Accidentally lost partition
ksotos
#1 Post by ksotos »
Hi all,
On my Windows 7 laptop, I have two HDD installed, the first is my boot disk with the windows and the second is a disk mainly for storing files.
Few weeks ago, I used Windows disk manager to try to create a new partition on my second drive in order to install Linux and have a dual boot system.
In the process of doing this, I deleted the two existing partitions on my second drive.
I ran Testdisk but although I could see both partitions when I search, the second partition (which is dynamic) shows as not recoverable.
Any idea of what can I do to try to recover this?
I used Photorec and retrieved the stored files but most of them have lost their filename so it's impossible to understand what is what and there is no folder structure anymore so it's really hard to find any files amongst thousands. Also, I noticed that most if not all, of my photos seem to have been recovered with no issues but a lot of my recovered PDF files are showing as corrupted and can't be opened anymore.
I stopped using the drive since the partition was lost so it's very unlikely files were overwritten.
Any idea/suggestion of how I can recover the lost partitions to make my life a lot easier?
Re: Accidentally lost partition
Read this article:
If the p-key ("list files") does not work, try out any other recovery software to see if they do better.
PhotoRec is the last line of defense if everything else fails.
ksotos
#3 Post by ksotos »
Hi there,
Thanks for the guidance, I followed the instructions as per the link you shared.
I managed to find both partitions on my drive, the second one was showing as Deleted.
I followed the instructions to Write the partitions in the partitions table.
I then got the next screen where my Boot sector is showing as Bad and the Backup boot sector as OK.
I then selected the Backup BS option but I get a message saying "Write error: Can't overwrite NTFS boot sector"
Any suggestion why this might be and how to overcome this?
Have you granted admin rights to TestDisk?
Is your "HDD" in question a SSD?
ksotos
#5 Post by ksotos »
Sorry if I am asking the obvious, but how do I grant admin rights? I run "testdisk_win.exe" and I am asked if I want to allow the software to make changes, is this what you refer to? It does not specifically asks for admin rights.
No, the drive is a normal external 1GB HDD, not an SSD.
#6 Post by recuperation »
Initial posting:
ksotos wrote: 30 Oct 2025, 02:27 Hi all,
Later on:
ksotos wrote: 01 Nov 2025, 13:44 No, the drive is a normal external 1GB HDD, not an SSD.
It's disappointing to read that kind of documentation. The case changed from a laptop with two disks inside to a case with one disk and the other one attached externally.
The worse the description is the the lesser the chance of getting a correct answer.
As for your question right-click on "testdisk_win.exe" and select "run as admin".
ksotos
#7 Post by ksotos »
recuperation wrote: 03 Nov 2025, 15:41 It's disappointing to read that kind of documentation. The case changed from a laptop with two disks inside to a case with one disk and the other one attached externally.
Apologies for this inconsistency, it was by no means intentional or lack of attention, I really appreciate the time that you spend to try to assist.
The reason of this discrepancy between my first post and the last one, is that I removed the HDD from my laptop and I installed it in an external enclosure to avoid damaging any data from it while trying to recover the lost partitions.
If you don't mind helping any further, I've run Testdisk with Administrator rights, I run the Analyse function and both my partitions (alongside a couple old ones) were found.
with a comment that the last partition on the list (WD <B>) can't be recovered. I proceeded to the Quick Scan after which I got to the next screen where the last partition was no more visible
I then proceeded to click Continue to get to the next screen where my second partition is also not visible
Any idea on what to do next? How do I recover my second partition (WD<B>) which is no longer visible?
