293344 2647397394    4104050 [CbàœUÇQê±ÔƼ	Þ]
     cramfs, 2101 MB / 2003 MiB
     SysV 4                2858273227 2858273226          0 [XŒ¿	R>]
     SysV4, 0 B
     SysV 4                3219543979 7126125430 3906581452 [<Ü h¬]
     SysV4, 2000 GB / 1862 GiB
     SysV 4                3471484831 11123416623006 11119945138176 [ËÔf]
     SysV4, 5693 TB / 5178 TiB
The hard disk (2047 GB / 1906 GiB) seems too small! (< 18361035 TB / 16699264 TiB)
