run testdisk in winpe?
pikoslav
#1 Post by pikoslav »
- Made my own winPe with Windows ADK
- Put testdisk on it (tried all 3 version on the download website)
- I get black screen when i open it when in booted WinPE
Anybode got testdisk running in WinPE? I quite like it because it's small and CLI. I know that there are bootable ISOs with testdisk, but i would like to integrate it into my own bootable repair thingy
Re: run testdisk in winpe?
Boot different iso files instead. SystemRescueCD and Gparted are the smallest distributions that contain the TestDisk package.
#3 Post by recuperation »
Pikoslav,
this is an answer that has not been written by me, but from a suspected spammer:
TestDisk can run in WinPE, but a black screen usually means missing dependencies. Make sure your WinPE build includes the C runtime libraries (vcruntime140.dll etc.) and the console subsystem. Also, try running it from the x:\Windows\System32 folder or an extracted folder with full permissions. Some users found that using the 32-bit version in a 64-bit WinPE works better.
