So basically i accidently quick formatted my HDD and then immediately stopped
After i set the drive to read-only using diskpart,then i did a scan with TestDisk,so my HDD went from GPT to MBR for some reason after that quick format,it did find the primary partition and the recovery partition,however the primary partition had a damaged MFT,they were both detected as NTFS but TestDisk said "NTFS found using backup sector" on the primary partition
So here are the logs:"# Drive went from GPT to MBR (i tried doing a GPT partition scan,but it would have been way too slow,taking days)
Tue Feb 25 19:44:47 2025
OS: Windows 8 (9200)
ext2fs lib: 1.45.3, ntfs lib: available, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3840755982336
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=3839290729984
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000396746752
Disk \\.\PhysicalDrive0 - 3840 GB / 3576 GiB - CHS 466945 255 63, sector size=512 - SAMSUNG MZ7LM3T8HCJM-00003, S/N:S242NAAH500062, FW:GXT3003Q
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - JMicron Generic, S/N:0123456789ABCDEF, FW:0405
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - JMicron Generic
Analyse Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63
test_FAT()
1 P FAT16 >32M 0 32 33 243201 45 44 3907024896
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
NTFS at 243070/195/5
filesystem size 3904692224
mftmirr_lcn 2
HPFS - NTFS 14 233 28 243070 195 5 3904692224
NTFS found using backup sector, blocksize=4096, 1999 GB / 1861 GiB
NTFS at 243070/195/6
filesystem size 2097152
mft_lcn 87381
mftmirr_lcn 2
HPFS - NTFS 243070 195 6 243201 78 13 2097152 [Recovery]
NTFS, blocksize=4096, 1073 MB / 1024 MiB
* HPFS - NTFS 14 233 28 243070 195 5 3904692224
P HPFS - NTFS 243070 195 6 243201 78 13 2097152 [Recovery]
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 20-Nov-2024 10:33 .
5 dr-xr-xr-x 0 0 0 20-Nov-2024 10:33 ..
38 dr-xr-xr-x 0 0 0 18-Jan-2023 01:31 Recovery
36 dr-xr-xr-x 0 0 0 11-Feb-2023 14:55 System Volume Information
40 -r--r--r-- 0 0 0 9-Oct-2024 14:24 $WINRE_BACKUP_PARTITION.MARKER
45 -r--r--r-- 0 0 0 20-Nov-2024 10:33 Recovery.txt
1 * HPFS - NTFS 14 233 28 243070 195 5 3904692224
2 P HPFS - NTFS 243070 195 6 243201 78 13 2097152 [Recovery]
So i would like to know if this is recoverable,Im planning to send the drive to a professional,I really hope its recoverable
Thanks
Damaged MFT and HDD went from GPT to MBR after accidental quick format
XXXDark303
Re: Damaged MFT and HDD went from GPT to MBR after accidental quick format
You will be told your professional. I don't have a crystal ball.XXXDark303 wrote: 18 Jun 2025, 17:41 So i would like to know if this is recoverable,Im planning to send the drive to a professional,I really hope its recoverable
XXXDark303
Ok.
I just asked if this could be recoverable btw.
