SSD corrupted during reboots, any idea if this is recoverable?
MrGroggle
#1 Post by MrGroggle »
Good morning,
I was checking my Win10 PCs settings to see if it was possible to upgrade to Win11. This involved BIOS UEFI checks with some reboots to see how to enable Secure Boot. After some of these reboots, my main data storage drive (thankfully not OS) was flagged as needing a disk check on startup. The PC was running incredibly slowly, because this drive was running at 100% active time with occasional > 50KB/s read transfers. In disk management the drive shows as RAW, and cannot be accessed by Windows or any disk info software (e.g. CrystalDiskInfo).
I ran TestDisk and was able to review the files during the investigations, and have started to move the most important of these to a new drive just in case. However, I cannot repair the drive, as it emits a "Partition: write error" with no apparent reason. I selected the drive, selected GPT as that was the original format, then Analyze. I did a quick search and a deeper search. I cancelled the deeper search after a time, then went to attempt the repair. Can anyone shed some light on what might need to be done to fix the drive, or whether it's best to just recover the data?
Tue Apr 22 23:02:34 2025
OS: Windows 8 (9200)
ext2fs lib: 1.45.3, ntfs lib: available, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=480103981056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=15376318464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=211956946432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000397795328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=267217010688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=512107741184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=15376302080
Disk \\.\PhysicalDrive0 - 480 GB / 447 GiB - CHS 58369 255 63, sector size=512 - SanDisk SDSSDHII480G, S/N:154307406252, FW:X31200RL
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Samsung SSD 870 EVO 2TB, S/N:S621NF0R201126E, FW:SVT01B6Q
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Hitachi HDS721010CLA332, S/N:JP2911J82B7LTV, FW:JP4OA3MA
Disk \\.\PhysicalDrive3 - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - ADATA SX8200PNP, S/N:2J3620033546        _00000001., FW:S0118C
Disk \\.\PhysicalDrive4 - 15 GB / 14 GiB - CHS 1869 255 63, sector size=512 - SanDisk Cruzer Blade, S/N:4C530000091108102234, FW:1.00
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - Samsung SSD 870 EVO 2TB
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 3907029167)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Data                     2048 3907028991 3907026944 [Basic data partition] [SSD Data]
NTFS at 0/32/33
filesystem size           3907026937
sectors_per_cluster       8
mft_lcn                   39164790
mftmirr_lcn               10770
clusters_per_mft_record   -10
NTFS part_offset=1048576, part_size=2000397791744, sector_size=512
NTFS at 0/32/33
mft_lcn                   39164790
mftmirr_lcn               10770
     MS Data                     2048 3907028984 3907026937 [SSD Data]
NTFS at 243201/78/13
mft_lcn                   39164790
mftmirr_lcn               10770
     MS Data                     2055 3907028991 3907026937
     NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
mft_lcn                   39164790
mftmirr_lcn               10770
NTFS: Can't read MFT
     MS Data               3907028991 7814055927 3907026937
This partition ends after the disk limits. (start=3907028991, size=3907026937, end=7814055927, disk end=3907029168)
file_win32_pread(544,11,buffer,3907029162(243201/80/58)) read err: read after end of file
file_win32_pread(544,8,buffer,3907029165(243201/80/61)) read err: read after end of file
file_win32_pread(544,14,buffer,3907029156(243201/80/52)) read err: read after end of file
file_win32_pread(544,14,buffer,3907029157(243201/80/53)) read err: read after end of file
file_win32_pread(544,14,buffer,3907029158(243201/80/54)) read err: read after end of file
file_win32_pread(544,14,buffer,3907029159(243201/80/55)) read err: read after end of file
file_win32_pread(544,14,buffer,3907029160(243201/80/56)) read err: read after end of file
file_win32_pread(544,14,buffer,3907029162(243201/80/58)) read err: read after end of file
file_win32_pread(544,14,buffer,3907029164(243201/80/60)) read err: read after end of file
file_win32_pread(544,14,buffer,3907029166(243201/80/62)) read err: read after end of file
The hard disk (2000 GB / 1863 GiB) seems too small! (< 4000 GB / 3726 GiB)
NTFS at 0/32/33
mft_lcn                   39164790
mftmirr_lcn               10770
NTFS at 0/32/33
mft_lcn                   39164790
mftmirr_lcn               10770
file_win32_pread(544,16,buffer,382034(23/199/3)) read err: read after end of file
[..] REMOVED FOR BREVITY
file_win32_pread(544,16,buffer,2935462(182/184/41)) read err: read after end of file
mft_lcn                   39164790
mftmirr_lcn               10770
mft_lcn                   39164790
mftmirr_lcn               10770
NTFS at 0/32/33
mft_lcn                   39164790
mftmirr_lcn               10770
 1 P MS Data                     2048 3907028984 3907026937 [SSD Data]
write!
file_win32_pwrite(544,32,buffer,2(0/0/3)) write err
Partition: Write error
Re: SSD corrupted during reboots, any idea if this is recoverable?
MrGroggle wrote: 24 Apr 2025, 08:16 Good morning,
Disk management IS a part of windows. Therefore your disk can be accessed by Windows.
Better SSD products that have reached the maximum writable amount of data remain readable and do not allow write operations. Unfortunately the TestDisk log file shows write errors as well.
Given your description and the TestDisk logfile you should not use this SSD anymore.
