Recover files from Raid disk
PhantomR13
#1 Post by PhantomR13 »
I have a disk, which was part of a RAID array, and I am trying to recover the files on it, without having the other RAID volumes. Could you give me a hand, please? Here's a copy of my log, and a screenshot from TestDisk:
Sat Jun 21 17:49:44 2025
OS: Windows 8 (9200)
ext2fs lib: 1.45.3, ntfs lib: available, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=61958258688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=998038831104
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=61923655680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=512108789760
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=599262232576
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=33554432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=228390338560
Disk \\.\PhysicalDrive0 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - ST3000DM001-1ER166, S/N:Z503APL9, FW:CC26
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WD_BLACK SN850X 1000GB, S/N:E823_8FA6_BF53_0001_001B_444A_48E6_7F25., FW:620331WD
Disk \\.\PhysicalDrive2 - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - SAMSUNG MZVLB512HAJQ-000L7, S/N:0025_3886_81B5_746D., FW:5L2QEXA7
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Samsung SSD 970 EVO Plus 1TB, S/N:0025_385A_1151_0C20., FW:4B2QEXM7
Disk \\.\PhysicalDrive4 - 61 GB / 57 GiB - CHS 7532 255 63, sector size=512 - Patriot Memory, S/N:0E7F20190070, FW:PMAP
Disk \\.\PhysicalDrive0 - 3000 GB / 2794 GiB - ST3000DM001-1ER166
Analyse Disk \\.\PhysicalDrive0 - 3000 GB / 2794 GiB - CHS 364801 255 63
BAD_RS LBA=1 0
 1 P EFI GPT                  0   0  2 267349  89  4 4294967295
Bad relative sector.
recover_EXT2: s_block_group_nr=0/18, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 622544
recover_EXT2: part_size 4980352
Filesystem created: Wed Sep  7 00:28:53 2016
Last mount time:    Sun Jul 10 22:08:26 2022
     Linux                    0  32 33   310  35 45    4980352 [1.42.6-7373]
     ext4 blocksize=4096 Large_file Sparse_SB, 2549 MB / 2431 MiB
Raid magic value at 310/35/46
Raid apparent size: 2180925952 sectors
Raid chunk size: 0 bytes
md0 md 0.90.0 B.Endian Raid 1: devices 0(8,1) 1(8,17) 2(8,33) 3(8,49) 4(8,65) 5(8,81)* 6(8,97) 7(8,113)
     Linux RAID               0  32 33   310  37 47    4980480 [md0]
     md 0.90.0 B.Endian Raid 1: devices 0(8,1) 1(8,17) 2(8,33) 3(8,49) 4(8,65) 5(8,81)* 6(8,97) 7(8,113), 2550 MB / 2431 MiB
     Linux Swap             310  37 48   571  56 45    4194160
     SWAP2 version 1, pagesize=4096, 2147 MB / 2047 MiB
Raid magic value at 571/56/62
Raid apparent size: 2180922880 sectors
md1 md 0.90.0 B.Endian Raid 1: devices 0(8,2) 1(8,18) 2(8,34) 3(8,50) 4(8,66) 5(8,82)* 6(8,98) 7(8,114)
     Linux RAID             310  37 48   571  58 63    4194304 [md1]
     md 0.90.0 B.Endian Raid 1: devices 0(8,2) 1(8,18) 2(8,34) 3(8,50) 4(8,66) 5(8,82)* 6(8,98) 7(8,114), 2147 MB / 2048 MiB
Raid magic value at 587/111/37
Raid apparent size: 3837972614 sectors
Charly:2 md 1.x L.Endian Raid 5 - Array Slot : 10 (failed, 1, failed, 3, 4, failed, 6, failed, 2, 7, 5, 0, failed, failed, failed)
     Linux RAID             587 111 37 364788 112  4 5850889096 [Charly:2]
     md 1.x L.Endian Raid 5 - Array Slot : 10 (failed, 1, failed, 3, 4, failed, 6, failed, 2, 7, 5, 0, failed, failed, failed), 2995 GB / 2789 GiB
     Linux                    0  32 33   310  41 51    4980736 [1.42.6-7373]
     ext4 blocksize=4096 Large_file Sparse_SB, 2550 MB / 2432 MiB
   * Linux RAID             587 111 37 364788 130 14 5850890240 [Charly:2]
Re: Recover files from Raid disk
PhantomR13 wrote: 21 Jun 2025, 15:53 Hello,
Unfortunately your description is not sufficient.
Be aware that TestDisk won't assemble member disks of a RAID array. Furthermore, having one disk of a Raid array, for instance one out of three disks of a RAID5-type array, limits your recovery success to files that fit into a single RAID stripe. I guess you would need PhotoRec for that.
I don't know what you mean by saying "without having the other RAID volumes".
Does this refer to the virtual RAID device referenced to below?
When you are asking your question somewhere else, you should describe which RAID level you were using, how many disks your RAID array consisted of, how RAID was realized (software, hardware) and how you partitioned and formated the resulting virtual RAID device.
