Is "Quick Search" faster when the partition is in Intel MBR than when it is in EFI GPT?
I have a 1TB external HDD. One of its partitions became RAW.
TestDisk automatically detected EFI GPT which I validated by leaving it as is. I launched Quick Search, the search took 4 days non-stop. Unfortunately, TestDisk told me that the partitions are unrecoverable!
I had used the same process for the same problem some time ago, and I was able to recover the data.
So I quit TestDisk and restarted it, this time choosing "Intel" and launched "Quick Search". The search this time was much faster, it took approximately less than 3 hours! The data counter was moving much faster.
The question here: Is "Quick Search" faster when the partition is in Intel MBR than when it is in EFI GPT? Have you observed the same thing?
"Quick Search" Comparison for EFI GPT and Intel MBR
Re: "Quick Search" Comparison for EFI GPT and Intel MBR
I don't know and I don't care because I let TestDisk run unattended.
If your partition search for a 1 TB secret disk (no further information given) lasts four days, this is definitively too long.
If your USB connection is OK, then this results suggests lots of unreadable sectors.
By the way, instead of running TestDisk immediately you are always better of reading out SMART parameters first, cloning the disk using ddrescue as described in the manual and running TestDisk against the physically healthy cloned disk.
+1 to what recuperation said: check SMART first, then clone with ddrescue and run TestDisk on the image. Repeated multi-day scans on a failing drive are the fastest way to lose the data for good.
And once you have the image — hardware failure is only half the problem. The other half is ransomware, which takes out the backup too if it's a mounted share. Worth sorting out while you're thinking about it anyway. (For French readers, comparora.fr runs side-by-side antivirus tests — handy if you're picking one.
