Why might photorec do this?
I used a scripted run of photorec to recover everything on a usb stick. It recovered lots of files including pdf and gnucash.
I then did a test and searched only for pdf and it returned just pdf. I then did the same for gnucash and it recovered nothing.
I wonder why that might happen? It's certainly capable of finding gnucash files but leaves me a bit worried files will get left behind if I search for a specific file type.
Thank you for any insight.
Re: Why might photorec do this?
Which version are you using?
PhotoRec 7.2, on openSUSE
Please download the 7.3 BETA and try to reproduce the error.
The linux version contains the static version of PhotoRec - no installation is necessary.
Thank you for replying.
Same with 7.3 beta... it doesn't work.
PhotoRec syntax error: gnucash,enable,search
If I run the same command but replace gnucash with txt it recovers all the txt (and py, html etc) files.
I don't know how many filetypes it might do it for but I can't get it to work for any custom signatures I create either. If I use fileopt,everything,enable then the gnucash files, and custom signatures are found.
Please explain these words.lostbit wrote: 12 Dec 2025, 23:18 Thank you for replying.
Custom signatures do work but I can't help you without a proper bug documentation. Your error description is vague and lacking details.
There is at least one thread where I went through creating a custom signature in all details, based on the failures the user experienced.
You should always check your custom signature by putting some files and a file with a type that you want to find. Put them on a USB pen drive p.e. If that test file is not found, your signature is wrong.
I've learned that PhotoRec doesn't handle individual file types, onlly families of file types. So, gnucash is found using gz.
gz
gnucash, kmy, RData, schematic, sla, tgz, als, prproj
zip
docx, xlsx, pptx, odt, ods, odp, epub, jar, apk, kmz, vsdx, kra, xd, indd, xpi, sketch
txt
py, php, html, asp, bat, c, h, java, js, json, sh, xml
tiff
pef, nef, dcr, sr2, arw, cr2, dng, wdp
mov
mp4, m4a, m4v, 3gp, 3g2, heic, jp2, cr3
doc
xls, ppt, vsd, pub, mdb, msg, max, sldprt, fla, wps, qbb
riff
wav, avi, cdr, cda, ani, cpr, aep
mkv
webm, ebml
asf
wma, wmv
exe
dll
gz
zip
txt
tiff
mov
doc
riff
mkv
webm, ebml
asf
wma, wmv
exe
dll
I give up. I can't help you. Yes, I know what families are.
Again:
These two lines are not a bug report!
A bug report contains all the necessary information to reproduce a bug.
Typically it contains sentences. A sentence contains at least a subject and a verb.
This - is not a sentence!PhotoRec syntax error:
I don't know what these words above are supposed to mean.
maxencevidal26
PhotoRec detects files by file signatures. PDFs have a strong, well-defined signature, so they’re easy to find. GnuCash files often don’t have a unique signature (or are embedded in SQLite/XML), so PhotoRec may only recover them during a broad scan and miss them when filtering by type.
So yes, when you restrict file types, some files can be missed. A full scan is safer for uncommon formats.
What you say contradicts what Christophe Grenier programmed as far as I can read C.
Furthermore the scan undertaken by PhotoRec is always complete. Deselecting families does not reduce scan time.
