The directory name is invalid – file system RAW
xJamie
#1 Post by xJamie »
Hello dears,
first things first:
- the external hard drive is a 1 TB WD My Passport WDBYNN0010BBK-0B
- the OS is Windows 10 Home 64-bit x64, version 22H2, build 19045.6396
What happened?
After doing a backup of all my files onto the external hard drive (due to a clean windows installation), I tried to get the backup back on the pc. However, the system is not able to open the external hard drive path. Yet it is visible but without the storage:
- when trying to access the external hard drive, the following error pops up:
Location is not available.
E:\ is not accessible.
The file or directory is corrupted and unreadable.
Checking the disk management of Windows I see the hard drive with file system RAW / error-free (base partition):
However, after a little research I found TestDisk (v7.2) to try to get access to the hard drive.
Which steps did I already do?:
- Proceed with the corrupted hard drive:
EFI GPT partition table type has been detected:
1. Advanced path:
1.1 Checking the advanced path to see the partition and boot sector status – both are on status OK:
Since both status are OK, I went for the repair MFT:
Yet I still could not access the external hard drive.
2. Next on the list was the Analyse path:
2.1 Quick Search result:
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121597 255 63
NTFS at 0/32/33
filesystem size           1953454080
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=1048576, part_size=1000168488960, sector_size=512
NTFS at 0/32/33
mftmirr_lcn               2
     MS Data                     2048 1953456127 1953454080 [My Passport]
file_win32_pread(572,11,buffer,1953458170(121597/37/35)) read err: read after end of file
file_win32_pread(572,8,buffer,1953458173(121597/37/38)) read err: read after end of file
file_win32_pread(572,14,buffer,1953458164(121597/37/29)) read err: read after end of file
file_win32_pread(572,14,buffer,1953458165(121597/37/30)) read err: read after end of file
file_win32_pread(572,14,buffer,1953458166(121597/37/31)) read err: read after end of file
file_win32_pread(572,14,buffer,1953458167(121597/37/32)) read err: read after end of file
file_win32_pread(572,14,buffer,1953458168(121597/37/33)) read err: read after end of file
file_win32_pread(572,14,buffer,1953458170(121597/37/35)) read err: read after end of file
file_win32_pread(572,14,buffer,1953458172(121597/37/37)) read err: read after end of file
file_win32_pread(572,14,buffer,1953458174(121597/37/39)) read err: read after end of file
   P MS Data                     2048 1953456127 1953454080 [My Passport]
NTFS Volume is dirty.
2.2 Listing files (P):
dir_partition inode=5
ntfs_readdir failed for cluster 5: Input/output error
       5 dr-xr-xr-x     0      0         0 27-Sep-2025 09:36 .
       5 dr-xr-xr-x     0      0         0 27-Sep-2025 09:36 ..
2.3 Deeper Search result:
NTFS at 0/32/33
mftmirr_lcn               2
NTFS at 0/32/33
mftmirr_lcn               2
SYSV4 Marker at 75883/200/5
Below is the full tesdisk.log file with all the mentioned steps included.
Sat Sep 27 22:57:42 2025
OS: Windows 8 (9200)
ext2fs lib: 1.45.3, ntfs lib: available, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.1
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=239464076288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000148566016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000168488960
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA HDWD110, S/N:Y8SRGUJNS, FW:MS2OA8R0
Disk \\.\PhysicalDrive1 - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - Patriot Burst, S/N:742D079307B700154698, FW:SBFM61.3
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512 - WD My Passport 25E1, S/N:WXK1A57HU2YT, FW:1019
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - WD My Passport 25E1
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953458175 (expected 1953458175)
hdr_lba_start=34
hdr_lba_end=1953458142
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Data                     2048 1953456127 1953454080 [My Passport] [My Passport]
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn               2
Status: OK
Status: OK
Sectors are identical.
repair_MFT
NTFS at 0/32/33
MFT and MFT mirror match perfectly.
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn               2
Status: OK
Status: OK
Analyse Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121597 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mftmirr_lcn               2
NTFS at 0/32/33
mftmirr_lcn               2
NTFS at 0/32/33
mftmirr_lcn               2
NTFS at 0/32/33
mftmirr_lcn               2
recover_sysv4
     Unknown               1219072999 18827966944230 18826747871232 [Öš 8!]
     SysV4, 9639 TB / 8766 TiB
Partition not added.
NTFS at 121597/5/8
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
NTFS at 121597/5/8
mftmirr_lcn               2
NTFS: Can't read MFT
     MS Data               1953456127 3906910206 1953454080
This partition ends after the disk limits. (start=1953456127, size=1953454080, end=3906910206, disk end=1953458176)
The hard disk (1000 GB / 931 GiB) seems too small! (< 2000 GB / 1862 GiB)
To be honest, I was able to somehow recover files using PhotoRec, however, since I got ~511 GB of data (~82k files) and PhotoRec doesn’t sort the files (instead it renames all files and puts them in random folders), I will not be able to sort all the corresponding files to the original folders/paths.
I really hope the situation is not too bad and it is somehow possible to recover the hard drive with the original folder structure.
Many thanks for going through the post. I would also be very grateful, if any expert has an idea how to solve this.
Best regards
Re: The directory name is invalid – file system RAW
xJamie wrote: 29 Sep 2025, 09:38 The directory name is invalid – file system RAW
Hello dears,
first things first:
What happened?
Laut der Logdatei von TestDisk ist mindestens ein Cluster nicht lesbar.
Bitte die Logdatei von smartmontools erzeugen und hier veröffentlichen:
viewtopic.php?f=5&t=10910
Es wäre sinnvoll, die Festplatte unter Linux mit ddrescue zu klonen, wie im Handbuch beschrieben.
Wenn Testdisk mit der P-Taste nicht in der Lage war, das Wurzelverzeichnis inklusive Inhalt anzuzeigen, sollten Sie irgendeine andere kommerzielle Software zur Datenrettung verwenden - ich gehe davon aus, dass CHKDSK diesen Defekt nicht beheben kann.
PhotoRec ist das letzte Mittel, wenn alles andere nicht funktioniert, weil Metadaten nicht verfügbar sind. PhotoRec benötigt keine Metadaten. Es versucht, Dateien aufgrund von Fingerabdrücken zu identifizieren.
PhotoRec durchsucht die Festplatte von vorne nach hinten.
Die gefundenen Dateien werden in Anlehnung an ihren Fundort auf der Festplatte benamt und der Reihe nach (nicht zufällig!) in Ordnern abgelegt.
xJamie
#3 Post by xJamie »
Vielen Dank für die schnelle Antwort!
recuperation wrote: 29 Sep 2025, 14:47 Laut der Logdatei von TestDisk ist mindestens ein Cluster nicht lesbar.
Bekommt man bei diesem Fehler die Festplatte gerettet, damit man wieder normalen Zugriff hat?
recuperation wrote: 29 Sep 2025, 14:47 Bitte die Logdatei von smartmontools erzeugen und hier veröffentlichen:
Hier die logs:
smartctl -a /dev/sdc > myreport1.txt
(.../sdc, da Datenträger 2)
Smartctl open device: /dev/sdc [SAT] failed: \\.\PhysicalDrive2: Open failed, Error=5
smartctl -a -d sat,12 /dev/sdx > myreport2.txt
smartctl -a -d sat,16 /dev/sdx > myreport3.txt
Smartctl open device: /dev/sdx [SAT] failed: \\.\PhysicalDrive23: Open failed, Error=2
smartctl -a /dev/hdc > myreport4.txt
Warning: Limited functionality due to missing admin rights
Device Model:     WD My Passport 25E1
Serial Number:    WXK1A57HU2YT
Firmware Version: 1019
Device is:        Not in smartctl database
ATA Version is:   [No Information Found]
Local Time is:    Mon Sep 29 16:39:55 2025 MS
                  Enabled status cached by OS, trying SMART RETURN STATUS cmd.
SMART support is: Disabled
SMART Disabled. Use option -s with argument 'on' to enable it.
(override with '-T permissive' option)
=> Ich besitze volle Adminrechte, trotzdem wird vor fehlenden Adminrechten gewarnt.
smartctl -s on -a /dev/hdc > myreport5.txt
Local Time is:    Mon Sep 29 17:13:07 2025 MS
=== START OF ENABLE/DISABLE COMMANDS SECTION ===
SMART Enabled.
Read SMART Data failed: Function not implemented
SMART Status not supported: Function not implemented
SMART overall-health self-assessment test result: UNKNOWN!
SMART Status, Attributes and Thresholds cannot be read.
SMART Error Log not supported
SMART Self-test Log not supported
Selective Self-tests/Logging not supported
The above only provides legacy SMART information - try 'smartctl -x' for more
smartctl -x -s on -a /dev/hdc > myreport6.txt
Local Time is:    Mon Sep 29 17:14:53 2025 MS
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Unavailable
Write cache is:   Unavailable
DSN feature is:   Unavailable
ATA Security is:  Unavailable
SMART Enabled.
Read SMART Log Directory failed: Function requires admin rights
General Purpose Log Directory not supported
SMART Extended Comprehensive Error Log (GP Log 0x03) not supported
SMART Extended Self-test Log (GP Log 0x07) not supported
SCT Commands not supported
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11) not supported
recuperation wrote: 29 Sep 2025, 14:47 Es wäre sinnvoll, die Festplatte unter Linux mit ddrescue zu klonen, wie im Handbuch beschrieben.
Leider habe ich keinen Zugriff auf ein Linux-System. Würde sich hier ein Windows Subsystem für Linux (WSL) anbieten?
Welchen Sinn hat das Klonen, außer ein Backup der korrupten Festplatte zu haben?
recuperation wrote: 29 Sep 2025, 14:47 Wenn Testdisk mit der P-Taste nicht in der Lage war, das Wurzelverzeichnis inklusive Inhalt anzuzeigen, sollten Sie irgendeine andere kommerzielle Software zur Datenrettung verwenden - ich gehe davon aus, dass CHKDSK diesen Defekt nicht beheben kann.
Da ich die Dateien über PhotoRec wieder herstellen konnte, benötige ich eigentlich keine andere (kommerzielle) Software, oder?
Oder gehen mit PhotoRec ggf. Daten/Dateien verloren?
recuperation wrote: 29 Sep 2025, 14:47 PhotoRec ist das letzte Mittel, wenn alles andere nicht funktioniert, weil Metadaten nicht verfügbar sind. PhotoRec benötigt keine Metadaten. Es versucht, Dateien aufgrund von Fingerabdrücken zu identifizieren.
Das heißt, die Dateien sind (mehr oder weniger) sortiert?
Leider besteht trotzdem das Problem, dass alle Dateien umbenannt sind (z. B. f0525168.jpg), weswegen ich gerne den Zugriff auf die Festplatte hätte.
xJamie wrote: 29 Sep 2025, 16:19
Das Klonen stellt sicher, dass bei weiteren Datenrettungsversuchen die Datenrettungsquelle sich nicht weiter verschlechtert. Es geht also darum, dass ein physisch intaktes Duplikat für beliebig viele Rettungsversuche zur Verfügung steht.
PhotoRec ist ein Notnagel, wenn nichts anderes mehr funktioniert. Verloren geht gar nichts, denn Sie überschreiben ja Ihre Defektplatte nicht. Fragmentierung auf Ihrer Defektplatte führt aber dazu, dass Dateien nicht korrekt wiederhergestellt werden können. Aufgrund der vorhandenen Datengrundlage kann PhotoRec solche Fälle eben prinzipbedingt nicht erkennen.
Eine andere Datenrettungssoftware, die Reste von Metadaten auswerten kann, kann zum Teil oder gar ganz Ordnerstrukturen und Dateinamen wiederherstellen. Liegen auswertbare Informationen über die verwendeten Cluster vor, kann die betroffene Datei auch korrekt wiederhergestellt werden - mit korrekter Länge und korrektem Inhalt.
Ja, nach Position auf der Festplatte. Aber danach sortiert kein Mensch.
Deswegen müssen Sie - wie schon erklärt - andere Datenrettungsprogramme verwenden.
Das TestDisk-Paket kann ein paar Fehler auf einer Festplatte reparieren. Im Normalfall aber modifiziert Datenrettungssoftware eine fehlerhafte Festplatte nicht.
Ihre Formulierung "Zugriff auf die Festplatte" impliziert aber, dass die Datenrettungssoftware ihren Defektkandidaten repariert oder irgendwie in lesbarer Form auf Ihrem Arbeitsplatz einblendet.
xJamie
#5 Post by xJamie »
Vielen Dank für die Hilfeversuche. Ich habe einfach mal "chkdsk E: /f" versucht und die Festplatte funktioniert nun wieder!
Zumindest bekomme ich nun die Daten in der bekannten Struktur und kann diese auf eine neue Platte übertragen.
kandaon
#6 Post by kandaon »
God!, this thread is so detailed, I couldn't get to read it! (My German is quite rusty, too.)
I did something stupid under Linux, deleted the EFi partition and tried to overwrite it with the main data partiton. All on a 4TB data disk, under Ubuntu.
Now my data partition is RAW and no filesystem restore app has managed to fix that, either under Windows11, or under Linux. TestDisk said at one point it had fixed it and I had to restart, but it didn't work. I've backed up the small, EFI partition and am currently backing up the huge data one, then I'll try some more invasive moves.
I'm not great with the se things (just a basic understanding of computers), but your software and your forum are of great help (thank you!!!)
kandaon
#7 Post by kandaon »
I ran a second scan, the app got stuck at the same sector. So it's safe to assume that one is bad and TestDisk can't get past it. Should I run a sector scan to isolate the bad one? Would you recommend a specific tool for that?
