QNAP 'volume' recovery - RAID10
CraigB
#1 Post by CraigB »
I have an 8 disk QNAP NAS in RAID10, with a single 'storage pool' sitting across that array. The pool is divided into what QNAP labels as volumes, but which appear to be ext4 partitions. I accidentally deleted a QNAP 'Shared Folder' which equated to 'volume1' and am hoping I may be able to recover the circa 30TB of media files that were residing there. volume1 still exists in the GUI but shows as empty, the corresponding Linux directory is empty. The array remains intact with 5 other 'volumes' on the device. volume1 was dedicated to this folder and shouldnt be at risk of being overwritten
testdisk.log:
https://drive.google.com/file/d/1ly9fm2 ... sp=sharing
Prior to deleting I could see the partition here:
/dev/mapper/cachedev10
29.8T 25.0T 4.7T 84% /share/CACHEDEV10_DATA
After deletion /share/CACHEDEV10_DATA is empty. testdisk shows /dev/mapper/cachedev10:
TestDisk 7.3-WIP, Data Recovery Utility, April 2025
Select a media and choose 'Proceed' using arrow keys:
 Disk /dev/mapper/CG0ssddev - 420 GB / 391 GiB
 Disk /dev/mapper/cachedev1 - 2748 GB / 2560 GiB
>Disk /dev/mapper/cachedev10 - 34 TB / 31 TiB
 Disk /dev/mapper/cachedev2 - 18 TB / 17 TiB
 Disk /dev/mapper/cachedev3 - 10961 GB / 10208 GiB
 Disk /dev/mapper/cachedev4 - 1421 GB / 1324 GiB
 Disk /dev/mapper/cachedev8 - 2899 GB / 2700 GiB
 Disk /dev/mapper/vg1-lv1 - 2748 GB / 2560 GiB
 Disk /dev/mapper/vg1-lv10 - 34 TB / 31 TiB
 Disk /dev/mapper/vg1-lv1312 - 7193 MB / 6860 MiB
>[Previous]  [  Next  ]  [Proceed ]  [  Quit  ]
Note:
Disk capacity must be correctly detected for a successful recovery.
If a disk listed above has an incorrect size, check HD jumper settings and BIOS
It also lists alternative 'disks' of the same size:
/dev/mapper/vg-lv10
/dev/dm-16
/dev/dm-23
Selecting any of these I can drill into an ext4 partition and list top level files/directories - but I am unable to descend into any directory (I get a No file found error). If I select one of the physical disks (such as /dev/sda) I can see:
Disk /dev/sda - 18 TB / 16 TiB - CHS 2188400 255 63
>D Linux filesys. data           40    1060135    1060096
 D Linux Raid                    40    1060143    1060104 [9]
 D Linux Swap               1060288    1060303         16
 D Linux Raid               1060296    2120527    1060232 [256]
 P Linux filesys. data   35138862048 35139777503     915456
 P Linux Swap            35139922336 35154392591   14470256
                P=Primary  D=Deleted
     Enter: to continue
ext3 blocksize=4096 Large_file Sparse_SB Recover, 542 MB / 517 MiB
Unclear whether these deleted partitions are where my data is hiding ? The RAID10 array is still intact and I have multiple other volumes/partitions sitting atop it from what I can see.
I'm new to testdisk and know little about linux/RAID filestructures - any suggestions would be appreciated.
Re: QNAP 'volume' recovery - RAID10
TestDisk does not include an undelete function for ext4.
