I had a laptop which had dual boot. windows 10 and ubuntu. I put its hard disk in an enclosure and was using it , one day i maximized one windows partition as linux partion was visible as unallocated space. now windows isn't recognizing it and disk management is showing it as unallocated space.
tried testdisk quick search which is showing
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63
Analyse cylinder 52426/121600: 43%
MS Data 2048 1085439 1083392 [Recovery]
EFI System 1085440 1290239 204800 [EFI System Partition] [NO NAME]
MS Data 1323008 416247154 414924147
MS Data 414973953 416247808 1273856
MS Data 416247808 417521663 1273856
MS Data 1323008 417523711 416200704
MS Data 417523711 833724414 416200704
it has become ultra slow after 42 %. there are overlapping area .in such case testdisk doc suggest to fix boot first.
start testdisk
select the device containing the partition (avoid drive letter like D:)
confirm the partition table type
go in the Advanced menu
select the NTFS partition
choose Boot
select RebuildBS
choose List.
now my scan isnt showing boot it show efi. further if I choose advance option it shows me only image creation option. someone help how to proceed. please note this was a dual boot hard disk but right now it was being used as and extarnal disk
corrupted partition table on external disk from an old dual boot
Re: corrupted partition table on external disk from an old dual boot
Please post your TestDisk log file and your smartmontools logfile.
How to extract SMART parameters:
viewtopic.php?f=5&t=10910
This is what I have after running testdisk.
Sun Aug 17 19:26:05 2025
TestDisk 7.3-WIP, Data Recovery Utility, April 2025
OS: Windows 8 (9200)
Compiler: GCC 12.4, Cygwin32 3003.3
ext2fs lib: 1.45.3, ntfs lib: available, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000204884992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=511043436544
Disk \\.\PhysicalDrive0 - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512 - SAMSUNG MZVL8512HELU-00BH1, S/N:0025_384A_41B2_B041., FW:HPS3NKXM
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Mass Storage Device, S/N:116AC2101219
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - Mass Storage Device
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953525165 (expected 1953525165)
hdr_lba_start=34
hdr_lba_end=1953525132
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Reserved 34 32767 32734 [Microsoft reserved partition]
Analyse Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
filesystem size 1083392
mft_lcn 45141
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=554696704, sector_size=512
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS, blocksize=4096, 554 MB / 529 MiB
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
no_of_cluster : 98304 (2 - 98305)
fat_length 769 calculated 769
FAT32 at 67/144/14
FAT: cluster=2(0x2), pos=1093632
FAT32, blocksize=1024, 104 MB / 100 MiB
NTFS at 82/90/9
filesystem size 414924147
mftmirr_lcn 2
NTFS part_offset=677380096, part_size=212441163264, sector_size=512
NTFS at 82/90/9
mftmirr_lcn 2
NTFS, blocksize=4096, 212 GB / 197 GiB
NTFS at 25910/58/5
filesystem size 1273856
mft_lcn 53077
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 652 MB / 622 MiB
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS, blocksize=4096, 652 MB / 622 MiB
NTFS at 25989/165/32
filesystem size 416200704
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 213 GB / 198 GiB
mftmirr_lcn 2
NTFS, blocksize=4096, 213 GB / 198 GiB
P MS Data 2048 1085439 1083392 [Recovery]
P EFI System 1085440 1290239 204800 [EFI System Partition] [NO NAME]
1 P MS Data 2048 1085439 1083392 [Recovery]
2 P EFI System 1085440 1290239 204800 [EFI System Partition] [NO NAME]
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 17/234/2
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
MS Data 281675 287848 6174
NTFS at 17/234/2
mft_lcn 2058
mftmirr_lcn 5162
MS Data 287848 294021 6174 [Boot]
NTFS at 18/77/52
mft_lcn 2058
mftmirr_lcn 5162
MS Data 287899 294072 6174
NTFS at 18/77/52
mft_lcn 2058
mftmirr_lcn 5162
MS Data 294072 300245 6174 [Boot]
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
1 P EFI System 1085440 1290239 204800 [EFI System Partition] [NO NAME]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
gpt_change_part_type
Change partition type:
NTFS 1323008 416247154 414924147
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
P MS Data 1323008 416247154 414924147
3 P MS Data 1323008 416247154 414924147
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
P FAT32 1085440 1290239 204800 [EFI System Partition] [NO NAME]
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 21-Oct-2022 08:41 .
5 dr-xr-xr-x 0 0 0 21-Oct-2022 08:41 ..
40 dr-xr-xr-x 0 0 0 21-Oct-2022 08:41 Recovery
36 dr-xr-xr-x 0 0 0 29-Aug-2022 09:54 System Volume Information
dir_partition inode=0
3 drwxr-xr-x 0 0 0 19-Sep-2024 15:54 EFI
26840 drwxr-xr-x 0 0 0 28-Aug-2022 21:24 System Volume Information
X 35 drwxr-xr-x 0 0 1024 14-Jul-2024 07:47 MSI9a82f.tmp
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
New options :
Dump : No
Align partition: Yes
Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P Unknown 34 32767 32734 [Microsoft reserved partition]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 17/234/2
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 17/234/2
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 18/77/52
mft_lcn 2058
mftmirr_lcn 5162
NTFS at 18/77/52
mft_lcn 2058
mftmirr_lcn 5162
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
New options :
Dump : No
Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 45141
mftmirr_lcn 2
FAT32 at 67/144/14
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
FAT32 at 67/144/14
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 82/90/9
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
NTFS at 25910/58/5
mft_lcn 53077
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
If you wonder why I have not answered yet:
I am waiting for the smartmontools log file!
