Hard drive without partition table
congui
#1 Post by congui »
Good morning.
I have a hard drive that was working and suddenly stopped working. I had to buy another hard drive from the same series to replace the chip because it felt like it had burned out. After replacing it, some Windows programs recognize the hard drive as unbootable and without partitions, and some Windows programs don't even recognize it. Linux doesn't even recognize it.
Although Windows doesn't recognize your software, yours does, but it shows up with a huge amount of TB. I'm sending the image.
I've used your application a bit, but I haven't been able to recover all the information that was on the partition. Any help you can offer?
I have photographs from many years ago and I need to recover them.
Thank you very much.
Images in Google Drive: https://drive.google.com/drive/folders/ ... sp=sharing
Re: Hard drive without partition table
Please consult with a professional recovery lab.
congui
#3 Post by congui »
Hi! =)
Can you recommend someone?
Thank you!
